The charging socket on my laptop took a bit of a bang and now the connection is a bit hit and miss.
Can the socket be replaced or is it goosed?
In other news, I have a clumsy 9 year old for sale.
You can take them to pieces & re-solder the connection but it's an arse of a job on the easy ones. Find a local repair shop (phone/tablet place not necessarily a computer shop) they'll have done hundreds of times, unless you enjoy taking stuff to bits & are handy with a soldering iron
As above. It'll be doable, but it probably won't be easy, it certainly won't be a 5 minute job and you'll need a fair skill with a soldering iron.
Mine needs doing and it looks like it's well hidden so plenty to remove hence it's needed doing for a few months ...
Get it done - loose connections generate heat and further melt/damage the connectors.
As said. It's doable but only if you're handy with a soldering iron, screwdriver and fingernails. I've done a few.
However sometimes (but probably not the OP's due to the knock) it's actually the plug that's become wonky somehow - the contacts inside the plug on mine are what's wobbly.
