Is it easy enough t...
[Closed] Is it easy enough to swap the radiator on a berlingo?
9 Users
Any mechanics know if it's areas enough job my normal spanner man is on hols
Ta
Posted : 27/11/2015 7:55 pm
and in the queens english your question is ?
what engine ?
the 1.9 is certainly an easy job to do - not that ive replaced it but ive pulled mine out and given it a wash through. plenty room and good access.
hardest part is getting a good bleed on the system - there are a couple of hidden schrader bleed valves that if you dont bleed will give airlocks.
Posted : 27/11/2015 9:16 pm
Bloody spell Checker changing my text.
It's a 1.4 and needs a new radiator as I've a leak in mine. Just wondering how easy it is to do to swap for a new one
My usual mechanic is away on hols and ive not loads of cash for a repair this close to Christmas
Posted : 27/11/2015 9:22 pm
I've got a 1.6. Tried to flush the rad the other day but struggled to even get the bottom hose off.
Access is pretty restricted unless you have a ramp. I've ended up taking it to a garage...
I've now been told I need a new radiator, radiator fan etc. £550. 😥
If you have the time, daylight and access you should be ok.
Posted : 27/11/2015 9:27 pm
not done a 1.4 BUT
http://www.saxperience.com/forum/showthread.php?t=80569
although its a saxo - itll be the same engine near as damnit ime..... explains the bleeding proceedure quite well and stresses the importance of doing it right. many folk miss the schraeder one out and wonder why they get airlocked.
Posted : 27/11/2015 9:29 pm
for those of you without wheel ramps.....
Trying to do the radiator on the floor with no ramps isnt going to happen - unless you park half on half off a kerb or something.
My berlingo is tight to change the oil filter on the floor TBH - my van is no issue - same vehicle same engine - blingo much lower for some reason.(both have new springs on the front as well)
Cheers fellas
That's crazy money kayak rads are about 50 quid
Posted : 27/11/2015 9:49 pm
New fan assembly too, flush and fill coolant etc etc labour labour...
Not happy but just can't see that I can do it all easily enough without a ramp.
Posted : 27/11/2015 9:53 pm
top tip - dont buy the cheapest radiator off ECP - it wont last.
Never had good success with cheap radiators.
last time i changed a radiator(on the frontera) i had the original one recored for about 120 quid rather tahn buy a cheapo ..... thats worked out well for me. THe cheapos folks were putting in on the forums were lasting about a 18 months before springing leaks - the original was 20 years old.....previous to that id stuck a cheap on in my fiesta - it holed at 13 months - i just rad welded it until i got rid of the car for a scrap a couple months later.
Posted : 27/11/2015 10:00 pm
Is Radweld worth a shot for a while? I wasnt sure if it might cause more problems than it solved
Posted : 27/11/2015 10:09 pm
only if you plan to scrap the car in the next month or so .
its nothing but a really shitty bodge.
I wouldnt recomend it on any level for a car you want to keep or even sell.
its horrible nasty stuff.
Posted : 27/11/2015 10:11 pm
Glad I didn't try it then lol thanks
Posted : 27/11/2015 10:14 pm
Put one in our old C15 back in the days of Serck Marston. Vaguely remembered it came with a lifetime guarantee which they honoured when 4 years old.
The Scudo rad was an OEM Valeo for about £110.
Kayak - does it really need a fan? Seems very coincidental for both to fail together. Or are they just being lazy not wanting to bother swapping the old parts? Fans and sensors etc were still fine in the above examples at 155k and 133k miles.
Posted : 27/11/2015 10:15 pm
If you go rad seal route go for the better version called k-seal.
Posted : 27/11/2015 10:18 pm
Hardest bit will be the bleed. I'm sure there will be a video on YouTube.
Posted : 27/11/2015 10:19 pm
Thats about £50 worth of timber! - Cheaper to buy some wheel ramps 😆
Posted : 27/11/2015 11:24 pm
depends if your buying the timber or not... that wouldnt even dent my scrap wood pile. - he has also made them long for fitting under his low car .
Ive seen full size up in the air type pits made from wood - the kind of scare the shit out of you ramps 😀
i just use a pair of cheapo sealeys i got years ago - best tool ever for a drive way mechanic.
Im currently latterally thinking my way round a steering rack swap on my berlingo :S
Posted : 27/11/2015 11:28 pm
Sadly yes. It's seized. The car has been overheating when in stationary traffic for ages. Realised fan wasn't working, but carried on and avoided traffic...a bit.
Posted : 28/11/2015 3:28 am
Just had a look I'm the light and there seems to be plenty of access, I think lol
Are the only bolts the couple on top I'm thinking the bottom is on grommets but I couldn't feel as it was hot
I think I'd maybe trust myself to bleed the system rather than an independent garage. As long as I could find the bleeding points that is
[URL= http://i49.photobucket.com/albums/f278/firestarter4075/Mobile%20Uploads/DSC_0043_zpsfpwxrtoi.jp g" target="_blank">http://i49.photobucket.com/albums/f278/firestarter4075/Mobile%20Uploads/DSC_0043_zpsfpwxrtoi.jp g"/> [/IMG][/URL]
Posted : 29/11/2015 3:31 pm
Citroens tend to have bleed valves towards a the tops of the heater matrix pipes as they enter the bulkhead from memory.... But just follow every water pipe and look for the highest spots as that's normally where bleed valves are.
Posted : 29/11/2015 7:10 pm
 scud
Which engine is it you have?
Whereabouts are you?
I am just about to scrap a 1.9 non turbo Berlingo (rear ended) where I only replaced the radiator and hoses (plus back tyres) 3 weeks before I got hit if any good to you?
Posted : 29/11/2015 7:54 pm
I'm in Leeds it's a 1.4 petrol I'm not sure on what fits what tho
Posted : 29/11/2015 10:37 pm
