Improving wife sign...
[Closed] Improving wife signal in house
95 Users
I have Virgin media broadband and the standard supplied router/Wifi box. Wifi is good downstairs but poor upstairs. What is the best way to either boost it upstairs or create a secondary network from the Ethernet socket upstairs?
Posted : 30/03/2013 8:52 am
Just ask her to shout...
Posted : 30/03/2013 8:53 am
become a mormon and have 2 wives?
Posted : 30/03/2013 8:54 am
Most people are looking to degrade the signal.
Posted : 30/03/2013 8:55 am
ask her to stand on the roof with an ariel, a bit like Rod Hull, just ensure life insurance is up to date......
Posted : 30/03/2013 8:56 am
"good downstairs but poor upstairs"
BOBFOC?
Posted : 30/03/2013 8:57 am
Thread title typo of the week! 😀
Posted : 30/03/2013 9:04 am
Problems with Virgin wife signal?
I reckon you've got a duff unit there.
Posted : 30/03/2013 9:09 am
Flowers, that always works. Say sorry then do something really wrong...
Posted : 30/03/2013 9:11 am
Hmm, clever phone keyboard makes untrue assumption! There is no wife.
I had corrected that twice in the post but missed the title.
Think I had better start again, I suspect it is going no where helpful 🙂
There is no wife.
Maybe there is, just a bad signal.
Posted : 30/03/2013 9:15 am
Posted : 30/03/2013 9:17 am
Brilliant
Posted : 30/03/2013 9:21 am
Secondary wife networks aren't the easiest systems to manage. You'll probably have no luck in either socket once you've got a conflict.
Posted : 30/03/2013 9:27 am
Wifes always give off poor signals.
Posted : 30/03/2013 9:37 am
 Pook
is there a problem with your dongle?
Posted : 30/03/2013 9:41 am
No Virgin here - ended up with bl00dy TalkTalk.
Advised to 'turn off and on again' - first part was easy.........
Posted : 30/03/2013 9:43 am
 kevj
Are you putting it in the right port?
Posted : 30/03/2013 9:46 am
And when you get the right port you might just need to wiggle it about a bit.
Posted : 30/03/2013 9:48 am
Are you sure your wife is backwards compatible?
Posted : 30/03/2013 9:50 am
Buy her a more powerful router?
Are you getting interference from next doors signal?
Posted : 30/03/2013 9:54 am
Flash the (not so) firmware with a younger more up to date version.
Posted : 30/03/2013 10:41 am
She's probably running too many background tasks and so communication processes can't get any cpu time. Scan her for infections, common resource consuming malware includes Shoes, Decore, Gossip, Fad Diets and worst one of all - Frumpiness. If its frumpiness I'd just bin her and get a new one.
Posted : 30/03/2013 10:45 am
Tbh I've heard that looking at the wrong sort of websites can result in speed (or indeed any kind of action) being much reduced
Posted : 30/03/2013 10:48 am
I had two wife networks once, but I got cross talk and it all got very messy. Cost me my house, car and all my savings to sort it out, but I ended up homeless without any Wife.
Never again....
is she secure? teenage lad next doors non stop activities caused a problem in our house
Posted : 30/03/2013 10:59 am
Thread of the Year , Class !
Posted : 30/03/2013 11:10 am
Signal to noise ratio can be very poor IMHE.
Posted : 30/03/2013 11:34 am
try mounting the wife router in different locations around the house, it improved our signals no end when we did that
Posted : 30/03/2013 11:35 am
Mines always encrypted, lucky if I can get a clear signal any day! 😀
Posted : 30/03/2013 11:36 am
My wife network never liked being mounted upside down. Apparently I needed a different model....
 Doug
Sky+ helped with my wife network problems. It seems much more stable and communicative in the evening now. Can only assume it drops out a lot more whilst I'm at work.
Posted : 30/03/2013 12:01 pm
You could try a WIFE repeater, not something I would like though.
Posted : 30/03/2013 12:07 pm
I'd get an engineer in to give her the once over.
Posted : 30/03/2013 12:13 pm
Still performing well in the kitchen but the bedroom is more intermittent than it used to be. Still have never got close to the back passage ect, ect, ect.
RIP Sid James
Posted : 30/03/2013 12:21 pm
Don't think it even has to be a qualified engineer, I've heard plumbers, postmen, even the milkman can perform quite extensive servicing, at regular interval for years.
Posted : 30/03/2013 12:28 pm
You need a signal booster
Posted : 30/03/2013 12:33 pm
What about trying your neighbours wife?
Posted : 30/03/2013 12:38 pm
"Thy shalt not poach thy neighbour's unsecured Wife"
Posted : 30/03/2013 12:42 pm
*wipes tears away*
*stitches up split sides*
Keep it coming chaps! Thread of the year so far!
Posted : 30/03/2013 12:51 pm
deadlydarcy
We should actually have this as a weekly award 😉
Posted : 30/03/2013 1:39 pm
Have you turned her off and then turned her on again?
Posted : 30/03/2013 1:55 pm
Have you tried plugging the wife into the master? You'll have to locate the box and pull the bottom half off to gain access.
Posted : 30/03/2013 2:25 pm
sorry to say, it's probably needing a bigger aerial
Posted : 30/03/2013 2:35 pm
Have you checked what the wife designed to receive? Not all wifes are B|G N compatible. Frequency can also be a problem, if wife is only designed for a rate of 2.4 G cycles a second then 5 G cycles a second will be problematic.
