How to replace/fix ...
[Closed] How to replace/fix inline water valve?
5 Users
Just fixed a toilet cistern that required me to turn off the water at the inline valve. However, now that I have used the valve, it has started to leak around the middle (where the screwdriver slot is). It isn't bad but it will need fixing - so how to do it without turning off the supply to the house?
Any ideas / tips would be most welcome.
Posted : 09/02/2013 7:39 pm
not easily
i'd just turn off your water at internal stopcock, open upstairs and downstairs taps to drain system, flush toilet a few times to drain that pipe, then replace the inline valve
30mins work tops for a DIYer (assuming you are not a bodger)
Posted : 09/02/2013 7:44 pm
freezing if you cannot turn off the main stop tap.. but be quick!!!
Posted : 09/02/2013 7:59 pm
Sunday bump
Posted : 10/02/2013 11:23 am
have you tried tapping, and I mean [i]tapping[/i] the slotted cicular section with a spanner or similar? It does stop it if it's only a weep..
Alternatively turn the water off at the stopcock, freezing the pipes in a house is pointless, as it'll be copper, and as the ice plug in the pipe expands it'll split the copper. (Same as it bursts external pipes)
Ben.
Posted : 10/02/2013 1:09 pm
 Bear
If minor weep on isolating valve, then leave it for a few days to see if it 'takes up'. Failing that turn off water and simple job to replace, although can be fiddly beneath a WC cistern.
Benn - you can freeze copper pipes, in all my years only caused one burst with my freezer kit.
Posted : 10/02/2013 1:43 pm
