I hate Halfords eve...
[Closed] I hate Halfords even more now.
28 Users
So, there I am overhauling the drivetrain on my road bike when I get to one very reluctant bottom bracket. My isis tool isn't all that and I needed it out to get the HT cups and other bits in.
The nearest bike shop is Halfords, I thought I'd pop in and they'd sort it. Then when I'd ask how much they'd say.."err, a couple o quid?" like a normal lbs.
No, he consulted a f*cking chart and it was £9.99!?
I should have walked the extra distance to a proper shop 😐
Posted : 29/06/2011 3:26 pm
Seems fair to me
Posted : 29/06/2011 3:28 pm
can't think of many shops these days where it wouldn't be £5-10
Posted : 29/06/2011 3:29 pm
tight geyt
Posted : 29/06/2011 3:31 pm
Just in case this isn't obvious - if it is like my cheap isis bottom bracket tool, it has a hole in the middle. Usually you can just bung it on and spanner off the BB, but if it is tight, you can put a rear skewer through the hole, tighten up the skewer to hold the tool on, then give it a good hammering (or I have an old piece of metal pipe that gives me a 3 foot level on the end of the spanner).
Without the skewer, I couldn't get one side off at all, and was pretty close to damaging the BB bits. With the skewer and the pipe it was dead easy, off in no time.
Joe
Posted : 29/06/2011 3:37 pm
Jusk ask to quickly borrow the tool... you tool.
Posted : 29/06/2011 3:42 pm
Maybe it's the generosity of my usual LBS then. Seems a bit tight to charge a tenner for a 10 minute job (he made a meal of it), which would have been 5 minutes at Baker's. They've done small jobs before without wanting any payment.
Tracknicko, you may want to lube your hinges if your gate's too tight. It'll probably seize soon. I'll do it for £9.99 if you like?
Couple of quid to remove a BB? Workshops doing jobs that cheaply won't be around for long.
Posted : 29/06/2011 3:43 pm
JM it was pretty seized. My remover sounds the same but it wasn't happening. The lad had to give it all he had with a fairly sizeable spanner.
TSY 🙄
Posted : 29/06/2011 3:47 pm
Maybe it's the generosity of my usual LBS then. Seems a bit tight to charge a tenner for a 10 minute job [b](he made a meal of it)[/b]
As oppose to how well you were doing it but you thought you'd give it to Halfords just so they can get some practice? 😉
its people like you expecting work done for **** all that wrecks small bike shops mate.
countless times you have people bringing a bike with a stuck bb into the shop, expect you to take it out for £1.20, and then when the shitely maintained heap of crap strips the threads in there it's most definately the shops fault.
sorry mate but i think you're wrong on this one. if £10 is too much, buy better tools.
[i]buy better tools.[/i]
this.
plus you're not paying for the 10 minutes you're paying for the experience that meant he could get it out and you couldn't.
Posted : 29/06/2011 3:53 pm
^ which given that you went to halfords is a double fail on your part!
Posted : 29/06/2011 3:54 pm
I've never heard of Halfrauds being defended on here but I guess it's more the pricing.
I personally think a bike job's price should be largely defined by the time taken to do it. Baker's sorting out my rear wheel for £12 seemed like a bargain as it must have taken a little while to finish, therefore a 10 minute (should have been 5) job for £9.99 is inconsistent to me.
And yes I am cheap, I can't afford to be otherwise!
Ok fine, better tools.
Are you ready.....................................I was wrong.
Posted : 29/06/2011 3:56 pm
if you came in any of the shops i have worked in and asked me to get a stuck BB out. i guarantee you would have been quoted AT LEAST £10
Posted : 29/06/2011 3:57 pm
But fwiw double fail=win.
He had the tools, experience and where-with-all to complete a task that you couldn't. £9.99? Bargin!
Posted : 29/06/2011 3:58 pm
and this is why it's worth supporting your LBS otherwise all you get is BS
Maybe you could have sent it to CRC?
Posted : 29/06/2011 4:01 pm
CM, that's what I was getting at. Unfortunately Halfords is nearer than the shop I usually use and the bike I would ride there on was not a bike.
Lesson learned.
