IPad help - lead fo...
[Closed] IPad help - lead for TV
8 Users
So, my TV has HDMI and PC in points, but which is best to get for iPad to TV linking so we can watch stuff on the big screen? Last time I looked (admittedly a couple of months ago) it didn't seem that clear as to what I needed. Also, Apple prices for leads - are they havin' a laugh!?
Posted : 16/10/2012 5:55 pm
Just get one of these
[url= http://http://www.ebay.co.uk/itm/Dock-Connector-to-HDMI-HDTV-1080P-Cable-Adapter-for-iPhone-4-4s-iPad-2-3-/320938824799?pt=UK_iPad_Tablet_Accessories&hash=item4ab971d45f&_uhb=1 ]HDMI Adapter[/url]
Then plug your HDMI cable in and the USB to charge.
I've been using one for a couple of years and they work a treat
Posted : 16/10/2012 6:08 pm
^ this or an appleTV or a raspberry pi running raspbmc (because it supports AirPlay.)
Posted : 16/10/2012 6:14 pm
You will need this
http://store.apple.com/uk/product/MD098ZM/A/apple-digital-av-adapter?fnode=3a
Or its third part equivalent, if they exist, no idea.
And a standard HDMI to HDMI cable.
I have the Apple adaptor and the cheapest HDMI cable I could find, it works really well.
Posted : 16/10/2012 6:15 pm
 DrP
I'm using a VGA adaptor only because I needed it for projectors too.
Works well for iplayer and you tube etc...
DrP
So both hdmi and the pc/vga plugs will work? For sound too?
Thanks for replies...
Posted : 16/10/2012 6:24 pm
Apple might be having a laugh with their prices but their leads do work very well.
We've got an Apple HDMI connector and an Apple Composite AV lead and they're both excellent. Composite AV is red, white and yellow and Component AV is red, green and blue - check which one you need for your television.
Also buy a SCART to RCA lead, a long RCA to RCA lead and some connectors (I think it's just phono stuff), a 10m HDMI lead, some HDMI right-angle connectors and you're good to go. I'm not joking - all of these will be cheap: £15 or so tops for all of these and you can pretty much connect to any television that you come across!
We take our iPads abroad and if you have either or both leads you should be able to watch your own films / BBC iPlayer downloads and listen to your music no problem. It's just a case of working out how to make the television in your hotel room receive the signal... Mostly a breeze (pretty much - we've succeeded on most of our holidays)
Hope this helps - it works really well for us!
PS - The Apple Camera Connector works really well as well...!
Posted : 16/10/2012 6:32 pm
Sound certainly works for us with what we have...
Posted : 16/10/2012 6:37 pm
 IA
HDMI is only on more recent iPads, no? I forget which one it was added with.
Not the same it does't. I find linux airplay support works fine with music, youtube, non-drm videos already on the device and nothing else.
Posted : 16/10/2012 7:03 pm
 DrP
No sound on VGA......
DrP
Posted : 16/10/2012 7:06 pm
Thanks! What confused me previously was that there didn't seem to be one single lead, it needed adapters and two leads and you've all pretty much corroborated that.
Ta! And if VGA don't have sound then hdmi it is.
Posted : 16/10/2012 7:09 pm
 Rich
Be sure to check it's possible to send whatever it is you're planning to the bigger screen.
When I looked into it, it wasn't possible with Lovefilm or Sky Go, so I didn't bother.
Posted : 16/10/2012 7:16 pm
