Just bought a van a...
[Closed] Just bought a van and it's already dead
58 Users
Ah mate, that's harsh. I hope the garage get it sorted for you. ☹️
Posted : 23/06/2020 6:32 pm
I phoned the mechanic from the side of the road in Rotherham and he dropped everything and came straight out with the trailer.
He plugged it in and there was an error code for the DPF. He said the switch for the DPF was reading as disconnected. It probably tried to kick in and do a regen after it heated up on the motorway. All seems well mechanically. The engine didn't sound like a biscuit tin full of marbles like it did last time.
So it's gone on the trailer back to the garage and he said he'll drop it off tomorrow when he's in Sheffield.
Hopefully it's just a few gremlins. I'd rather find them now than in the Alps.
Posted : 23/06/2020 6:38 pm
On my 2.0 tdci Kuga the DPS (differential pressure switch) went, BIG warning lights, limp mode, the works.
Simple swap out and all fixed 🙂 It promptly did a regen and all well since.
I strongly recommend getting to grips with Forscan, a free diagnostic thing you download. Combined with a Tunnelrat elm327 connector and you are all set for cheaps 🙂
Posted : 23/06/2020 7:49 pm
Update: He just called to let me know what the problem was. It looks like someone has recently replaced the vaporiser in the DPF but the fuse was blown.
New fuse fitted and 70% through a forced regen.
Hopefully tomorrow I can drive to somewhere and, all things being well, return home with no further disasters. Just to get one single complete journey under my belt.
I think it's going to take some time to fully trust this thing.
Posted : 23/06/2020 7:53 pm
Trip to Barnard castle ? 😉
Posted : 23/06/2020 7:59 pm
Pub for a well earned beer? With a friend who can drive you home in it?
Posted : 23/06/2020 8:04 pm
That thing is really going to have to work hard to earn your trust now.
Posted : 23/06/2020 8:26 pm
Fingers crossed for you op.
Posted : 23/06/2020 9:09 pm
A minor problem like that after an engine swap and something they wouldn't have found on a 5 mile test drive, don't worry about it. If it'll run trouble free for a week or two the chances are it'll be fine for the trip to Morzine. IME French garages are every bit as good as UK ones and if the worst comes to the worst you get a free trip home on a flat bed - I assume you'll have breakdown cover.
Posted : 23/06/2020 9:19 pm
The person who did the swap sounds amazing. You no longer really expect people to care and it seems like they do
Posted : 23/06/2020 9:36 pm
It happens his response i think shows his ethics
Dont let it worry you. Number of motor rebuild I've done that then throw a spurious error up on a good 1st runs nuts
Posted : 23/06/2020 9:40 pm
That's good news now op.
Posted : 23/06/2020 10:22 pm
I just completed my first full journey! We just did a 10 mile loop, dipping into the Peak and back. I wanted to stop somewhere for a victory picture but everywhere is absolutely rammed as always.
Once I'd stopped stressing out I remembered why I bought it. It's clean and presentable, the cabin looks brand new and it's not a bad place to sit. It's many levels of niceness above the average Connect you see flying around. It just needs some big comfy Mondeo seats and it's finished. Even the mrs. is back on board.
The problem was literally just a blown fuse. He said the DPF looks brand new. Fair play to him for taking it back and fixing it and then dropping it off first thing this morning even though it's something that definitely wasn't his fault.
Hopefully that's the end of that. If your Transit Connect ever blows up I can recommend someone.
Posted : 24/06/2020 5:22 pm
Is the fuse the correct size? A brand new DPF must have a tale to tell? I am an overthinker...
Posted : 24/06/2020 5:34 pm
The lad who did the swap sounds as if he knows his stuff rather than just being able to work spanners. A rare thing these days and worth his weight in gold.
Posted : 24/06/2020 6:07 pm
THREAD RESURRECTION
I just remembered about this thread and thought I'd stick in an update as my last post (8 months ago) certainly wasn't the start of a trouble free relationship.
