IT problems...
[Closed] IT problems...
8 Users
First it was teh telly, now the spacebar on my PC keyboard has stopped springing back. I took it off and it's manky underneath. I reckon it might be a good idea to take all the keys off and give the thing a good clean out.
I was thinking of putting them back in a more logical order - starting ABCDE at the top left. Has anyone done this and did it make your typing any quicker?
Posted : 18/12/2012 11:12 am
I think you mean "HE" problems now...
Posted : 18/12/2012 11:15 am
To do that you'll need to change the profile for your keyboard to map the right buttons to the right keys.
You probably won't find any increase in typing speed. In fact, I'd place a fair bet that changing yours keys to that sort of order would actually slow you down more. QWERTY keyboards are designed to place the most used keys within the easiest reach of your hand resting position to make typing faster.
Originally keyboards did use a different pattern (think back to typewriters here!), which was even faster to type with, but people were simply typing too quickly for their typewriters to keep up back then, this won't be an issue with a computer of course, just a quick bit of history 😉
Posted : 18/12/2012 11:19 am
Only if English is your first language....and for druidh...well....
Posted : 18/12/2012 11:20 am
I'll give you that, I was assuming that it is the OPs first language as this is a UK-based site 🙂
Posted : 18/12/2012 11:24 am
Ziol olf'z vgkaofu zgg vtss
Posted : 18/12/2012 11:28 am
QWERTY keyboards were designed to separate commonly used combinations of letters so that mechanical typewriters didn't jam. It's not a particularly efficient layout, but we're kinda stuck with it now.
The DVORAK layout is supposed to be the solution to this, but in *mumble* years in IT I don't think I've ever come across one.
Rearranging keys on a traditional keyboard is unworkable as they're all different pitches; you might have some success with a chicklet-style keyboard, but even then I can't really see a compelling reason to recommend it.
Posted : 18/12/2012 11:29 am
my Garmin car sat nav has an alphabetical order keyboard....
Its ****ing infuriating!
Cant recommend it 🙂
Posted : 18/12/2012 11:31 am
Bingo. Thats what I was trying to remember the name of.
Posted : 18/12/2012 11:36 am
QQQQQQQkui!! Viqz gkrtk rg zitn ug wqea of??
Posted : 18/12/2012 11:39 am
I can't remember the name of it but isn't there a keyboard pattern that's meant to be more efficient than the 'slow down the typist' qwerty arrangement i.e. vowels are central, z is half a mile away (unless you're americanized).
@Stoner very good
EDIT: Dang my ridiculously slow work internet, I'd written this days ago!*
*Possible truth error
Posted : 18/12/2012 11:40 am
Do it, rearrange it.. It's Xmas and we're all in Holiday mode anywhoo's..
Wot cud go rong.
Posted : 18/12/2012 11:43 am
Here you go, problem solved. You'll be rapid on this.
Bit of a myth that, as someone said above, the arrangement was designed to separate common combinations of letters, rather than slow down the overall speed of the typist.
Posted : 18/12/2012 11:46 am
Nothing screams cutting edge technology more than naming your user interface device MAL-TRON.
