I seem to remember reading something about being able to withdraw money if under duress? Security would be notified or something?? Cheers T
Yes there is
Edit:
Is that the urban myth about putting your PIN in the machine backwards and the police being notified ?
Chuckle at honeybadger.
OP - I don't think so. Massive security flaw if so, and I've never been told about it despite owning about 8 C&P cards so if it's a desired feature it's not a very desired one cos they don't tell you about it.
It's complete rubbish
My pin is 1441
Nat West & RBS accounts can give you an 8 digit pin if you have lost your cards.
Do you mean this ?
http://www.bbc.co.uk/news/business-19857243
My pin is 1441
You'll explode any minute.
[url= http://www.crimestoppers-uk.org/fraud/types-of-fraud/common-scams/atm-pin-number-reversal-hoax-email ]http://www.crimestoppers-uk.org/fraud/types-of-fraud/common-scams/atm-pin-number-reversal-hoax-email[/url]
This was doing the rounds on faceache.
If it was the case, why wouldn't they publicise it a bit more. You know, tell you when you get your new card etc. I don't see why it would be a big secret.
Would be a good idea, similar to how TrueCrypt gives you a password to divulge if you're forced to, but that doesn't show your real data. Obviously it'd have to be unique to each person and not just your PIN backwards...
Really? How many people do you know who have been forced to withdraw a whole £200 from a cashpoint at knifepoint?
1
The 2 most common PIN verification algorithms are Visa PVV and IBM 3624. The Visa PVV algorithm is not reversible - you can't derive a PIN from the PVV. The IBM 3624 algorithm calculates a "natural PIN". If you want to select a different PIN it's done as an offset from the natural PIN.
In all cases the calculations are done in a hardware security module, not the main host computer.
The reverse PIN could be identified for IBM DES in the HSM - weak PINs are identified that way. It's not practical for Visa PVV. In any case, it has to be done in the HSM.
To further complicate it, many UK banks have "tweaks" to the standard algorithms or use something completely different.
It's not referenced in the Visa, MasterCard or Link documentation.
It's theoretically possible (at least for IBM 3624) but no one does it.
If you're being robbed at knife point give them your cards, PIN, whatever. Cash can be replaced.
As has been said above, Natwest can give people a code to enter into a cashpoint to get at funds if you have lost your card. It's a one off thing, and you can withdraw upto £300...
I never knew this existed until the other half lost her card and she was offered it when she phoned up to report it.
As has been said above, Natwest can give people a code to enter into a cashpoint to get at funds if you have lost your card. It's a one off thing, and you can withdraw upto £300...I never knew this existed until the other half lost her card and she was offered it when she phoned up to report it.
Gets advertised on telly quite often...
Send me your card and the PIN (aka PIN number number).
I'll do a quick check to make sure that it's up to date in terms of security settings.
#noneedtothankme
CZ - that'll explain why I'd not heard of it before then! 🙂
Everyone's PIN is the same anyway.
It's very smart. I mean, if you steal someone elses card the last PIN you'll try is your own and it saves buying a load of fancy HSM equipment.
No one personally, but that's not to say it doesn't happen. Anyway, how often is happens doesn't make it a bad idea.
What makes it a good idea?
You key in your special code, the machine says "sorry, you've no money", the assailant goes "you've just keyed in your special code, haven't you" and kills you in the face.
Any organisation giving out advice for people faced with armed robbers that isn't "just save yourself by giving them the money" is going to have to have a pretty robust alternative.
Maybe an 'Acid' PIN is needed. you put in the secondary PIN, move sidewards to allow the crim to grab all your loot and then he gets sprayed with acid.
There is no way that idea could go wrong.
Alternatively the machine sends out an immediate alarm signal and gives out marked notes.
This.
This would be even better.
I think it would be better if entering the special code triggered a series of events including a boot on a stick kicking a road sign and a man high diving into a bath tub culminating in a sturdy cage descending onto the culprit.
*This is entirely my own idea and any similarity to a rodent themed board game is wholly coincidental*
To who? What's that going to do? Reckon the police are going to get there before the perp leaves?
Who'll be checking for those marks? And if someone finds some, then what? How hard will it be to launder a hundred quid? "Excuse me sir, this tenner is marked, where did you get it from?" - "Christ knows, they all look the same to me."
Boxing glove on an spring.
