Looking for a search tool that I can put paths to several server locations in.
Eg: need to find a file, means I have to browse to, & search, up to 5-6 different locations. Is there a tool that I can put all the locations in & have it search each location automatically ?
Cheers.
windows search, just stick a semi-colon between locations?
"Agent Ransack" is worth a look..(you can save criteria including multiple directories)
Do people just like having extra software knocking around that's not needed ? 😉
I assume you're talking windows?
coffeeking...it wont let me use the locations joined by the ";".
Tells me its not a valid folder... 😐
fubar, Agent Ransacker works a treat. IT dept will probably remove it thought. 🙁
Show me what you're entering in the search location box
To save searches:
Let search complete.
File>save search
This saves the criteria as a shortcut to wherever you like. just double click the icon to open the search box again with the same criteria specified.
I suspect that ck's approach may need you to have mapped the drives to letters first. I'm only guessing though.
Yep, sorry, it does require mapping but that's quick and "permanent" once done.
Eg:-
\\xxxxxxxx6\cad\library; \\xxxxxx1\tech\DWG\Product\Actuators
maybe geoffj is right, & they need to be mapped drives.
Yup, geoff is correct, I'd forgotten windows search wasn't UNC compatible; map them all to drives each (with reconnect at logon) and then just enter the drive letters "c:\;d:\" etc. Then do the file-save search and save it to your desktop or wherever for future rapid searches.
