Is the Earth heavie...
[Closed] Is the Earth heavier than it used to be?
32 Users
So I'm thinking, everything we create is sourced from the earths environment. At a molecular level, are we not replacing molecules with molecules, and despite the fact we've covered the place with heavy objects (buildings, cars and ikea furniture) that are made from "man made" materials, it's the same weight?
My secondary question related to the same subject, it's that if there is excess weight being placed on the planet, surely this has some impact on the Earths gravitational rotation and therefore via momentum, it's position on space. So, could it possible be that we could accidentally - by manufacture - cause the Earth to be slung out of orbit when it reaches some kind of critical mass to overcome the current principles?
What can I say, my mind works in mysterious ways.
Posted : 28/11/2013 9:51 pm
I reckon that it must be ever so slightly lighter. There is an awful lot of debris in space that we have put there that will not be balanced out by the amount of stuff we've brought back from space.
Doubt the numbers would have much effect on anything important though
Posted : 28/11/2013 9:53 pm
Dunno, but I am pounds lighter than I was a little while ago.
Posted : 28/11/2013 9:56 pm
click on google maps - look up your address and zoom out - we've barely made a mark on the planet in terms of built structures. Nothing we build adds to the weight of the planet as all the materials have been found on the planet - we've just moved them around.
A not inconsiderable amount of new material falls to earth all the time though - not just the more exciting big flaming meteors - but tons and tons of dust
Posted : 28/11/2013 9:57 pm
weighs less
we burn coal and oil and transform it into heat which does not weigh the same.
Then again we have loads of cattle so perhaps even?
Fly off the orbit - the sun is what holds us we can neither fly off nor break free however much me weigh.
We are losing some atmosphere into space - a very very tiny % of the overall mass of the Earth. Also we're collecting the odd meteorite and have been for 4.5 billion years so overall I would think we are gaining weight.
Posted : 28/11/2013 9:59 pm
There are more people though? Fewer dinosaurs.
You cant destroy matter, so its getting heavier due to meteorites etc. Weve only been putting stuff in space for 50 years.. ish?
it turns into CO2, water and ash which combined weigh exactly the same
The earth must be heavier, all old remains seem to be below ground. Therefore the earths diameter must be increasing so then getting heavier,
Posted : 28/11/2013 10:00 pm
Yes and no?
Isn't there a physics law to do with the conservation of mass?
The only way earth can get heavier is for shit to come from the outside.
so we gain a few lumps of space rock each year, making us heavier but we send shit into space making us lighter.
Posted : 28/11/2013 10:01 pm
 kevj
In the bigger scheme of things, it means f.a. The mass of the sun, the relative mass of our iron core has a very marginal effect on our orbit.
The balance of (very engineered to be light weight) man made satellites and additional mass due to impacts has a net gain /loss of ???
I dint know the figure, but it will be point 000 of a percentage.
Posted : 28/11/2013 10:05 pm
http://science.slashdot.org/story/12/02/02/1844205/
Hugh Pickens writes writes
"BBC recently asked physicist and Cambridge University professor Dave Ansell to draw up a balance sheet of the mass that's coming in to the earth, and the mass going out to find out if the earth is gaining or losing mass. By far the biggest contributor to the world's mass is the 40,000 tonnes of dust that is falling from space to Earth every year. 'The Earth is acting like a giant vacuum cleaner powered by gravity in space, pulling in particles of dust,' says Dr. Chris Smith. Another factor increasing the earth's mass is global warming which adds about 160 tonnes a year because as the temperature of the Earth goes up, energy is added to the system, so the mass must go up. On the minus side, at the very center of the Earth, within the inner core, there exists a sphere of uranium five mile in diameter which acts as a natural nuclear reactor so these nuclear reactions cause a loss of mass of about 16 tonnes per year."
(Read more, below.)
