Lighting - key to g...
[Closed] Lighting - key to get into the bugger ...
5 Users
Bulb has gone but cover removal needs a triangular key - any idea where I could get one and are they all one size ??
Local (small-ish) B&Q didn`t have a clue ....
Posted : 22/09/2013 3:36 pm
 JAG
Get a bit of soft Pine wood, a chunk off a pallet is fine.
Get a sharp knife and carve the end of the wood into a triangular shape that fits.
It takes a few seconds but I've never found an official tool and this approach always work and costs almost nothing.
Posted : 22/09/2013 3:48 pm
Correctly sized screw driver will do job as well
Posted : 22/09/2013 3:51 pm
If it's like the triangular thingy on my outside gas meter, which is about ten mm corner to flat, there's a tool I have. It does radiator vents and stop-taps too. This looks similar...
http://www.screwfix.com/p/plumbing-tools-by-rothenberger-4-way-radiator-services-cabinet-key/84379
Posted : 22/09/2013 4:42 pm
As above, you must have a flat screwdriver/allen key that will fit? Only other suggestion is one of those four head radiator bleed tools (shaped like an X) I got one of those in B&Q...sure one or two of the ends is triangular
(Oh yes, just like the post above from 10 minutes ago!)
Posted : 22/09/2013 4:57 pm
