I need to screw som...
[Closed] I need to screw some racking onto garage wall ...
4 Users
Which is brick and the legendary Sussex bungeroush ....
The weight will mainly be taken by the brick ...
To hold 3 windsurfing boards + sails + masts
What do I need to use --- normal screws and rawlplugs ... or something else ?
Posted : 01/11/2017 10:10 pm
Personally I would mount wooden battening along the wall first with expanding bolts then screw hooks or whatever into the wood.
Makes moving or adding hooks a lot easier.
Btw Sussex bungeroush ?
Posted : 01/11/2017 10:36 pm
A quick Google has answered my question. We don't build using that method in Worthing hehe !
Posted : 01/11/2017 10:45 pm
 Bear
If fixing into the brick then use thunderbolts.
Posted : 01/11/2017 11:09 pm
would have gone the wooden batten route ....
off to look at thunderbolts
Re Bungeroush and Worthing ... if it's not screwed down in Worthing it won't be there ...
Posted : 02/11/2017 7:24 am
Will thunderbolts work on brick, rather than concrete?
Posted : 02/11/2017 7:32 am
Depends on the brick. Some are too hard. You also need to be well away from the edge.
Posted : 02/11/2017 7:46 am