Posted : 30/03/2013 2:42 pm
So your wife keeps going down on you and you're on here complaining about it?
Sheesh!
Posted : 30/03/2013 2:45 pm
The secret lies in power lines, however we all know who has the real power in any STW marriage.
Posted : 30/03/2013 3:19 pm
 hels
Have you read the manual ? That might help you locate the on/off switch.
Posted : 30/03/2013 3:24 pm
Have you got a physical connection?
Posted : 30/03/2013 3:44 pm
Perhaps yours is a public hotspot?
Posted : 30/03/2013 3:59 pm
Maybe you could implement some kind of pay per use system, and use the income to support a second better wife just for you?
Posted : 30/03/2013 4:04 pm
OK, back to basics here.
Insert Tab A in to Slot B. You don't need to worry about Spot G yet, not until you've got the basics sorted out.
Posted : 30/03/2013 4:11 pm
Try turning the TV off, I often find I have a better wife signal without other background electrical interference.
Once you have uploaded any info required its best to turn it back on or you can get loads of unnecessary traffic/spam
Posted : 30/03/2013 4:19 pm
If all else fails I could pop by and give it the once over. I charge by the hour but these things only usually take a few minutes
Posted : 30/03/2013 4:21 pm
Your Wife has probably caught a virus. You need to be careful of interfacing with public Wifes, never know what you might pick up...
Posted : 30/03/2013 4:25 pm
Never skimp on servicing 😉
Posted : 30/03/2013 4:27 pm
We can attempt to make it last longer but sometimes it just starts working all too quickly and can't be made to stop again. Probably just lack of practice with the tools.
Posted : 30/03/2013 8:21 pm
Tbh, the problem usually seems to be user error rather than a problem with the wife.
Posted : 30/03/2013 8:43 pm
This thread made my wife make an unusual noise, it normally whines, and when it doesnt whine it moans but it actually seemed happy for a brief moment.
Wipes away a tear STW has some great comedians
Posted : 30/03/2013 8:53 pm
Classic STW thread, nearly lost a contact lens wiping the tears away! Genius! 😆
Posted : 30/03/2013 8:56 pm
Have you got kids? I'm fairly sure it's the kids causing my wife to disconnect, as it was much better before they came along.
Posted : 30/03/2013 9:00 pm
Every time I've had that problem this has sorted it, look round the back you will find a small hole where you have to poke something small into it ,you might find some resistance,just keep pushing,you will probably hear a small noise at first then it should work just fine, should achieve similar results in all rooms in the house!!!!
Posted : 30/03/2013 9:24 pm
Have you just tried kicking it?
Or placing it next to a radiator??
Posted : 30/03/2013 9:26 pm
I´ve had to skip most of this since I´m trying not to spray beer across the keyboard and screen. I will be back later. Carry on.
Posted : 30/03/2013 9:32 pm
BT sent a man round to fix mine.
Posted : 30/03/2013 9:36 pm
Don't ask the TV man to service it! It may not turn out as expected 😯
Posted : 30/03/2013 9:40 pm
 kevj
"It's the t.v. repair man. And the t.v. isn't even broken"
Moans. Etc.
Posted : 30/03/2013 9:44 pm
has her socket got a deep groove? If so, you have found the right wife.
Posted : 30/03/2013 10:00 pm
Forgot to mention that mine responds well to a good spank if its been inactive for a while 🙂
Posted : 30/03/2013 10:32 pm
Throwing a load of cash at it will have suprisingly good results, but only for a short while!!!!
Posted : 31/03/2013 6:45 am
Yes, but be careful here. You need to be quite subtle and can get away with it only once or twice, regular cash outlay can have very poor results leading to serious failure and regular outages.
There are two possible three times a year where targeted spending will have desirable results, anything outside of this is a tad risky...
Posted : 31/03/2013 7:01 am
*Decides contribution to thread over-steps boundaries of decency and leaves others to it*
Carry on everyone. This is great stuff 😆
Posted : 31/03/2013 7:06 am
If your Wife isn't turned on, my model has a hole at the back you need to push something in while locating the button at the front at the end of the groove. Usually lights up like a Christmas tree. NB. Might need a friend to help if you have small hands!
Posted : 31/03/2013 7:15 am
There's a very good app on android called wife analyser. You can use it to check wife strengths, plot wife performance over time and even compare your wife to other wife's in the neighbourhood. If that's too complicated then there's a simple colour coded dial, when it's green your wife is good to go.
Posted : 31/03/2013 7:35 am
If its instant access u require fill it full of alcohol,should then do everything you want!!! Beware though this is temporary as it won't work at all tomorrow!!!! 😀
Posted : 31/03/2013 7:38 am
If you want to eliminate user error, try and borrow a friend's wife and see if that works any better in your house?
Posted : 31/03/2013 7:44 am
Good idea FF, in fact you could extend the idea. Speak to the other guys on the street and organise a really good test by putting all [your] various wifes in one house and test each in turn, in several rooms (need to be quite scientific about it). For best results make sure the others are turned off otherwise the interference becomes unmanageable.
The one that performs best in a variety of positions is the model you want.
Posted : 31/03/2013 7:53 am
 ianv
You could always just get rid and replace it with a newer model. The more up to date ones tend to be better looking, slimmer design and less hassle to operate.
Posted : 31/03/2013 8:16 am
