Is it ok to use a f...
[Closed] Is it ok to use a fold flat hosepipe with a jetwash?
5 Users
When using a jetwash does anyone use a fold flat hosepipe? I'm thinking it'd be ok but am a little worried that the jetwash will be pumping the water out so quickly that the hose will collapse on itself. Does it have to be a rigid hosepipe?
Posted : 03/03/2013 6:10 pm
Good question... I suspect that he pump *could* suck the pipe flat unless you have very good pressure/flow.
Would be interesting to hear how it goes.
Posted : 03/03/2013 6:17 pm
Can't see it being a problem , i use a hozelock hose & reel for my pressure washer and never had a problem . Just make sure there's no kinks in it prior to use .
Posted : 03/03/2013 6:21 pm
The volume of water trying to come through the hose pipe is far greater than coming out the jet wash so the pipe will stay inflated
Posted : 03/03/2013 6:31 pm
Yep, works fine even with an £8 eBay hose.
Posted : 11/03/2013 3:35 pm
my waterpressure is so much that i have to turn the tap down or it blows the blow off valve on the pressure washer when i switch let go of the trigger and the motor stops..... - a bosch aquatak 115 so not cheap crap.
i wouldnt be worried about the hose at all.
Posted : 11/03/2013 3:48 pm
