Just dropped my sho...
[Closed] Just dropped my shockproof camera and it will.................
15 Users
not let me take pictures just comes up withwrite protect on the screen,but if I take the memory card out it will work any ideas?
Posted : 28/08/2012 3:53 pm
The SD card has a little slidey switch on it that Write Protects the card. It's got knocked on when you dropped it.
Slide it back and try again.
Posted : 28/08/2012 3:54 pm
The memory has a write portect tab on it which had been knocked on with the shock?
 Kit
Maybe it knocked the slidey write-protect thingy on the memory card?
Posted : 28/08/2012 3:55 pm
There is a little sliding tab on the memory card which activates the write-protect.......
Posted : 28/08/2012 3:59 pm
Have you checked the side of the card? There's a little write-protect tab there, apparently.
Perhaps that could be the problem.
Posted : 28/08/2012 4:00 pm
 grum
I don't know if anyone has mentioned this already, but on the card there is a little write-protect switch....
Posted : 28/08/2012 4:01 pm
Posted : 28/08/2012 4:04 pm
So, no-one knows? STW finally fails.
Posted : 28/08/2012 4:05 pm
Is it broken?
Posted : 28/08/2012 4:10 pm
 Kit
Maybe you need to replace the crown race... anyone know if postierich's shockproof camera comes with one?
Posted : 28/08/2012 4:12 pm
[img] [/img] [img] [/img]
Posted : 28/08/2012 4:13 pm
Happens a lot to mine. The tab was very loose. Finally got round to gluing the tab today as the superglue was right next to the PC while I downloaded some pics.
Posted : 28/08/2012 4:18 pm
Just 😆 at this thread!
Posted : 28/08/2012 5:01 pm
Eagerly awaiting the "help, my SD card won't eject" thread.
Posted : 28/08/2012 6:22 pm
Cougar - Member
So, no-one knows?
Posted : 28/08/2012 6:25 pm
It's broken and will never work again. Please send the old one to me - I collect broken things.
Posted : 28/08/2012 6:33 pm
 Bez
Maybe your memory card has Aids...?
Posted : 28/08/2012 7:14 pm
Did we get to the bottom of this??
I've been up all night worrying about it.
Posted : 29/08/2012 8:54 am
Do you have a small tab on the bottom that you could adjust, perhaps?
Posted : 29/08/2012 8:58 am
Thanks for all your responses!
Flicked the tab on the memory card and still no luck not got another to try!
Posted : 29/08/2012 3:06 pm
Oooooooh. That's not good.
If another card doesn't work then I'd suggested the little switch inside the camera that "reads" the position of that tab is jiggered.
Posted : 29/08/2012 3:15 pm
Internal Hamster failure ...
Posted : 29/08/2012 4:24 pm
