They are remarkably small and portable.
Thought I'd start this thread to solicit mockery from people with proper MIG machines and as a support group for anyone else who'd succumbed to the temptation of the middle isle this week
Look the picture even shows it doing it al itself, how hard can this be!
Next stop, Toolstation for some gauntlets and a proper mask. Lidl did have some but I figured between my technique and flux core wire that the amount of splatter was going to make a mask with replaceable glass important!
I did like the LIDL mask, for the price, iirc it had a large viewing are, one had an LED to see better. BUT you have a plastic screen over the glass so you dont destroy the element, and theres probably spares in the box, and easy to cut others to size
I didnt know you can get inverter MIGs these days, if thats what it is.
Considering buying one myself but >150A and dont want gasless or flux core
Yea, I'm not under any illusions that it'll do a great job, and will be out of it's depth on anything heavy.
But I've had a so many times of times in the past year working on cars / bikes / pizza ovens / gates where I've thought that if I could just tac this together it would be so much easier than trying to bracket/sleeve/clamp/bolt or whatever it is I'm doing instead.
Watched a few youtube videos of people managing to do car bodywork with it set to minimum, so if I can get in anyway half decent with it I might attempt a rusty mx5 or something😂
whatever you get youll need lots of practice anyway and once youve got the technique you can get something bigger if need be. But it will be frustrating to begin with
I think I'll purchase a handheld drill style welder when they eventually appear in the middle of Lidl.
I bought a piller drill from Lidl and it is pretty good.
it’s great practising on scrap metal on a bench, but then you go to work underneath a car and it goes back to square 1
I opened this thread thinking god no, not another far right Dutch politician
a lot of which is getting a good earth, and cleaning the metal to weld on. Consider that old metal will be thinner and rusty, you want no gaps, and welding on your back, sideways, vertical, etc without room to move your head and arms makes a massive difference to your proficiency
Hmm I haven’t bought the LIDL Welder but I do have a lot of welding experience and I own a.n.other cheap MIG Welder.
My biggest problem is the electronics on the welder - my welder seems to work really well for the first 5 minutes of welding. After that the arc becomes unstable and difficult to weld with. If I leave it to cool off between 5 minute welding sessions it’s fine :o)
Bear that in mind with yours and have fun ;o)
Does it have the option to connect a gas bottle to it and use 'normal' MIG wire? If so it could be a good buy. I'm afraid 'gasless' MIG is a bit crap, however good your technique!
The pain of Mig spatter fizzing in your ear..........Mig welding only exists to highten the Zen experience of Tig welding.
@thisisnotaspoon don't you own an MG Midget? I thought a MIG welder came in the toolkit for them with the sparkplug spanner ;-). (Speaking as a former Midget daily driver.)
As others have said, practice, practice, practice, and then you'll start working on the car and it'll all go out the window.
That said, I "invested" in what I thought was a good SIP machine, never got on with it and generally hated the whole thing. A second hand TIG machine was actually much better for what I was trying to do (Mostly fixing 70's MGs). Then I found that the supposedly good SIP machines were widely hated by just about everyone as the wire feed is inconsistent and can't be realistically made to work nicely. I've now got a Machine Mart cheapie and it's 10x better than the supposedly semi pro machine I thought I was better off with. One doesn't always get what you pay for.
I looked at getting the parkside one and even went so far as to watch some vids.
Did find one of a professional welder using the parkside one to construct a fence in heavy steel bar.
He rated it as acceptable.
Maybe not if youre into welding or its structural or critical, but just for fixing the lawnmower or garden gate, it would good to have around.
Or use it as a latest toy and play with it till the latest toy buzz wears off/you burn yourself/set fire to the shed.
I do, I had to drive back to the office to pick up the welder as I'd ridden in.
Having the welder in the car felt like a circle of life moment 😂.
Yea, I found these two. No idea how competent they are as welders but in terms of use in do need to modify a bike trailer and do have the MG!
Also found another video where the guy showed a more general overview of the process with one and how to get a decent weld, and also how to get something that looks aesthetically at least nearer a nice fillet of stacked 5p's, but then showed it gave much poorer penetration than the first technique.
Can’t see how it can be worse than my crappy Arc welder from Makro 20 years ago.
With care and patience it can weld old german car panels.
It absolutely would just blow holes in a modern car panels.
I learnt Arc and oxyacetylene at college 35 years ago. Never tried MIG or TIG, I’ve heard they’re much easier, so tempted by the Lidl welder myself.
Yep, I need to take my screwfix grinder apart and fix that too, think the switch or a connection is loose as it's become "shake to start" which is sub optimal for something that could remove limbs 😂
i love a welder - wonder if my lidl has one in? scenic route home for me tonight!
most old car bodywork needs to be done with as low a setting as possible anyway so low power is good. Alot of teh larger machines dont go low enough to not just burn through everythng.
I'm sure there is a lesson here somewhere. As my dad used to say, buy cheap, buy twice.
under appreciated comment from kormoran.
Ohhh what is it?
Hate to break it to you, opinions are the cheapest commodities on earth.
Well I didn't expect to buy a welder at lunchtime. But that's what I've done.
I have a job for it that I've been putting off though 👍
I believe with Mig, if you don't use it for a while you'll need to bin any remaining wire and buy a new spool. It rusts ever so slightly and stops feeding reliably.
It's this sort of thing that makes having a welder in the shed for the 'I'll just tackle that' moment, not so handy as you might hope.
NeilNeville - seems to be OK with me? i suppose it depends on how long you leave it. I own a t2 baywindow (muchos rust!) so i leave it about 6 months between uses (winter!). I may howvere begin to wrap the spool in clingfilm as it kinda makes sense it would degrade. my garage isnt that damp so maybe i`ve been lucky.
better to keep big spools indoors if not being used, but i guess it depends how good the feeder spools/motor are
I know that the chinese may make several different qualities of the same item, so you may choose to suit your needs, so a bargain may be not a bargain, if youre thinkin you have a lifes' supply of brake pads, and some money left over.
Lidl Welders... far superior to the big hairy types when you need to get into a tight space.
VanHalen, maybe some welders or wires are better? Iirc, I read it on a similar thread here and it made sense. 30 years ago I learnt to drive in a ratty old mk1 fiesta and my brother and I were forever chasing rust so we bought a cheap mig, Clarke iirc. Remember after a while the wire feed became trouble, the wire seemed to jam. Very frustrating and we didn't know why. Now I do.
I hadn't used the welder in 25 years so when mum moved and we cleared the garage i gave it away to a neighbour, but told him, if you user it, buy a fresh spool!
If i still had it i would take the spool out to store it inside between uses.
Yea, I read similar, take the spool out (careful not to let it unwind) and store in a sealed tupperware.
The spools are only £2.99 though so it's not really a big deal to just buy a fresh one if there's a big job to do. Could be annoying if it was just to tack something quickly.
I've no real inkling of how far 0.45kg of wire goes though? Based on a 4mm triangular fillet that would be almost 700m, I'm guessing by the time the gas has vaporized and splattered a lot of metal with it, that it's a lot less!
The wire will go a long way.
Yeah, like assholes, everybody’s got one! 🙃
Head down your local motorbike garage and ask for scrap from their bin. Car brake discs are good to practice on. Car panels are not the place to start as you will just blow holes in the metal.
Your welding will be crap and weak to begin with but that shouldn't stop you enjoying it and making stuff. Go for it.
https://photos.app.goo.gl/WdH1eijSsb2BgDcP7
