Insulated water bot...
[Closed] Insulated water bottle
12 Users
Any recommendations please? Does not necessarily need to be bottle cage compatible. Prefer to buy once but cheaper the better - not worried about designer badges or ergonomic design!
Thanks
Posted : 03/01/2019 9:20 am
I've got a Camelbak Forge that works really well. Keep the drinks hot (or cold) and is pretty indestructible, mine's about 4 years old and still works well.
Posted : 03/01/2019 9:29 am
Have a look at One Green Bottle products.
Posted : 03/01/2019 10:26 am
Really impressed with these
https://www.amazon.co.uk/gp/product/B074J3LMDS/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Edit - should add its build quality I’m impressed with. I use a flask for hot drinks, this for cold.
Posted : 03/01/2019 11:02 am
Do what we did for many a year - take any water bottle and Ducktape Karrimat around it.
How insulated does it have to be? I have an insulated camelback podium, it prevents freezing in this weeks subzero or warming up in summer heat with ice cubes in. We also have an old nalgene insulated sleeve that worked well, until one of the household lost the nalgene bottle. That was 50% as good as a flask.
We also have three different flasks in the house, for properly keeping things hot.
Posted : 03/01/2019 11:14 am
I know you said economical, but I have a Yeti bottle and its excellent.
It seems to be made of girders..... it'd certainly crack a concrete paving slab if you dropped it. It will definately last at least my lifetime.
Posted : 03/01/2019 11:15 am
Thanks for responses. Should have said for keeping water cold. Off to Cape Verde and want a cold drink after a few hours kiting. Capt slow I was on the verge of buying your recommendation when I thought I cant make a big decision like this without the STw seal of approval.
Posted : 03/01/2019 11:22 am
Those insulated steel bottles are available under loads of different brands. I'm sure they are all much the same thing, from the same Chinese factories. Cheaper if you buy them direct from AliExpress.
Posted : 03/01/2019 11:31 am
I bought a Corkcicle mug thing (they do bottles also) while out in the BVI in October. That thing is amazing - put a cold drink with ice in it and the ice will still be there 4 hours later easily. After 9 hours the ice was gone but the drink was still very cold.
A bit spendy though.
Posted : 03/01/2019 4:42 pm
I bought a camelbak Podium bottle last year.
It was decent at keeping drinks both hot and cold but I would not buy another as the valve was a PiTa to clean. Even taking lid & valve apart after each use I ended up binning** it after an ominous black mould appeared inside.
**okay. My missus threw it out.
Posted : 03/01/2019 4:57 pm
Home Bargains; identical to the Chillys items that are £25 on Amazon, labeled as 'Manna' and £5
Posted : 03/01/2019 5:08 pm
https://www.ulula.co.uk/pura-sports-top-22oz-vacuum-insulated-bottle-aqua-sleeve.html
I use one of these, take the silicone sleeve off and have a plastic bottle cage otherwise it's noisy over bumps. Couple of hours in and refreshing fruit tea is a winner 😁
Posted : 03/01/2019 5:49 pm
Klean Kanteen.
Posted : 03/01/2019 5:50 pm