After a few carefree local drives the power went away. I was guessing the turbo had died as it was running but with absolutely no enthusiasm. With lots of big hills between me and home it was a pretty slow and stressful drive back. So I was driving along, barely moving, waiting for the death rattle and then, with the sound of a gunshot, the small chip in my windscreen turned into a full width crack. I papped my pants but I was still moving. Inching, slowly homewards.
So, I had a new heated windscreen fitted for £140 and then it went to a garage who couldn't fix the boost problem. They had to call in an electrician to replace the actuator. At this point I've given up Googling things to try and understand the problem so I took their word for it. £400 later It's back on the road.
Then it was MOT time. It got through with just advisories for worn brakes. If I keep putting it in the garage it'll bankrupt me so I ordered a full set of discs and pads and spent the day on my back wrestling with rusty caliper bolts, skinning my knuckles and swearing at it. Now I have all new brakes which feel mint.
I'm trying to use it a couple of times a week to make sure it starts so we drove it to Tesco. On returning to the van there's a huge pool of fresh liquid underneath it. Yes, the filler hose has perished and is leaking go-juice from both ends. We're only a couple of miles away from home so cue another nerve wracking journey.
A £20 pipe and an hours work and it's fixed. As far as I know, that's everything that needed to be fixed, fixed. There's currently nothing wrong with it.
So far I've got over 5 grand in my 3 grand van. It was supposed to go to Morzine in July. Would you dare?
And finally, we're having our first child in June. Which means that any time we want to actually use the van, by throwing the bikes in and going away for a weekend, my stupid 2 seater van is completely useless. Perfect.
Posted : 04/03/2021 2:12 pm
If it has sliding side doors turn it into a crew van get some seats off ebay and you can buy a window kits with the glue. Measure 20 times and cut once when cutting out the metal for the windows. That's what I did to my Citroen Dispatch. I picked up the factory seats which matched up with the reinforcement in the floor. A few large bolts and some carpet sorted it. Had to remove the bulkhead behind the driver. Need to fit seat belts which came with the seats.
Vans can be expensive mine is having an engine replacement at present after it seized before christmas. Oil rarely needed topping up approx every 8 months and I had topped it up the day before but hadn't changed it for a while. Cambelt had been changed. Will probably end up with a bill for £2.5K. The power steering pump went on my old van luckily when we had got to our camp site in Lake Garda. The replacement Pumpi Libre cost around £1200. I've had two EGR valve failures (old van) leaving me stranded on the side of the motorway. I'm contemplating returning to a people carrier but the van is handy.
<div class="ms-editor-squiggler" style="color: initial; font: initial; font-feature-settings: initial; font-kerning: initial; font-optical-sizing: initial; font-variation-settings: initial; forced-color-adjust: initial; text-orientation: initial; text-rendering: initial; -webkit-font-smoothing: initial; -webkit-locale: initial; -webkit-text-orientation: initial; -webkit-writing-mode: initial; writing-mode: initial; zoom: initial; place-content: initial; place-items: initial; place-self: initial; alignment-baseline: initial; animation: initial; appearance: initial; aspect-ratio: initial; backdrop-filter: initial; backface-visibility: initial; background: initial; background-blend-mode: initial; baseline-shift: initial; block-size: initial; border-block: initial; border: initial; border-radius: initial; border-collapse: initial; border-inline: initial; inset: initial; box-shadow: initial; box-sizing: initial; break-after: initial; break-before: initial; break-inside: initial; buffered-rendering: initial; caption-side: initial; caret-color: initial; clear: initial; clip: initial; clip-path: initial; clip-rule: initial; color-interpolation: initial; color-interpolation-filters: initial; color-rendering: initial; color-scheme: initial; columns: initial; column-fill: initial; gap: initial; column-rule: initial; column-span: initial; contain: initial; contain-intrinsic-size: initial; content: initial; content-visibility: initial; counter-increment: initial; counter-reset: initial; counter-set: initial; cursor: initial; cx: initial; cy: initial; d: initial; display: block; dominant-baseline: initial; empty-cells: initial; fill: initial; fill-opacity: initial; fill-rule: initial; filter: initial; flex: initial; flex-flow: initial; float: initial; flood-color: initial; flood-opacity: initial; grid: initial; grid-area: initial; height: 0px; hyphens: initial; image-orientation: initial; image-rendering: initial; inline-size: initial; inset-block: initial; inset-inline: initial; isolation: initial; letter-spacing: initial; lighting-color: initial; line-break: initial; list-style: initial; margin-block: initial; margin: initial; margin-inline: initial; marker: initial; mask: initial; mask-type: initial; max-block-size: initial; max-height: initial; max-inline-size: initial; max-width: initial; min-block-size: initial; min-height: initial; min-inline-size: initial; min-width: initial; mix-blend-mode: initial; object-fit: initial; object-position: initial; offset: initial; opacity: initial; order: initial; origin-trial-test-property: initial; orphans: initial; outline: initial; outline-offset: initial; overflow-anchor: initial; overflow-wrap: initial; overflow: initial; overscroll-behavior-block: initial; overscroll-behavior-inline: initial; overscroll-behavior: initial; padding-block: initial; padding: initial; padding-inline: initial; page: initial; page-orientation: initial; paint-order: initial; perspective: initial; perspective-origin: initial; pointer-events: initial; position: initial; quotes: initial; r: initial; resize: initial; ruby-position: initial; rx: initial; ry: initial; scroll-behavior: initial; scroll-margin-block: initial; scroll-margin: initial; scroll-margin-inline: initial; scroll-padding-block: initial; scroll-padding: initial; scroll-padding-inline: initial; scroll-snap-align: initial; scroll-snap-stop: initial; scroll-snap-type: initial; shape-image-threshold: initial; shape-margin: initial; shape-outside: initial; shape-rendering: initial; size: initial; speak: initial; stop-color: initial; stop-opacity: initial; stroke: initial; stroke-dasharray: initial; stroke-dashoffset: initial; stroke-linecap: initial; stroke-linejoin: initial; stroke-miterlimit: initial; stroke-opacity: initial; stroke-width: initial; tab-size: initial; table-layout: initial; text-align: initial; text-align-last: initial; text-anchor: initial; text-combine-upright: initial; text-decoration: initial; text-decoration-skip-ink: initial; text-indent: initial; text-overflow: initial; text-shadow: initial; text-size-adjust: initial; text-transform: initial; text-underline-offset: initial; text-underline-position: initial; touch-action: initial; transform: initial; transform-box: initial; transform-origin: initial; transform-style: initial; transition: initial; user-select: initial; vector-effect: initial; vertical-align: initial; visibility: initial; -webkit-app-region: initial; border-spacing: initial; -webkit-border-image: initial; -webkit-box-align: initial; -webkit-box-decoration-break: initial; -webkit-box-direction: initial; -webkit-box-flex: initial; -webkit-box-ordinal-group: initial; -webkit-box-orient: initial; -webkit-box-pack: initial; -webkit-box-reflect: initial; -webkit-highlight: initial; -webkit-hyphenate-character: initial; -webkit-line-break: initial; -webkit-line-clamp: initial; -webkit-mask-box-image: initial; -webkit-mask: initial; -webkit-mask-composite: initial; -webkit-perspective-origin-x: initial; -webkit-perspective-origin-y: initial; -webkit-print-color-adjust: initial; -webkit-rtl-ordering: initial; -webkit-ruby-position: initial; -webkit-tap-highlight-color: initial; -webkit-text-combine: initial; -webkit-text-decorations-in-effect: initial; -webkit-text-emphasis: initial; -webkit-text-emphasis-position: initial; -webkit-text-fill-color: initial; -webkit-text-security: initial; -webkit-text-stroke: initial; -webkit-transform-origin-x: initial; -webkit-transform-origin-y: initial; -webkit-transform-origin-z: initial; -webkit-user-drag: initial; -webkit-user-modify: initial; white-space: initial; widows: initial; width: initial; will-change: initial; word-break: initial; word-spacing: initial; x: initial; y: initial; z-index: initial;"></div>
Posted : 04/03/2021 5:04 pm
Not sure where that extra wording has come from cant delete it.