Pickens continues: "What about launching rockets and satellites into space, like Phobos-Grunt? Smith discounts this as the mass is negligible and most of it will fall back down to Earth again anyway. But by far the biggest factor in earth's weight loss are the 95,000 tonnes of hydrogen that escape from the atmosphere every year. 'The other very light gas this is happening to is helium and there is much less of that around, so it's about 1,600 tonnes a year of helium that we lose.' Taking all the factors into account, Smith reckons the Earth is getting about 50,000 tonnes lighter a year, which is just less than half the gross weight of the Costa Concordia, the Italian cruise liner that recently ran aground."
Posted : 28/11/2013 10:07 pm
It depends where in the earths life cycle it is. If it's in middle age then it's going to be heavier (probably a bit fatter round the equator). Then when it gets really old it's going to lose quite a lot of weight and go round a bit slower. Then it'll either go a bit wobbly or will stop going round altogether and just sit there.
Bit like a person really
Posted : 28/11/2013 10:10 pm
The moon has a greater effect than we do, and it's moving away at a very small rate. So it 50million years time the moon may leave our orbit and we'll get lost in space.
We may have made ourselves extinct by then though 😆
Posted : 28/11/2013 10:11 pm
I'm not sure if burning fossil fuels the products of combustion have the same mass as the original material or if you are converting mass into energy (I though you could only do this via nuclear fission or fusion). Where does the heat energy come from? Is it converted from the mass, or is the chemical reaction exothermic? I'm not sure of the chemistry here.
I've lost weight. But gravity feels the same. The planet must be heavier.
Posted : 28/11/2013 10:15 pm
Surely it's the wrong question, since 'weight' is a measurement derived by gravity then if the earth has increased in size and it's gravitational pull increased then the answer would be yes. Do things 'weigh' anything at the sub atomic level? That Higgs Boson, what does that weigh? And the God Particle if they're not the same thing?
 kevj
Thinking about this again, the earth is actually pretty ****ing massive. We humans think on a very scalar level.
A brick is quite heavy and big for one hand to pick up. The surface of the world is scarily massive.
Posted : 28/11/2013 10:16 pm
It sure is, but the fact that absolutely blows my mind is that despite is physical size and huge mass its mostly empty space - the space between the atoms. I remember reading a that if you took away the empty space between the atoms you can fit the mass of a battleship into a baseball! Though I understand this I just can't comprehend it.
Posted : 28/11/2013 10:21 pm
Not sure that's any more than an observation.
Posted : 28/11/2013 10:22 pm
Its both, the reaction is an exothermic chemical reaction but as energy is created mass must be lost, according to the famous equation though it is only a tiny amount of mass.
Posted : 28/11/2013 10:23 pm
this is covered by Karl
It's number 9 (@1.10) 🙂
Posted : 28/11/2013 10:58 pm
Sounds like one for Mr Monroe:
http://what-if.xkcd.com
Posted : 28/11/2013 11:02 pm
And as an extra mindmelter: https://mobile.twitter.com/whatifnumbers
Posted : 28/11/2013 11:05 pm
 Crag
Will having a big shit make a difference?
Posted : 29/11/2013 12:11 am
Remember also that helium (though it is very light) in the atmosphere is lost to space - and we have no way of acquiring more. In fact, helium could be the first element we run out of.
Posted : 29/11/2013 12:22 am
Crag
Only if the previous nights curry was so powerful to ensure your turd leaves at the 17,500mph required for escape velocity and it to become orbital.......
Posted : 29/11/2013 12:30 am
 poly
Is the conveyor belt moving?
Posted : 29/11/2013 12:36 am
 kevj
Kryton57 - Member
Erm, yes?
When read in conjunction with my previous post, it may make more sense. The net amount of mass gained/ lost, relative to the mass of the earth is tiny.
