I'm planning to clad 2 garage walls with 8x4 sheets of 18mm OSB. I'll need about 7 of them which I can have delivered with B&Q's new bulk delivery service.
The problem is they'll all be 120mm too high and I need to cut around a door frame. So that means cutting lots of long, straight, accurate lines.
What's the best way of doing this DIY style? I don't have access to a table saw. I also don't have any other power tools yet and don't mind buying them. I only have a cordless drill and a grinder!
I've used a jigsaw before and I know they like to wander around. Also it would take forever to do the long lengths that I need. Unless I've just used a toy in the past and I can buy a more beasty one. What about those handheld circular saws? They look faster but do they wander around? Any recommendations on the best tool for the job?
Maybe I'm over thinking it. It might be easy with a decent jigsaw and a clamped down guide but it's a big job and it'll all be visible. I'd rather not cock it up.
Track saw.
I have an erbauer from screwfix but the titan one is probably perfectly acceptable.
To be fair though i'd do it with a panel saw quite happily if I wasn't going to need the track saw again.
Buy with the 120mm ready cut from a B&q with a saw facility? Or similar from a properly timber merchants?
Any jigsaw (very slow) or circular saw will cut straight if you clamp or screw a straight bit of plank to run it against.
Mini plunge saw, really useful little things to have in your arsenal.
I have this model but there are cheaper ones around:
https://www.toolstation.com/draper-20979-600w-89mm-mini-plunge-saw/p66271
I did this a couple of weeks ago framing out the extension.
Circular saw and a straight edge.
If I was buying. New tools then track saw it would be.
As it was the circular saw was the tool of choice for a 1 man cut of a full size board..........and that's with me having an elu table saw.
Check out Peter Millard's videos on tracksaws. Some helpful stuff for beginners, including reviews of cheap models.
What’s the best way of doing this DIY style? I don’t have access to a table saw.
Its not a job for a table saw really - big stationary saws for small bits of wood, small portable saws for big sheets of wood.
A track saw is ideal if you think you'll do other stuff with sheet material in the future. A regular circular saw is more versatile if you don't have other tools already (with a bit of planning and jig making it can do the job of a track saw or a mitre saw just not as quickly)
That said Its not difficult (either in terms of skill or effort) to cut 7 sheets of OSB with a handsaw to a standard that will suffice for cladding a garage.
B&Q should also be happy to do any straight cutting of boards to length or width for free before they deliver (although I know they'd stopped their cutting services initially when the lockdown started I don't see a reason why they shouldn't have resumed them now)
Circular saw and a guide batton. Could chew through 2 at a time if you have clamps, although if it goes wrong thats 2 screwed boards.
You can borrow mine if you like, in Hampshire tho.
You using osb3 and some sort of insulation? Cellotex or polystyrene will help keep it cosy if your using it ad a workshop in winter. Might need to fit a membrane depending on outer skin integrity.
Be a bit mindful in your planning. Across different thicknesses and grades OSB can vary in sheet size
Some is the an imperial 8ft x 4ft (2444 x 1222) much the same as all ply/mdf etc and some is a metric size (2400 x 1200) so smaller, especially in length - its easy to miss the difference written on paper but if you've planned for one and the other arrives it can spoil your day. So double double check the panel sizes when you order with OSB
OSB is a devil for this for reasons that are probably very sensible (im going to guess its got something to do with framing and plasterboard which is also typically 2400x1200) - you don't get this issue with Ply, chip or MDF
I’ve used a jigsaw before and I know they like to wander around. Also it would take forever to do the long lengths that I need. Unless I’ve just used a toy in the past and I can buy a more beasty one.
