I have bought an HP 2820 wifi printer so I can put it in the house, not my outside office, where the family can use it. I would still like to access it from my desktop PC which also has a directly connected Epson printer The PC is running Opensuse Leap 15.3 and is connected over eth0 to the router. The HP printer is setup and running in the house, but I can't connect to it from my PC despite both being on the same network. I have the IP address which I have locked to the device.
I have tried an Opensuse forum but find the advice there beyond my knowledge and expertise, and it's a long drawn out process following the thread. It seems that Opensuse adds a firewall on installation which is particularly hard, so I need to open some ports to access the printer. However, I am finding the instructions difficult to follow.
So I'm appealing to STW. Can anyone provide relatively simple instructions? For info, neither YAST nor CUPS seems able to recognise the printer.
Dunno, but for starters have you tried AirPrint from a smartphone or other device to make sure the printer end of things is ok?
we can print to the machine from tablets and smartphones in the house. It's just my PC which can't.
Might be worth trying some different flavours of Linux.. Some are more user friendly than others.
I've found Mint and Ubuntu to be pretty good from a newbie perspective.. And you can fire them up from a USB stick to trial them out.
I can't help with the printer though... Printers are arsholes at the best of times!
Especially , in my experience, with Linux. I've been using it for 20 years and every time I install a new version or distribution it always seems to be printers that cause problems.
We can send man to the moon, but not a document to the printer!
A modern printer like that should support driverless printing (so mobiles can print to it) which modern Linuxes also support. For it to work your computer needs to be able to scan the network using dns or mdns, part of the avahi package, and to have CUPS installed and have the cups-browsed service (part of cups, which makes use of dns/mdns) running.
https://doc.opensuse.org/documentation/leap/startup/html/book-startup/cha-print.html#sec-print-net
From the above at section 7.7.1 you do need to make a hole in your local firewall for this unfortunately. It might be possible to turn off the firewall completely for testing purposes then, if CUPS detects the printer, you might be encocuraged to do the firewall fiddling?
I found setting up my recently purchased Canon printer very easy via the CUPS web interface, but I am not running opensuse, or anything like it (Gentoo wierdo here) so can't help with details.
avahi and cups installed. maybe need to look at cps-browsed service. Not at the machine just now, will check later.
sudo systemctl stop firewalld
At a guess, the above might disable the firewall, and replacing start with stop (or rebooting) would enable it.
ETA and
systemctl
would list all running services, in which cups-browsed should show up, or if it is too long and confusint
systemctl | grep cups
will weed the output to lines containing cups.
BTW I am not entirely sure cups-browsed is needed on the client, but I rather think it is.
ETA2 there is an element of guesswork on my part here as this is based on the systemd runtime control system that OpenSuse uses, whereas I use OpenRC.
Install Windows? (Sorry, I couldn't resist.)
Can you set up another PC as a print spooler maybe?
What does it do that the Epson doesn't?
Does the printer work if plugged-in direct?
Mine is a pain, it's easier to send the document to a windows PC, sorry, but to do anything else is time I'll never get back 🙂
Update time:
What does it do that the Epson doesn’t?
Epson printer is over 5 years old and regularly has cartridge problems.
shows cups-browsed.service is running
makes no difference, still can't see the printer.
Hmmm. If you know the ip address, can you ping the printer?
and if you can, or indeed can't
avahi-browse -at should list a load of devices that use dns/mdns including your printer. Or not.
avahi-browse -at - command not available
ping seems to work
Tried nmap to identify open ports:
mike@linux:~> nmap 192.168.178.43
Starting Nmap 7.70 ( https://nmap.org ) at 2024-05-02 10:49 BST
Nmap scan report for HP021FD6.fritz.box (192.168.178.43)
Host is up (0.0026s latency).
Not shown: 995 closed ports
PORT STATE SERVICE
80/tcp open http
443/tcp open https
631/tcp open ipp
8080/tcp open http-proxy
9100/tcp open jetdirect
Nmap done: 1 IP address (1 host up) scanned in 6.56 seconds
Appears to recognise the printer HPO21FD6 on that IP address.
Well it appears to be open for ipp, Zyou could tyr setting it up as an ipp printer via the cups web interface. But I have always found that stuff a bit miss and hit, but genarally a hit after a few misses.
If you have HP LIP installed you should be able to run the HP setup wizard, think the command is just 'hp-setup'
eta- in fact there are suse specific instructions on the docs
https://developers.hp.com/hp-linux-imaging-and-printing/howtos/install
I can run hp-setup but then need to temporarily connect by USB to start the process. The printer was not supplied with a cable so i will have to buy one. Then I can try again but I would be concerned that the PC is outside the range of the router wifi. That will be problem for another day!
Also appears avahi and/or avahi-utils are not installed, you could check this.
mikejdFull Member
Been a while since I've done it but IIRC the options are USB, network, or wireless with USB. You should be able to do the network option. I *think* you can then let it search the network or give it an IP address if it doesn't find it. But like I said, been a while. i may be mixing it up with the windows installer.
avahi-utils wasn't installed, is now.
avahi-browse -at lists both Epson printer and HP 2820 printer
Well you know the IP address of the printer then? You should be able to just run
hp-setup 123.45.67.89
Just give up. Or read the entire Arch Linux wikipedia - it is actually a very good resource even if you don't use Arch.
Just to return to this for a last time:
I have connected the printer to the router by the USB port. The printer is connected to the wifi network wih the IP address 192.168.187.43. So both the PC and the printer are directly connected to the same network. Printer Information Report says connected to the network, IP address as above, signal strength is excellent, connected to internet.
Run hp-setup and hp-setup 192.168.178.43. No printer detected. Yast, CUPS no printer detected. HP Smart app shows the printer but not available.
I think it's time to give up!
