I need to remove some render from the top of a wall,what's the best method?
Hire a smaller breaker from your local hire centre
or the old method of a lump hammer, bolster and
Plenty of elbow grease
you could have had it put on by the people that did ours a few years ago.
It's now falling off of it's own accord! 🙁
I'd recommend a SDS drill with a wide chisel bit!
+1
Get a cranked chisel bit, less chance of getting a bit carried away and taking the wall out as well 🙂
Hire something like this with a chisel bit [url= http://www.toolgurus.co.uk/milwaukee-kango-900k-k-steel-10kg-heavy-duty-breaker/ ]Kango Hammer[/url].
I worked on a building site when I was 16 and spent about a month using one of them to remove render from a tenement block in Glasgow.
I did mine with a big SDS (with roto stop) and a scutching chisel.
be very careful at the top of a wall, you'll easily loosen the top courses