Jigsaws can cut quicker and straighter if they have a pendulum action - the blade swings as well as goes up and down - the same way as you would cutting by hand really - and progresses better on longer straight cuts (you switch the pendulum off for tighter curves) . You can't cut beautifully straight with one freehand but you could probably cut straight enough for the job you want to do. Nominally you could use a clamped guide but unless the blade runs absolutely parallel to the edge of the baseplate the blade tries to deviate rather than follow the guide. In my experience I've never found a jigsaw that cuts well with a guide. But a good jigsaw with an appropriate blade shouldn't be particularly slow. You could cut a good enough line for a garage wall. But you'd have more versatility for any fiddlier shape cutting.
If you don't already have other tools I'd buy a jigsaw before I bought a circular saw. Anything with a pendulum actions should be good enough. The Makita 4350FCT is very good - seems to be less prone to vibration than other brands I've used and helpfully both illuminates the line you are cutting and blows the dust clear so you can see it - its as as good as you get before you start spending 4x the price on esoteric nonsense from festool and mafell ...... which one day you will 🙂
All you need is a sharp new £10 panel saw...
It won't take you any time at all. Probably a lot quicker than clamping up guides and stuff.
Thanks for all the pointers so far. I've been watching circular saw videos on YouTube!
I think that's the way to go. They're not too expensive.
I can get this corded Makita for £76- LINK
But then, I've been thinking about buying into the Ryobi cult for a while now and they offer this... LINK
Then when I need to tackle the rest of the house I can just buy bare sanders, jigsaws etc.
I was thinking I could get away without batons and membranes and stuff. They're both internal walls. It's on the ground floor of a terraced house. There's no draft and it's bone dry. I just want to cover the breeze block walls which are full of the holes left from the previous owners cupboard and shelves and have a surface I can attach my own stuff to.
EDIT: more replied while I was typing!
Jigsaws can cut quicker and straighter if they have a pendulum action – the blade swings and well as goes up and down – the same way as you would cutting by hand really
I was wondering what the pendulum referred to so thanks for that.
All you need is a sharp new £10 panel saw…
I'm tempted to try this. I might give it a go on a test piece before I spend any money.
I’ve been thinking about buying into the Ryobi cult for a while now and they offer this
The equivalent cordless makita is a superb wee saw. If you were buying into a battery system that saw on its own is the reason to go makita - its more versatile than a corded circular saw - having the blade on the left of the handle rather than the right seems a trivial difference but its really useful - paired with a roofing square as a guide they are a pretty good subsitute for a mitre saw and if you are cutting sheets freehand you can see your line much better
makita have pretty much the widest range of tool off one battery there is - including coffee percolators and wheelbarrows - they don't make one bad cordless tool.
So if you were looking down that line get whatever makita drill driver you fancy bundled with battery and charger and either the Makita DSS611Z the DHS680z as a bare tool - they are sold quite widely and theres always a bargain somewhere for bare tools
You need a cordless Mafell plunge saw kit. It's the only way I'm afraid.
I would second the above. Makita is a fantastic [s] cult [/s] battery platform to get into. I've got shed loads of it.
I've already got a cordless Makita drill that I bought in a sale about 10 years ago (I got an absolute bargain judging by the prices I'm looking at right now). Still going strong. Have they ever changed the battery design? I'll go out and buy a Makita if it works with my existing battery.
What drill is it? It's possible you may have a nicad one perhaps?
if its an LXT battery then that'll work with anything current (LXT came in about 10 years ago I think so it'll either be an early LXT or an older style nicad / nimh. The nicads/nimh batteries have a sort of prong that slots up inside the handle of the drill - the LXT ones are flat on top - you might find newer, higher capacity LXT batteries (4amp and up) aren't compatible with your drill / charger but older LXT batteries work fine with newer tools
Where are you based op?
I'm in Sheffield. I'm about a 30 second drive away from a B&Q, Screwfix and Halfords.
I just checked my battery it's definitely Lithium Ion but not LXT.
my battery it’s definitely Lithium Ion but not LXT.
Ahhh - theres a budget drill driver / set that Makita did that came with a non LXT battery but is sort of look-likey and doesn't work with other makita tools. B&Q sold them and it wasn't easy to tell they were not the same line as Makita's standard range. LXT batteries (once slotted into the tool) are all black apart form the grey/white button - the budget range and a grey/white band around the top of the battery.
