I'm thinking about getting an iPad mini but I'm unclear as to whether I would be able to plug in my garmin forerunner watch (which has a usb connection) and upload to strava. Does anyone know if you can get a cable to connect usb devices or will I have to buy a new Bluetooth watch
Yes there is a usb connector, whether it will work with your Garmin I don't know. I had a connector for my old iPad1 which I used for uploading photos. The app you use on the iPad has to recognise the external device and allow file uploads
EDIT, I had the prior version of this its explicitly advertised as a camera adapter
Don't know for sure but I would say very doubtful*.
iDevices are generally closed systems. They don't allow you to just plug in any old USB device, as that gets into the hell of drivers, compatibility etc.
* (It is [i]possible[/i] that Garmin have an iOS specific cable/software available)
Nice one, thanks for that. I've just watched a YouTube video which seems to show that most usb devices aren't supported. Now I'm thinking if I get the cheaper iPad 2 I can get the Bluetooth watch!
Echo the unlikely comment, hence my preference for android on the other thread. I think pictures is pretty much all you can do with usb on ios.
I know you are asking for information about the iPad, but just for info I can plug my Edge 500 straight into my Android tablet (Edge 500) and upload from there using a usb OTG cable.
You just navigate to the files using a file manager.
I have heard that some devices don't send enough juice to the usb port for it to function, but mine was fine straight off the bat...
Even Bluetooth is limited to things like keyboards on ios, file transfer is not possible I don't think, check before you assume it's possible. Android is much more accommodating but still difficult compared to a pc
Hmmm, I already have a Lenovo tablet but it really doesn't get much use as I can't get on with android even though I realise it is more flexible than iOS. I also have an older notebook which I use just for uploading my watch to strava. Would quite like just one device really but I can see that may not be possible. Thanks for the point about the Bluetooth reluctant wrinkly because I had assumed that any Bluetooth device could be compatible.
OP as per the other posters the issue will be whether the apps can see the Garmin. For security reasons Apple keep things very tightly controlled. My camera worked fine but that's because the Photo app is enabled to see external devices. Your real solution is to connect the device to a computer.
Or go back to using strava on my iPhone I guess
Host of reasons why it's very unlikely to work. You'd be better off with an Android tablet which supports USB on-the-go (OTG) (not all do).
Garmin connect mobile on an iPad mini works great with a range of Garmin Bluetooth devices here.
Cables are soooooo last century daaahrling.
(I just wish Garmin software was generally better 😐 )
OP I use endomondo and can see the results on the iPad via app or website but to do usefull things with the tracks I download into my computer. I think is an example of where the iPad is not a computer substitute.
Bluetooth should be fine. I have a Garmin vivofit 2 that I sync with my iPhone over Bluetooth Smart (via Garmin Connect app).
@grahamS - are you using the vivofit for cycling and with strava?
Nah. It's a glorified pedometer. No GPS. Got it free from work so just been playing with it for the past week.
(For route tracking I just use my phone)
To add a bit more detail, I have a Fenix 3 which I sync with my iPad, mrsj has a vivoactive which she syncs with her iPad and missj has a vivofit which she syncs with her hudl2 - all using Bluetooth and the Garmin mobile connect apps.
