Is an oil boiler da...
Is an oil boiler damaged if it overheats?
3 Users
Boilerists to the forum...
Grant combi oil boiler - It triggered its overheat lockout after a voltage drop caused the circulation pump to stop.
I could hear water boiling in the heating loop / heat exchanger, and the whole lot was too hot to touch.  I let it all cool down and then topped up back to 1 bar, and everything seems normal, but as it's fairly new I'm wondering if it's worth getting it checked over?
(Not my boiler but my mum's, installed a couple of years ago. A fault at the electrical substation caused the voltage to fall to about 140V for a few hours, and unfortunately the boiler fired up to top up its hot water side.)
Posted : 13/08/2024 10:47 pm
No, it shouldnt cause any lasting damage, that’s why the overheat stat is there, to protect against overheating.
Posted : 14/08/2024 8:11 am
Call the power distributor and explain the situation. If it does cause a problem then at least they're aware. Get names/confirmation/reference number, whatever.
They aren't usually liable for a power cut, but this is a fluctuation that they're responsible for
Posted : 14/08/2024 8:45 am