If anyone you know is travelling past Cambridge I’m selling a circular saw and some ruler clamps. Just be careful if you’ve not used a circular saw before as it’s a bit more powerful than a jigsaw.
https://singletrackmag.com/classifieds/advert/tools-bench-saw-tyres-pedals/
Seeing what you’re saying through the thread, it’s up to you really how far you wanna go.
Because for this project you could very easily do it with a fresh panel saw. Osb cuts very easy by hand, you can rip across the top of an 8x4 in 30 seconds, for a tenner. (Actually two saws for £13 seems the norm now!). And by the 7th (probably sooner) sheet you’ll have developed a good technique that guarantees a straight quick cut. I’m a big fan of hand tools.
However, I’ve also bought into the makita cult. I’d do this job with my lxt circular saw. I probably wouldn’t bother getting the track saw out because I don’t actually need it that accurate, I’d just run the circular along a pencil or chalk line. I certainly wouldn’t use the jigsaw, even if I push it in a straight line the cut won’t be square and it’ll take me longer than a handsaw to produce an inferior result. And I wouldn’t use my table saw because I’m not waving an 8x4 sheet over that thing!
It won’t take you any time at all. Probably a lot quicker than clamping up guides and stuff.
Nowhere near as fun though!
I regulalry choose a panel saw over pwoered tools. btu a tracksaw would be through it before you managed to draw the straight lines to cut to. sand the cut will be smoother too.
But i do agree totally that a hand saw would be no biggy for this task.
2 strips of MDF, screw together with an overlap, measure the plate of your saw, Make a cut, make your own track. easy peasy.
What NeilGlover says. Handsaw and MTFU.
cicular saw with an adjustable guide. Set guide to 120 and its simple.
my neighbour is a furniture maker and joiner by trade but supplements with general chippying stuff as there isn't always a lot of work (eg: he does big houses and pub refurbs etc.)
In other words, he's a pro.
He helped me do my shed which was OSB in part. With a good panel saw (he recommended a bit more than a tenner each, and coated for use on composite type boards as the glue can make the blade stick*) - and a strong arm and technique - he was cutting through boards in the time it would take me to unroll an extension lead.
* failing that, a spray of wd40 every now and then
As a fan of buying expensive power tools myself, you should be asking: "what other jobs have I got to do?"
My usual pattern is: struggle doing the first job without having the best tool, then buy one for the second job. Having spent 2 minutes doing what previously took me 2 hours, kick myself for not just buying the right tool in the first place.
I have some Ryobi tools - mostly household stuff that isn't going to take too much abuse, and I'm happy with it - the cordless hot glue gun in particular gets used frequently for fixing the kids toys! I do also have the circular saw. It's fairly good: as above, the blade being on the left makes it very easy to use.
However, I've also got a load of Makita kit - including their track saw. It's awesome, and the Makita kit is noticeably more solid and better made than the Ryobi stuff - I'm expecting it to last for decades (it's mostly corded). I'd advocate for a track/plunge saw if you have the budget, and have other jobs on the horizon for which you could use it.
cordless ryobi vs corded Makita? I'd get the Makita.
If you're not likely to use it again for the forseeable, then I'd get the cheapest circular or plunge saw you can find. Track saws are awesome but you can replicate it easily just by clamping a straight edge on the board (which ideally I'd use one of my pile of random bits of wood but you could use one of your other boards for hte first cut, which will be horrible and cumbersome but will work a charm, then the offcut from the first for the future ones.
I don't like deterring people from buying tools, but, if you do this cheaply then you can spend the money on buying more tools.
B&Q and Selco will both cut them for you, why put yourself through it? (Just measure twice!!)
