I need a shoe that ...
[Closed] I need a shoe that looks like a boot...
21 Users
I have to wear boots at work. I get given Altberg leather boots, but thay are currently playing merry hell with a sore achilles.
I need a recommendation for a low cut 'shoe' that will pass as a boot whrn worn with long trousers. It cant look like a toe-tector trainer, it has to look a little less casual.
Can anyine recommend anything?
Posted : 23/05/2018 11:02 am
It has to be a boot? Or it has to be foot protection? Look at executive safety shoes on Screwfix, they’re normal shoes but with steel caps.
Posted : 23/05/2018 11:16 am
It has to just look like a boot, so i dont appear to be walking around in a pr of trainers. I will check out screwfix, thanks
Posted : 23/05/2018 11:20 am
I have huge problems with some boot designs cutting into my tendons, others don;t do it at all.
One trick is not to lace them all the way up, I've found, but really just trying a number of designs is probably a good start.
Also consider looking at a built up heel insole - it moves the point the boot presses about a bit.
Posted : 23/05/2018 11:24 am
These any good? Dealer boot , what I wear at work. They don't rub my achilles unlike their shoes and 8 hole boots.
Posted : 23/05/2018 11:30 am
Is toe protection the requirement? Theres plenty of shoes, rather than trainers, with toe protection - Doctor Martens for instance
Being a bit like Argos - screwfix is a bit of an order-over-the-counter deal, unless they're pretty quiet they might not be able to accommodate looking at / trying on stuff.
Arco - as linked above - probably has the widest range of stuff that you can see and try on as you would in a shoes shop
Posted : 23/05/2018 11:36 am
may not just be toe protection .
i have to wear boots with support for risk of rolling an ankle as thats a risk highlighted on a facility wide risk assessment
Posted : 23/05/2018 12:39 pm
Timberland do some Chukka boots that could look like boots if your trousers overhang.
Similar, Red Wing make a Chukka that looks exactly like their round toe 6" boots from the vamp down.
Posted : 23/05/2018 12:45 pm
Or - depending on where you are have a trip to Altberg factory in Yorkshire to get fitted/customised?
Posted : 23/05/2018 1:24 pm
If it's not a health and safety thing then what about some desert boots?
But I don't see why they want you to specifically wear boots and not shoes of it's not H+S
Posted : 23/05/2018 1:28 pm
cut the back out ?
Posted : 23/05/2018 1:42 pm
Im in a uniformed occupation. There is a requirement that i loot the same as everyone else.
I may just cut a pair down and see what happens....
I cant wear a more formal shoe as it will look different, so needs to continue in that chunky vein
Posted : 23/05/2018 1:47 pm
Would a ankle brace negate the need for boots?
If you have to wear boots to work and you can't because of any injury you need to speak to occupational health/HR
Posted : 23/05/2018 2:09 pm
Your employer needs to understand that PPE is supposed to protect and not cause injury.
Why do you need to "look the same"? Surely it doesn't matter to that level of detail? If you boots are black leather, wear a pair of black leather shoes. Surely nobody cares that much?
Even squaddies wear different boots from each other at times.
Posted : 23/05/2018 2:34 pm
I wore KSBs for pretty much most of my time in the Mob.
Spotty Dog ( back then) IMHO.
So maybe try a pair of civie walking boots?
Lowa etc..
Posted : 23/05/2018 2:50 pm
Posted : 23/05/2018 2:55 pm
https://www.haix.co.uk
Posted : 23/05/2018 4:31 pm
It might help the OP if he posted a pic of the sort of footwear that’s required wear, then it might be possible to make more informed suggestions.
Posted : 23/05/2018 10:15 pm
Altberg sell shoes too
Look at Meindl Cambridge if brown is okay
Posted : 23/05/2018 10:24 pm
Got an Arco near you?
Posted : 23/05/2018 10:28 pm
Can it be a shoe cake?
https://m.youtube.com/watch?v=JM8quCF_Qkk
Posted : 23/05/2018 10:31 pm
Going to speak to HR / Medic people is probably the best way. You may get a sick chit allowing you to wear a more relaxed shoe.
I used to have to wear boots for work, we were issued boots but tended to wear our own. Magnum Classic being a very popular choice, were comfy as slippers.
Magnum also do a midi boot that may be worth a try...
https://www.amazon.co.uk/Magnum-Mens-Boots-Black-Schwarz/dp/B00IAM7HJC/ref=sr_1_11?s=shoes&ie=UTF8&qid=1527153459&sr=1-11&refinements=p_4%3AMagnum
Altberg also do a Midi boot....but I'd be very much looking at the Magnum boots.
https://www.tauntonleisure.com/alt-berg-men-039-s-malham-leather-walking-boots.html?utm_source=google&utm_medium=cpc&utm_campaign=Adwords&utm_content=Shopping&135=61&aid=14393&gclid=EAIaIQobChMI-9Sw0IKe2wIVBZztCh3rvgW_EAQYEyABEgKh3PD_BwE
Posted : 24/05/2018 10:24 am
