libre office spread...
[Closed] libre office spreadsheet help!
4 Users
I have a load of dates in a row, but libre office thinks they are text, so when I change format to date it adds a ` character in front of the dates and so it ignores the date format, and I cannot sort by date order.
If I copy the dates into a text field and back again it just repeats the bloody operation.
Help!
Posted : 26/07/2013 11:27 am
Just a guess but are you using the right seperator. I'm not familiar with Libre office, but it might need a / instead of a - or something like that...
Posted : 26/07/2013 11:46 am
If it's LibreOffice actually inserting the tick then I've seen this before. Unfortunately I couldn't find the correct answer so cut/paste into a file and used sed to remove them before cutting/pasting back in (with the cells already formatted to date).
Edit: Just seen you've got them in a row, not column. If you try the above you might need to export as csv, sed out the ticks, then re-import as csv and cut/paste into the right place. Bit long winded but if it's a one off it might be faster than working out how to do it properly.
Posted : 26/07/2013 12:36 pm
Can you leave that column as it is and create another one that uses whatever the equivalent is of a date(string, dateformat) function? Then sort on the new row..?
Edit - I didn't remember I had LibreOffice installed - try =DATEVALUE(<string cell>) - that will give you a number and then you can format this as a date. Actually, even VALUE(text) seems to work as well.
Posted : 26/07/2013 1:14 pm
euain, you are a gent, all sorted cheers.
Posted : 26/07/2013 1:22 pm