Handsaw
What's happened to this place! You's have changed man. 😐
Altendorf F45 ftw
OP, I'm sure this time last year was when Lidl had their tracksaw on special buy. Worth checking
G-series? I think the batteries now have a white top to distinguish them. Mine doesn't though. I'm considering buying the matching impact driver
I’m considering buying the matching impact driver
It looks like they might be winding that range down. There was supposedly a whole range of G Series stuff aimed at home / garden users - so thing like stimmers and hedge cutters seemed to be pretty short lived and currently Makita's site only lists a drill driver so even the impact driver might be discontinued.
Cutting sheet OSB yesterday, its evil stuff, spits sharp bits out,when being cut with a hand held circular saw so wear gloves and safety glasses, for obvious reasons.
Resist he temptation to run hands down newly cut surfaces.A set of plastic trestles also help to support the sheets when cutting, and an old door on top acts as a worktop, ask at Band q or Selco if they have any damaged doors or worktops going free or cheap
With the Stanley plastic trestles and probably others there are slots for 2" timber and when used they make a very sturdy working platform
Makita’s site only lists a drill driver so even the impact driver might be discontinued.
It's available as a bare tool from Amazon. It was really to make use of the batteries, rather than buying into another system. Another option is a Worx one as I have the pressure washer
Soon as I see the words 'one of them circular saw things'(or to effect, I get scared.
I feel that such power tools are not to be thought of as a power tool along the lines of a drill, jigsaw, impact driver or anything like that, it is a separate entity and by far the most dangerous tool available for professional or home use. I cannot emphasis that enough. That and the chop/slide saw. This regularly cuts fingers of joiners and carpenters, and they instinctively know the ins and outs of the tool.
The big one is one hand on the saw and the other hand they put under to catch the off cut from falling forgetting the projection of the blade. It's usually all fingers halfway up.
Im sorry to be vivid, but im a furniture maker(like others here), done the qualifications training under professionals on these specific tools. My approach to these things means I cannot stay silent(ahem) and must direct you to the other incredibly good suggestions of using a hand saw.
Which is satisfying enough to have fair working up an appetite, or if you feel its a bit of a struggle, a powered jigsaw and a straight edge. In fact that would probably be your best bet as the jigsaw on a fence will breeze through osb and the fence(straight edge) it wont wander.
To know A circular saw must have a riving knife as this prevents the cut closing on the blade and causing it to kick backwards towards the operator. It used to be the law that they must have a riving knife, but there are saws on the market without them in the form usually of a cheapo track saw. The technique of a track is you plunge cut and move forward so the riving knife descends with the blade can slide into the cut. The cheap its just no riving knife.
Try using that handheld in osb and it will bind and it will kickback. you tube will show you all the ways to operate the saw, plunge cutting mid board, angled cuts, but theres a whole aspect of safety to each of those operation
On you tube it looks very easy, but what are the inherent dangers ? again most buying one from b&q arent going to know.
My recommendation as a safety nut whoo approaches all machinery with the attitude its going to cripple me. So i do mentally prepare, Ok im doing this, this this etc. On a big machine its , where am i standing, anything impeding etc. Even for powertools like the hand held circular saw.
Not wanting to be nippy or offend anyone. Just saying from a safety basis the circular saw should be a pro only bit of kit, or unless you have prior experience,training or are very used to it. Straight off out the b&q box please dont. There are just too many things to know and can go wrong.
I agree with the above.
I'm comfortable around a lathe and mill even hands close to spinning Chuck as its a big stationary machine (though my intro to the machine is "it's designed to cut metal your fingers and hands are no threat to it".
Had to use the mitre (so) saw last week took a few cuts to be comfortable with the blade spinning and kneeling in front of it.
Don’t want to be a pedant, but the Mafell and Makita track saws do not have riving knives, in fact many hand held of any price range do not, I have a couple of Mafell one with and one without , MT55 and KS, they are not the cheapest , I also have the Parkside and that does not have one , anyway the real danger is a table saw - definitely the worst thing to have if you ever make mistakes , plunge/track saw is the least dangerous of all as the blade is guarded and has a spring to put the guard in place.
