Improving a dusty c...
[Closed] Improving a dusty concrete garage floor
21 Users
As the title, as part of fitting out my garage / workshop (seperate thread to follow), any suggestions on how to help with the dusty concrete floor.
Every time you sweep theres lots of dust and still a slight white residue if you run your finger over it.  The surface isnt breaking up or anything and I  dont want to go the floor paint route until i have sealed it properly
I was looking at the dustproofer/surface hardener products by Sika etc but any experience / advice / alternatives would be very much appreciated
Thanks
Posted : 27/08/2018 5:58 pm
I brushed mine , vacuumed it and then sealed and painted.
Job jobbed , no more dust.
Posted : 27/08/2018 6:09 pm
Thanks
Would you mind telling me which product you used for sealant?
Posted : 27/08/2018 6:13 pm
Used Ronseal sealant and floor paint on ours six years ago and still looks as it's just been done
Posted : 27/08/2018 6:21 pm
Try and get a two part epoxy paint, much more durable than the one part tosh we used at work.
Posted : 27/08/2018 6:22 pm
 kcr
Alternatively, you could lay the interlocking foam tiles instead of trying to seal the floor.
Posted : 27/08/2018 7:07 pm
 tomd
I had the same problem but it was a fairly old floor so stains here and there. I looked at painting it properly and with the pre cleaning and 2 coats I reconned it would bit a bit if a ballache with no guarantee it would last where the old oil stains were. I went for the interlocking floor tiles. Really good system, took half a day to do the whole garage and it's looks good. More expensive than paint but less time. IRC it was about £250 for a decent sized single garage.
Posted : 27/08/2018 7:24 pm
AstroTurf it.
Posted : 27/08/2018 7:32 pm
I brushes, vacuumed and painted (Screwfix no nonsense), didn't need to seal. Took a couple of hours over 2 days (doing 2 coats and half the garage at a time)
Posted : 27/08/2018 7:36 pm
I brushed washed then painted mine with some basic Screwfix floor paint. Seems to be lasting well. Did it 2 years ago
Posted : 27/08/2018 8:16 pm
 rone
I had an office carpet put down. Glued.
It's been perfect.
Posted : 27/08/2018 8:17 pm
Watered down PVA will dustproof it. Mine is also carpeted just in case I get kicked out of the house.
Posted : 27/08/2018 8:23 pm
plus 1 for chucking a cheap carpet down.
good to kneel on when fettling the bike
Posted : 27/08/2018 8:27 pm
I used some old event flooring, works well.
Posted : 27/08/2018 8:40 pm
Wot he said. I priced up floor paint for my shed and cried a little. Watered down PVA sealed it nicely, only used a couple of litres (you dilute it down a lot, maybe 20:1). Massive improvement, I'm not constantly sweeping up clouds of dust any more.
Posted : 27/08/2018 8:44 pm
Ronseal garage floor paint in a nice pale blue which shows up bolts and bearings nicely when you inevitably explode a part.
Posted : 27/08/2018 9:16 pm
I painted mine. Then when I replaced the master bedroom carpet, I put the old underlay & carpet down in the garage. Far more pleasant to work in now, especially over winter. No more frozen feet if I'm in there for some time / changing for using the turbo .
Posted : 27/08/2018 9:38 pm
As above PVA watered down 10:1. Brush floor (no need to vacuum), apply PVA solution with roller. Dries overnight. I then painted it with a £20 floor paint. Sorted.
Posted : 27/08/2018 9:46 pm
Bookmarked
Does exactly what it says on the tin.
Induces vomiting if swallowed....
Posted : 27/08/2018 10:52 pm
I used interlocking foam tiles which are great, but AstroTurf seems like it could have been good. I had carpet in there before which was great, but we had a few edges as we used offcuts from other rooms (as suggested above)
Posted : 28/08/2018 8:00 am
OP - if it's just dust that concerns you, £3 worth of PVA and it's pretty much sorted. Try this first, as the dust will still but be created/collect under carpet, foam tiles or whatever else you lay on top.
Posted : 28/08/2018 8:03 am
Another two part epoxy here. Four years old not bubbling or lifting. Took it a couple of inches up the wall for good measure. Cant remember the brand but a WRC team had just done there new workshops with it. It did take longer than the specified time to dry though best part of a week iirc.
Its a light blue/grey not unlike the STW background.
Posted : 28/08/2018 11:32 am
