Roofrack woes 🙁 Now I need to source an M7 Bolt/Screw.
Google and previous training seems to be telling me I need M7 Socket-Button/Socket-Cap/Allen-Head-Cap ones. Ideally stainless-steel. Sadly Google is not telling me where to buy them 🙁
B&Q and Screwfix have also let me down (they don't do [u]any[/u] M7 stuff apparently).
Ebay have regular steel ones for $999.99 (yes that is the genuine price and 'people' are watching the auction)
Help! Can anyone point me in the right direction?
Google a local "fixings" supplier.
What make roof rack. You have to make sure you get the correct tensile grade. I remember Thule had a recall to replace some failing bolts a while back.
Blimey DD, that was quick!!!
Many thanks, I now have a couple of possible leads, but any more ideas gratefully received 🙂
M7 does seem to be a bit rare, looking a the places I buy from - Buck & Hickman or Orbital Fasterners - they sell taps for making m7 threads in holes but nothing you can actually screw into that threaded hole once you've done that
If it really is a M7, then SJS do a 20mm one.
...and http://www.a2stainless.co.uk/M7-x-1-00mm_B217L5.aspx
Beware as Jamie talks some rare sense there. M7 is unusual. All my Thule bolts have been M6 - and if I'm not mistaken, most mounting holes in car rooves are M6 as standard aren't they?
@Jamie - Yup, def M7. I was suprised as well, but managed to find a couple of M7 bolts that I thought would do the job. The thread is fine, but the head had to be 'modified' to make it fit and is a bit 'string and sellotape' so I need a better fix
@andyl - Worrying info as I know far to little about Tensile strength 🙁
PS - It's the car that dictates the thread. I tried M6 and M8, but when I called the roofrack manufacturers they were adamant that it was M7 and when I managed to buy the hex-head bolts they were a perfect fit :-/
No, no, I insist...it must be M6. 😀
@DD - Can I put your 'name' on the insurance document as a guaranteed source of info re the M6 bit? 😉
Glad to hear you got sorted. 20mm seems a bit short though, and I hope they are the correct tensile strength.
As an aside, do the roof bar manufacturers not offer spares?
They are actually about 12-15mm long so I need to cut them down hence the preferance for stainless rather than coated/plated
As for the roofbar peeps, it was roofbox.co.uk who seem great/helpfull :-), but they are just a dealer so spares are an issue
Tensile strength is still making me 'twitch' though. Can you point me in the direction of any knowledge?
Posting from a position of engineering ignorance would the fact most roof bolts are M6 while yours is M7 and therefore beefier not be enough insurance?
Its not M7 - its 1/4" x 28 otherwise known as 1/4"UNF. Tensile strength should be 12.9, don't use stainless - go with nickel plated steel.
I am not sure about using stainless for load bearing bolts where a failure could Cause the rack to fail. Here is some info I found
http://www.volksbolts.com/faq/basics.htm
I would be looking for high tensile bolts tbh if they are under any stress
Yup!
Contact Thule with your woes about they're great product they have a good history of customer service so may well send you some.
Drill it out.. tap it M8. Job done
Not a very safe product though, the Thule bolts I had regularly snapped letting the bike carrier depart from the roof of the car and each time Thule just said 'yes, it happens a lot' and posted out a new bolt which then snapped a few months later....
Hmmm more ideas/comments since last night. In summary
Its def M7. I borrowed some calipers and dug out my old engineers ref book and it is not 1/4"UNF
It's a lease vehicle so drilling and tapping is not an option
It looks as if most of the 'load' is taken elsewhere, I 'think' these bolts are just there to stop the roofrack sliding round a bit so shear stregth is the most important bit
It's not a Thule rack so they would not/could not help (although I do have 2 thule racks in the garage from previous cars so could try a blag, but the comment about thier bolts breaking above puts me off a bit...)
Looks like I need High Tensile bolts from a local company that I can ask questions (for such a small sale value as well, I already feel sorry for them)
Ah not sure where I picked it up it was a Thule one from.
I've had Thule bars and carriers for about 17 years now and never had a bolt snap. 😀
