I need to fit decen...
[Closed] I need to fit decent lighting into my workshop via an extension lead
8 Users
I'll keep it short. Live in a rental with a nice brick outbuilding. Absolutely no chance of me being allowed to install proper power/lighting. Need decent lighting in it to fiddle with the bike etc and play some tunes. Can I run a light off a plug via an extension lead? If so, what light (bright and efficient) should I be looking at?
Thanks in advance.
Posted : 01/09/2014 9:14 am
I put up an old kitchen strip light wired to a plug, then ran an extension lead out to the shed, held above the ground (about 8 ft) by a line. The extension lead gave me a couple of sockets for power plus one for the light which was nice and even. A drip loop as the cable entered the shed and house stopped water running along the cable.
It was a bit Heath Robinson and there may well have been safety concerns I dont know about, but it worked fine for ten years.
Posted : 01/09/2014 9:25 am
My workshop is lit by 4 of these http://www.taskersonline.com/products/Faithful-240v-MIR-Task-Light-%2850092722%29.html
Bought on sale at about £15 each.
Posted : 01/09/2014 9:26 am
Cool. I was thinking of kitchen strip lights but those task lights look superb.... How bright are they? Good thinking about the 'drip loop' too 🙂
Posted : 01/09/2014 9:52 am
Pretty decent, the workshop is 8x4m and 4 of them are enough.
Posted : 01/09/2014 10:04 am
Excellent. Just found these on Screwfix [url= http://www.screwfix.com/p/defender-e709150-2d-work-light-38w-230v/78401 ]Worklight[/url] that look like they might do just the job.
Cheers for all the help and advice
Posted : 01/09/2014 10:07 am
Used to rent a terrace house that had the garage at the end with no power. We had a couple of strip lights up there and just ran an extension lead to it as already suggested. It worked fine.
Posted : 01/09/2014 10:10 am
Just make sure you use an RCD plug and it should be fine. I've done it will full armoured cable run through the garden but that was probably overkill.
Posted : 01/09/2014 10:48 am
Thanks nemesis. I've got a heavy duty 4 socket extension lead with a built in rcd, will that be good enough?
Posted : 01/09/2014 10:59 am
Your distribution box has probably got an RCD already....
Posted : 01/09/2014 11:08 am
It should do but best practice is still to always have one on the plug for outdoor use - not certain why but possibly more sensitive ones for the plug than the main one?
womble, that should be fine but IANAE 🙂
Posted : 01/09/2014 11:39 am
Those lights are Ok and all that, but @ £24 each I'd opt for an old kitchen strip light wired up to a plug on an RCD(same as I run in my loft) They can be picked up off Ebay for next to nowt. I think I paid £20 for 3x 6ft'ers which all went in the garage, they all came with tubes and starters and are as easy to wire up as a plug is
Posted : 01/09/2014 12:15 pm
Nope, they'll both be 30mA....
Posted : 01/09/2014 12:18 pm
My shed has a weather proof 4 foot batten in it. I'm pretty happy with it, using a strip light is nice as there are next to no shadows when working at the bench beneath it.
http://www.screwfix.com/p/lap-t8-high-frequency-weatherproof-batten-1-x-36w-4ft-1265mm/77863
Posted : 01/09/2014 12:32 pm
Those look really neat, Dave C. What cable would I need to wire these up? Also would a standard 13amp plug be ok? Just compiling a shopping list 😀
Posted : 01/09/2014 1:43 pm
If I wire two on one plug, might free up a socket on my extension lead.
Posted : 01/09/2014 1:58 pm
carlos - Member
+1 or just wander round any refurb (commercial or home), strip lights are always being dumped as their 'old fashioned'
Posted : 01/09/2014 2:00 pm
