In the name of gree...
[Closed] In the name of green / eco, why don't....
11 Users
[patent pending] Kettles have an adjustable temperature shut off thingy? [/patent pending]
Posted : 24/02/2014 12:04 pm
What so you can not boil water?
Posted : 24/02/2014 12:05 pm
Probably because if you're that concerned about making proper coffee you'd have a coffee machine for that and only use the kettle for tea (and other alternatives).
Posted : 24/02/2014 12:10 pm
the optimum range fo temp for brewing coffee is 91-94degs, so that would save a rainforest just on its own! 🙂
Posted : 24/02/2014 12:11 pm
So you too have discovered the optimum Pot Noodle temperature is slightly below boiling?
Posted : 24/02/2014 12:13 pm
But they tend to spring a leak just after the warranty period expires, so need replacing, which aint so green after all.
Posted : 24/02/2014 12:18 pm
Some Bosch kettles have different temperature settings.
So, £60 for the Bosch kettle linked above. How long for its savings, over a regular kettle, to pay for itself if making, say 10 cups of tea per day???
Posted : 24/02/2014 12:23 pm
Yep - loads of temperature-controlled kettles about.
I use one for tea - 80-degrees for Oolong for example.
Although from an eco point of view it's not necessarily great, because it holds the temperature, so the temptation is to heat a lot of water, then keep pouring from it for each new cup.
Posted : 24/02/2014 12:25 pm
267 days.
Just done some very rough calcs with some wild estimates and came up 4.1 years
Posted : 24/02/2014 12:28 pm
So, that's 65.12195122 days in a year then. Cool, glad that's clarified.
Posted : 24/02/2014 12:34 pm
Thats good, so lets all buy one and save a rainforest. Oh, wait. That will mean we chuck away all our current working kettles.
Mmmm, thats a bit of a waste.