Posted : 29/06/2011 4:02 pm
The price charged reflects not just what it costs them, but the value of the work to you. If you don't want to pay ten quid, do it yourself. You can't do it yourself, you say? That'll be ten quid then, mate.
Bloke comes out of his house and walks across the road to the corner shop, asks "a bottle of milk please." Guy behind the counter says, "that'll be £2 please." Bloke replies "two quid? It's only 89p at Tesco!" Shopkeeper tells him, "well, go there then." Bloke says "I'm not trailing all the way across town for a bottle of milk, what do you take me for?" Shopkeeper replies, "fair enough. That'll be £2 then."
Ultimately, they're a business, not a charity. An LBS will do a five minute freebie in order to secure repeat custom, and it works; you'll tell all your mates, and go back there when you want a new bike. Much as you like to think so, they don't do free work out of the goodness of their hearts. Halfords et al work to a different business model; they're more like a supermarket, they don't need customer loyalty because they've got a bloody big warehouse on a retail park that's open all hours.
I fail to see the correlation between someone asking for a favour to remove something they can't and LBS's going under.
IME if an LBS is kind enough to not charge me £10 for a 10 min job, the more likely I am to return to said shop and buy stuff I would have got elsewhere because I know i'll get good service.
Posted : 29/06/2011 4:05 pm
I think a lot of people only go their LBS for jobs thye've tried (and failed) to do themselves.
Fair enough if you've been there before and they know you. but to turn up and expect them to do you a favour, that if the thread on the BB shell gets kjnackered you'll blame them for, is a big ask.
I don't use my lbs very often at all - I'd rather buy the right tools and learn to do the job myself. But if I ****ed something up and went to them I'd expect to pay top dollar to get it sorted out.
Posted : 29/06/2011 4:08 pm
We are currently in the W2W coast to coast route. Last saturday evening MrsPPs front tube blew up at a campsite and blew the tyre with it. We need to be moving on Monday. The LBS in Barnard Castle doesnt open Sunday or Monday so we took a bus into Darlington. 3 proper bike shops. ALL CLOSED. Only Halfords was open and they had just what we needed.....
Posted : 29/06/2011 4:10 pm
I get this a lot in IT. Have-a-go heroes turning a five minute job into a day's work. My cousin used to ring me up, "my printer wasn't printing blue properly, so I reinstalled Windows, and now..."
Posted : 29/06/2011 4:11 pm
Nope, don't agree. LBS is answerable pretty much to themselves, so will often do a favour with no expectation at all. Same way I would if a neighbour knocked on my door and asked for a hand with their nbike.
thanks wwaswaswas.
you arent asking a shop to fit some new bars, or a bell.
you are asking them to remove a BB that YOU COULDN'T REMOVE.
if ever there was a job with potential pitfalls...
how much would you expect to pay for a stuck seatpost?
bout £2.20 no doubt.
Posted : 29/06/2011 4:12 pm
With that attitude, no wonder you went to Halfords to get a job done you couldn't do yourself, you champion amongst men
Posted : 29/06/2011 4:13 pm
Good old Halfords.
Posted : 29/06/2011 4:14 pm
Yeah, but you've only ever worked in Harrods and Fortnum & Mason
Posted : 29/06/2011 4:15 pm
Nope, don't agree
Depends on the LBS / individual, of course. So we're both right, or wrong, depending on context.
Posted : 29/06/2011 4:21 pm
Yup, in the context of you, you're wrong. In the context of me, I'm right
Posted : 29/06/2011 4:25 pm
You speak for all mechanics in all bike shops across the land?
Wow.
Posted : 29/06/2011 4:28 pm
No, I speak for you!
Posted : 29/06/2011 4:34 pm
You know even less about me than you do about bike shops.
Posted : 29/06/2011 4:56 pm
If the price menu chart said £10, and if Halfords, like most big shops, use mystery shoppers, then the guy doing the repair could have been disciplined for not charging you.
Posted : 29/06/2011 5:07 pm
£10 = fair price. Telling you "a few quid" then charging you £10 = a bit cheeky. This is not a Halfords exclusive though.
Personally I've better experiences on average with Halfords than with LBSs, I've had incompetence from Halfords but never deceit and I prefer fools to frauds.
