Does anything exist in the bike world for joining / extending a brake type cable? It's to relocate the door handle on the back doors of a van. It's cable operated and has the nipple on the handle end, so I need something that will take that end and then clamp to an extension cable with a nipple on the other end of that.
I can probably make something but was hoping to do it the easy way 🙂
Can't you just run a longer cable?
Sorry I don’t think I was totally clear, joining the cables isn’t the problem is making sure the outers butt up against something so they have something to pull on.
Like so
[url= https://i.ibb.co/cxPkj57/E4-B07-C75-32-CE-4816-9855-956-D81-B39-B6-C.jp g" target="_blank">https://i.ibb.co/cxPkj57/E4-B07-C75-32-CE-4816-9855-956-D81-B39-B6-C.jp g"/> [/img][/url]
[url= https://imgbb.com/ ]share images[/url]
Choc block?
Edited. Just seen your update. Can't think of a standard part to do that but it'll be easy to bodge
Can’t you just run a longer cable?
No, of course not, I need to make it extra complicated.
(I have no idea why I didn’t think of this. Obviously this is a much better idea 🤣).
I’ll investigate what type of cable I need!
Solderless nipple?
Tandem cables?
BMX Giro? 😀
It’s cable operated and has the nipple on the handle end, so I need something that will take that end and then clamp to an extension cable with a nipple on the other end of that.
Have a Google for "male nipple clamps". That's what you need...
Have a Google for “male nipple clamps”. That’s what you need…
Seconded.