Posted : 04/03/2021 5:11 pm
Van prices are really strong right now Tom. have a look on WBAC for an idea of how silly. I'd be tempted to flog it. Or possibly burn it! Congrats to you both BTW.
Posted : 04/03/2021 5:24 pm
I'm considering this, it's supposed to be quite easy. I've got 2 sliding doors and I've already cut the roof to fit a skylight which was quite straight forward.
Van prices are really strong right now Tom. have a look on WBAC for an idea of how silly. I’d be tempted to flog it. Or possibly burn it! Congrats to you both BTW.
Thanks, I'm actually looking forward to it! I would love nothing more than to sell it and see it drive out of sight for the last time. But then, I still kind of need a van and I'd be stuck paying inflated prices for a replacement. I might advertise it on Facebook because it's free and see if I get any serious offers.
Posted : 05/03/2021 12:51 pm
leaking go-juice
and
must be connected?
Commiserations on the van, congratulations on the kid. Soon you'll have loads of other things to worry about too. My advice would be sell the van and put the money towards a sensible estate car.
Posted : 05/03/2021 1:16 pm
I would love to swap it for an Octavia or Volvo but at the start of lockdown I bought a YZ125. My first ever MX bike and I haven't had a chance to ride it yet due to lockdown. So ideally I'd need something like a regular size Tranny with a row of middle seats. Just until I've scratched my lifelong motocross itch, or broken my first bone. Then I'm cashing out and going family wagon all the way.
Our 'decent vehicle' budget is currently tied up in a 3 door Fiesta. Definitely would have looked at the Focus if I'd known what was coming! It wasn't an accident, but as soon as we started trying the deed was done. At least I know I'm functional.
Posted : 05/03/2021 1:27 pm
At least I know I’m functional
Really? At least you know she's functional.
Sorry, couldn't resist.
Congrats and all that... 😉
Posted : 05/03/2021 3:26 pm
If it has sliding side doors turn it into a crew van get some seats off ebay and you can buy a window kits with the glue. Measure 20 times and cut once when cutting out the metal for the windows. That’s what I did to my Citroen Dispatch. I picked up the factory seats which matched up with the reinforcement in the floor. A few large bolts and some carpet sorted it. Had to remove the bulkhead behind the driver. Need to fit seat belts which came with the seats.
Do crew seats come with ISOFIX? What's the side impact/crash safety rating in a van? How warm/cool is it in the back?
Some questions I'd be asking myself before I started down that road.
Also, **** shifting a crosser in the same load space as any passenger never mind your first born. Unless you mean a crew cab in which case the above still applies.
Posted : 05/03/2021 3:33 pm
At least you know you're both functional.
Congratulations, less so on the van front.
Don't get a focus estate. The rear seats aren't as spacious as you imagine. Two isofix child seats and I now have an uncomfortable driving position
Posted : 05/03/2021 3:35 pm
Er yeah, just wanted to add that this won't be happening.
Posted : 05/03/2021 4:11 pm
Hell, I've seen a 250 crosser in the back (and front px) of a Punto at Armthorpe. He got a round of applause when he separated the two!
Posted : 05/03/2021 7:20 pm
Er yeah, just wanted to add that this won’t be happening.
I did wonder.
Posted : 05/03/2021 7:38 pm
Can't you get a tow bar mounted carrier for the crosser?
Posted : 05/03/2021 11:04 pm
Very unlucky, whenever I buy a car always check the cambelt interval, or just have a kit pit on it to give you peace of mind .
Good luck in getting sorted
Posted : 06/03/2021 10:43 pm
Dear me read this thread from the start, sounds like triggers broom! Id say now is your chance to cash in. Stick it on here, at least we know what it's had done!
Buy an estate with a towbar and lash the MX to a trailer, or buy a Kombi van.
Posted : 06/03/2021 11:32 pm
 hugo
Congratulations!
(sod the van)
Posted : 07/03/2021 3:20 am
Page 2 / 2
