Lighting experts ne...
[Closed] Lighting experts needed (12v battery question)
5 Users
I'm making a fancy dress costume for a couple of festivals coming up.. will include a few 12v LED strips, like [url= http://cgi.ebay.co.uk/2-x-48-LED-Linear-Flexible-Strip-Car-Lights-48cm-White-/120612584303?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c1511fb6f ]this[/url]..
My question is regarding power supplies.. need a portable 12v battery which will last for approx 4 hours to approx 5 or 6 of these led strips.
I was thinking of 8xAA batteries in a battery holder (will this be enough to power it?) - or is there a better option?
Just want something fairly small and reliable that'll keep the LEDs lit - cheers in advance
Posted : 17/03/2011 12:30 pm
Or maybe something like [url= http://cgi.ebay.co.uk/Portable-12V-Li-ion-Rechargeable-Battery-Pack-4800mAh-/170535032613?pt=LH_DefaultDomain_0&hash=item27b4ae1725 ]this?[/url]
Any thoughts, cos I don't know much about electronics?!
Posted : 17/03/2011 12:48 pm
I can't see a power figure anywhere on the lights but 8AAs should do just fine (you'd need to find out/measure/test the power needed to be sure).
I wouldn't use the lithium pack to power flamable costumes personally. Actually I'd include a fire extinguisher in the finished ensemble for AAs...
Posted : 17/03/2011 12:51 pm
without knowing the rating of the strips then it's difficult to know.
those cheap Chinese LEDs don't tent to be terribly efficient.
I'd start with 8 (non rechargeable) high capacity AAs and see how you get on.
If you use rechargeables you'll need 9 cells i think as they are lower voltage
Posted : 17/03/2011 12:55 pm
Thanks guys - much appreciated - will give it a go with the AAs and see if they last long enough.
Re: fire risk - alcohol will be involved, so no doubt I'll be fine!
Posted : 17/03/2011 1:00 pm
If you use AAs then at least you can take a spare set with you if you need more power. With that battery pack you'll need to plug yourself into the wall for an hour or so.
Posted : 17/03/2011 1:03 pm
looking at similar products they seem to be about 6mA per LED so that would make each strip about 290mA.
6 strips gives you 1.74A
4 hours means you'll need about 7 Amp Hours
I [i]think]'[/i] that standard AA batteries have a capacity of about 2000mAH
my problem is now working out a multi cell calculations. i think that at 12V and 8 cells the capacity will still be 2000mAH only at 12V not 1.5V
in this case i'd expect the batteries to last about an hour and three quarters
I may be very very wrong though and the LEDs may turn off before full discharge as the voltage will drop
Posted : 17/03/2011 1:08 pm
Thanks Michael, much appreciated! I might tone it down a little and use 24 led light strips, which should hopefully give me the extra run time. 2 battery packs should then cover it hopefully..
Thanks again guys.. will no doubt be posting again in a while when I'm having problems!
Joey
Posted : 17/03/2011 1:23 pm
You might find your LED's will run from 9V batteries.
Maplin also stock Slimline 12v lead acid batteries for emergency exit signs. Stored in a bum bag one of these would run your LED's for Days!
Electroluminescent wire?
Posted : 17/03/2011 7:13 pm
No worries then. Take a camera on the off chance 😉
Posted : 17/03/2011 7:17 pm
Here's the end product. Still in one piece, and didn't catch fire. Next stop 2000 Trees Festival.
Posted : 02/05/2011 10:30 am
