My macbook is telling me my startup disc is nearly full and in an attempt to free up memory I moved my iPhoto library to an external hard drive (EHD) some time ago. However, recently I imported photos from my camera into an iPhoto library on to my macbook drive by mistake and now want to move these photos on to my external drive. I've tried exporting them from the Macbook iPhoto Library into a new folder then importing from this folder to the EHD iPhoto Library but they do not show in the 'Library' (Events, Photos etc) but do show in the 'Last Import'!? Totally confused and dont want to mess it up any further...anyone willing to help out?
Drag and drop the photos into a folder or onto a stick, then drag and drop them into the proper library.
Is that different to exporting to a stick or folder then importing from that stick or folder? If so Ive already done that.
I would recommend iPhoto library manager - it takes a little to get used to but means you have iPhoto libraries in different locations (i.e. hard drive and ehd) - http://www.fatcatsoftware.com/iplm/ - I bought the full version and its worked well.
Tried this?
[url= https://discussions.apple.com/thread/5096799 ]https://discussions.apple.com/thread/5096799[/url]
I've only ever used drag and drop but I did just do an Export successfully. reading again, is it the import you are having problems with?
Aye it seems to be. I can see the photos in 'Last Import' but not in the Library.
It's not just that you have some bizarre view setting which is burying the new photos amongst the old ones is it? Try View Sort By Date Ascending and see if your new ones then appear at the bottom.
All sorted now - instead of exporting and importing via the option bar i just dragged and it seemed to work 😕