OSB is not a material to have any human contact with - harsh and splintery, and costs the same as cheap plywood so unless you absolutely have to use it for a particular reason I wood(sic) avoid.
What about moisture resistant MDF, easy to cut but dusty, doesnt splinter,and a superior smooth finish compared to OSB.
Where ? As I see it id have to come down to 9mm ply to get the cost comparuble to 18mm OSB.......
The joy of OSB compared to MDF is you can mount stuff directly .....tools/bikes/hooks etc
Also, you can set the depth that the blade comes out by using the stop. You can clamp the rail to the work piece. You can do a dry run of the cut without plunging (and ideally with the saw not plugged in). You can lock the plunge down and look from the side to double check your depth. Some saws have anti-kick back and the cheap Aldi/Scheppach one does have a riving knife.
That said they are a power tool and present an inherent risk. At the start of lockdown I was using mine to speed up cutting some pallets across the slats to make a temporary fence. Normally I use the saw with an MFT style bench top and clamps, dogs etc for cutting MDF, plywood and furniture board. But for the pallets I was just placing the rail on and cutting. On one cut the rail had moved slightly and the saw clipped a nail. This kicked the saw back off the rail and it gouged the rail. It could have been much worse. I immediately put the tracksaw away and got out the hand saw. Overall the job took about 10 mins longer, but was a lot safer. Lesson learned, sometimes power tools aren't the solution.
I would say that non-plunging circular saws are terrifying in comparison to plunging track saws. I don't like them
I think a lot of people have problems with circular saws as they tend to use them one handed. When they kick, its a lot easier to control them when you have them held properly.
Think about where you are standing, where the saw is going to go if it does kick back etc
Complacency is a big factor in accidents
I learned my less on with powertools when i plugged a brand new out of the box 4inch belt sander in.
Plugged it in and turned the socket on. The ****er shot across the roof to full extent of the cable before crabbing sideways in a perfect arc.
It came out of the box with the trigger latched on!
Right, I haven't bought a circular saw yet, or any other power tools.
I did have the wood delivered. Then my natural impatience took over and I decided to see what I could do with the only saw I have, a 300mm tenon saw.
Armed with a couple of clamps from Wilko and a long piece of scrap, I measured about 6 times and went for it.
It takes bloody ages to get through but I went slow and didn't cock it up. I've managed to scrape some paint off the floor and the ceiling as they're such a tight fit. They're also a pig to handle on your own.
The problem I have now is that I can't just whack them all up. I bought massive plugs designed for breezeblocks but the blocks are so soft that the plugs go in tight and then just spin loose. I decided to glue the first lot in with some Sikaflex (the only thing I had to hand) and that's done the trick. The first board pulled nice and tight to the wall and feels solid. The second lot of plugs are in and drying now.
I'll just cut one board a day after work then glue the next batch of plugs in. I'm not on a deadline so I'm not bothered. There's also little to no chance of losing my fingers.
Tomorrow night I'll be slicing board number 3, lining it up, drilling some 'oles and gluing in the 3rd set of plugs.
Looks great. Nice one 😀👍
Handsaws eh? Whatever next...
I know, it might actually do me some good! I was sweating buckets on each board. 4 more to go. Oh, and I have a door frame to negotiate. Not thinking about that yet.
I did my shed earlier lockdown, same OSB method and cut with circular saw, at first with a guide then freehand no worries. Built a frame from 2x4 to attach them, makes it simple to fix stuff too. Given that yours is directly against the wall won't you have the annoyance of drilling into the wall as well everytime you affix things?
Have you accounted for expansion?
18mm OSB is £16.85
18mm Shuttering ply is £16.80.
Handy. Entirely the wrong end of the country though and won't deliver. Prices round me (outside of the big sheds) seem to be 35 a sheet for OSB and 40 for ply.