Posted : 29/11/2013 6:37 am
Conservation of mass only holds true for thermodynamically closed systems in which energy transfers can be assumed to be completely isolated from any external environment. Since the Earth operates on a larger scale of physics than most thermodynamic systems, the theories of conservation of mass (and by relation conservation of matter) must give way to relativity. As such and despite meteoritic gains, heat, light and gas radiated into space will slowly reduce the planets overall mass.
Posted : 29/11/2013 6:49 am
So, if the moon is distancing itself, then surely this is because the gravitational effect of the sun is weakening, or because when the Earth is between the Sun and the moon, the moons mass and momentum works in such a way as to reduce the Sun and Earths effect on it.
What's to say this can't be true of Earth, or that the Suns pull might weaken leading to the point of critical mass to launch us out of orbit?
Posted : 29/11/2013 8:12 am
Just with the number of stove owners on here surely it's lighter because if all the wood we burn!
Posted : 29/11/2013 8:18 am
The moon is distancing itself because the earth is providing a slight kick to the moon each time it rotates due to tidal forces. The extra energy puts the moon in a slightly higher orbit but it only about 3cm a year so not something we have to worry about for a while. The other side of this equation is that the rotation of the Earth is slowing down. Each day is longer than the previous one. Again not something you need to worry too much about its only around 2.5 milliseconds a century, no need to buy a new watch just yet.
The Sun is also losing mass - it is after all a massive fusion reactor that is turning matter into energy. But again the effect is very small.
In around 2-3 billion years as the Sun becomes a Red Giant it will have lost enough mass to significantly effect the orbit of the earth.
However I wouldn't worry about it as the increasing intensity of the sun output in around 1 billion years time will have all ready boiled the oceans dry
Posted : 29/11/2013 12:27 pm
what about the fact that the universe is expanding at an increasing rate relativistically increasing the mass of all the objects in it? Or cos its space that's accelerating does it cancel itself out. Knew I shouldn't have watched that Light and Dark thing last night - head's cabbaged.
Posted : 29/11/2013 12:38 pm
scotroutes - Member
We will only technically run-out. Helium is produced as an alpha particle during radioactive decay so there is a pretty constant supply, just a very very slow one.
The reserves we used to have were produced over many millions of years and trapped underground.
Hard to beleive you can still fill a balloon with the stuff on the high street!
Matt
Posted : 29/11/2013 12:48 pm
I bet solar wind accounts for much more.
Eh what?
It's apparently gaining energy from the spinning earth, via the mass of water involved in tides. The Earth used to spin faster.
Posted : 29/11/2013 12:50 pm
We split the atom quite a while ago!
Posted : 29/11/2013 1:15 pm
maxtorque - Member
Crag
That would also require you to be taking a shit with your bottom pointing skywards.
Anyone tried it?
Posted : 29/11/2013 1:42 pm
 kevj
Anyone tried it?
Taking a shit upwards or measuring it's velocity?
Posted : 29/11/2013 1:44 pm
I'm sure you are right
It was a good documentary
I'm not sure "dark energy" is relativistically increasing the mass of all objects.
The space between galaxies is increasing and their motion relative to each other is indeed increasing. But for ourselves located in our galaxy our relative motion compared to the object around us doesn't change so according to our frame of reference relativistic mass remains the same.
What's really strange about dark energy (well apart from not having a clue about what it is) is that it appears to be increasing. The current theory is that "empty" space contains energy as it expands it creates more empty space and there is more energy as a result.
At the moment dark energy is not strong enough to effect objects which are gravitationally bound to each other. So dark energy is not expanding the space between the Sun or effecting the Suns position in the Milky Way.
But if dark energy keeps increasing it may start to overcome these gravitationally bound systems too, eventually becoming so strong that it starts to tear everything apart until the universe is just a vast expanse of disassociated atomic particles.
Posted : 29/11/2013 2:02 pm
I replaced a bunch of parts with titanium so it's definitely lighter.
Posted : 29/11/2013 3:17 pm
I definitely got a bit heavier in the early 70's, I blame these chaps.
Posted : 29/11/2013 4:37 pm
