how to remove stuck...
[Closed] how to remove stuck down lino?
16 Users
The edges are stuck down like a bastid, can't get the scraper underneath.
Hot air gun?
Posted : 25/03/2017 4:15 pm
Start at the door
Use a spade.
Posted : 25/03/2017 4:53 pm
 tomd
I had a similar problem recently except with cork tiles. The best way I found in the in the end was going bezerk with a bolster and a lump hammer. If there's a better way I'd love to have known, they were impervious to a hot air gun and broke anything less than a bolster.
This:
http://www.screwfix.com/p/roughneck-brick-bolster-guard-4-x-8-/55448?kpid=55448&cm_mmc=Google-_-Product%2520Listing%2520Ads-_-Sales%2520Tracking-_-sales%2520tracking%2520url&gclid=Cj0KEQjwqtjGBRD8yfi9h42H9YUBEiQAmki5Oqxjgz9ZnyNm8JFPkGQ1wxFpUu4BTzzPq8hqSXGVYusaAsSa8P8HAQ&gclsrc=aw.ds&dclid=CPCds8eR8tICFQKnUQod6cYHAg
and
http://www.screwfix.com/p/forge-steel-fibreglass-handle-club-hammer-4lb/7025c
Posted : 25/03/2017 5:02 pm
Posted : 25/03/2017 5:05 pm
Boiling water and a spade . Honestly it does work .
Posted : 25/03/2017 5:11 pm
Cheers good stout about the spade
Posted : 25/03/2017 5:28 pm
I tried everything ! In the end it was the spade that did it ( eventually ! ) Destroyed my Dutch hoe in the interim , finally brought in the big guns ! Took me a fair few goes over quite a few days mind , hands hurt like buggery for ages after ! Good luck !
Posted : 25/03/2017 5:54 pm
on the third day I decided to rip up and replace the floorboards
Posted : 25/03/2017 6:19 pm
Spade
Posted : 25/03/2017 6:20 pm
You brought in the Dutch hoes? did that help?
Posted : 25/03/2017 6:29 pm
Far too much talk of Dutch Hoes. Clearly not the right approach. Chap up there reckons he's destroyed one. 😯 That won't come without complications.
My brother had a Westie some years ago, that had no problem taking up the whole kitchen floor one afternoon.
Posted : 25/03/2017 6:40 pm
[url= http://www.toolstation.com/shop/p61818?mkwid=s22l43ki0_dt&pcrid=142002554548&pkw=&pmt=&product=61818&gclid=Cj0KEQjwqtjGBRD8yfi9h42H9YUBEiQA ]floor scraper[/url] worked for me (not this particular one but of this ilk) through you still need to get under a tile to start with
Posted : 25/03/2017 7:27 pm
Get a proper floor scraper/blade - far simpler and a lot less work.
Posted : 25/03/2017 7:29 pm
Has anyone suggested nuking it from orbit yet?
It's the only way to be sure.
Posted : 25/03/2017 7:34 pm
Can I avoid breaking my hoe by laying laminate on top of the vinyl?
Posted : 25/03/2017 7:35 pm
We used an oscilating multi tool thing to get the stuff up in our place. Took a couple of days. But with the right blade you could just go through wherever you wanted. Then work out to the edge.....
Posted : 25/03/2017 7:40 pm
Posted : 25/03/2017 7:42 pm
I've only got a small area to do, reckon the boiling water will soften it a tad and spade will do it..... 🙂
Posted : 25/03/2017 8:34 pm
Wilburt.
Then afterwards if you want carpet just lay that onto the laminate. Repeat adnausem until you don't fit into the room anymore....
Get it removed propper.
Posted : 25/03/2017 8:54 pm
Update.
Spade and boiling water worked but was still a bi*ch to get up...
Cheers for the advice.
Posted : 08/04/2017 7:56 pm
I guess if you already got it up, my suggestion will be too late, but when I had to do an entire, large kitchen floor with every square centimetre stuck down with kind of super-duper glue, I found part way through that a heat gun worked magnificently.
[img] http://s7g3.scene7.com/is/image//ae235?src=ae235/2263J_P&$prodImageMedium$ [/img]
Posted : 08/04/2017 8:09 pm
Heat gun was my first thought and maybe would have been less messy 🙂
Posted : 08/04/2017 10:01 pm