Posted : 29/06/2011 5:10 pm
Biggerbutslimmer bloke; I was trying to add some humour to an oddly serious discussion about something in the past. I had already acknowledged being wrong but noticed the double negative. Lighten up, no need to be condescending.
Posted : 29/06/2011 5:29 pm
I really doubt that is true
Posted : 29/06/2011 5:40 pm
businesses are that charities are that the shops closed on the high street did for a reason. we have a clear chargeing structure ( heating engineers) we come we look we offer advice for nowt we open the tool box thats £45 ( first hours labour) most jobs done for under £50 virtually all plumbing repairs done for less tha £100 parts and labour. by been clear i chargeing everyone the same everyone knows what to expect including the boys who work for me ie they ll get paid every fourth thursday
Posted : 29/06/2011 6:27 pm
Halfrauds are $hite.
Posted : 29/06/2011 6:55 pm
The work cost you two pounds, Halfords charged you £8 insurance in case the job either grew arms and legs or ruined your frame.
Posted : 29/06/2011 7:37 pm
It can't just be me who's confused by this.
You can't do the job yourself
You go to someone who can and ask for a price for them to do the job.
They quote price.
You accept price.
Job gets done - to your satisfaction?
And you hate them for doing it?
The STW barrel is pretty deep, well done for scraping the bottom of it.
And, BTW, I'd stay clear of plumbers if I was you.
Posted : 29/06/2011 7:47 pm
I think their price isn't just for the job.
what if the man had said "here i'll do it for a couple of quid mate", then wrecked your frame? would you have walked away? or claimed on their insurance?
I still think a tenner is a bluddy rip off though!
Posted : 29/06/2011 7:51 pm
The tenner is for a man, with the tool, in a room, with light and heat, open for 12 hours a day, for your walk in walk out convenience, who is insured incase he does harm or damage to you. He has to have change, a machine for accpeting your cards, provide a warranty on repair, and account for VAT and any other relevant taxes, as well as sundires like the squirt of wd40 it needed.
Its not a case of "just getting the right bolt", its all the above.
The fact is any car repairer will have a minimum charging time, of 15m, even if it is just to fill a washer bottle or something, yet you dont "hate" Volkswagen". And VW charge up to £200 per hour in southern city locations. A tenner is nothing. Its not even 3 beers, and about half an hour on the minimum wage.
Posted : 29/06/2011 9:18 pm
And so are statements like that. Means nowt. Apart from that there's a good chance you're a snob.
Posted : 29/06/2011 9:21 pm
mimimum wage is £20/hr? 😯
Posted : 29/06/2011 9:22 pm
Halfords are far from shite nowadays, the one near me is pretty damn good for most bike parts (full rrp though), well stocked and the staff are very friendly, plus I can get (in stock) Thule roof rack bits and bobs and as I discovered today everything I need to tart up a weathered carbon frame.
Try getting all that at your LBS.
Posted : 29/06/2011 9:27 pm
buy a tool and do it you self . 10 squids not that much ffs
Posted : 29/06/2011 10:04 pm
what solver to do an FEM study on threads stripping from a frame then nicko? 😆
ps you coming to longnor then?
Posted : 29/06/2011 10:11 pm
Whilst I applaud the OP for his admission of error, and whilst I also think he's had enough of a written beating.....,
Jujuuk68 - Member
AMEN! In fact, if you don't mind Jujuuk68, I might pinch that quote and use it as an analogy to those who expect free/very cheap photography - the similarities are startling!
"Well you've already got a camera, it'll only take you ten minutes you tightwad".... Erm, no, I've got to feed my family and replace all this gear once every two years, pay for promotion and marketing, my business insurance is double the cost of my car insurance... And in fact, never mind all that (and the rest) I put five years of my life into learning how to do what I do - what price the ticking seconds of my life?
That last question was rhetorical BTW...
Posted : 29/06/2011 10:34 pm
But luckily we now know the answer is £1,000,000
Posted : 29/06/2011 10:36 pm
How come I'm bleedin' skint then?!
Posted : 29/06/2011 10:38 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=27037&utm_source=google&utm_medium=shopping&utm_campaign=Google-Products-UK ]£12.99 for your very own park isis tool so you can do the job many times over. X[/url]
Posted : 29/06/2011 10:40 pm
you need to ask Rospa
Posted : 29/06/2011 10:41 pm
