How to open an Astr...
[Closed] How to open an Astra?
11 Users
Hello
Brand new Opel Astra hire car I know nothing about.
The key won't open it, new battery tried, still nothing.
There is a metal key which is supposed to go in a slot under the driver's door handle but doesn't.
Hire company not being terribly helpful and the breakdown details are in the glovebox.
Any ideas?
Thanks
Posted : 28/05/2022 4:50 pm
Did the key ever work?
Posted : 28/05/2022 5:09 pm
Brick?
Posted : 28/05/2022 5:19 pm
Is this the first time you have parked it after leaving the hire co?
Possible you have the wrong physical key ?
Posted : 28/05/2022 5:21 pm
In older ones the locks seize, but can't imagine that's an issue with a new one. 🙁
Posted : 28/05/2022 5:22 pm
Taking the battery out of the fob can sometimes mean the key needs to be re-paired with the car again which can be a back to dealer thing
the hire company should at least be able to tell you what the breakdown policy details are as they’re the ones who issued the policy
Posted : 28/05/2022 5:23 pm
Get back on to them, tell them to come and collect it and drop off something else.
This is precisely the point of hire vehicles, it isn't and shouldn't be your problem.
Posted : 28/05/2022 5:47 pm
Should be a small slot under the end of the drivers door handle , slot key into it and twist up to remove the plastic cap. This exposes the lock. Open with key as normal. Key should re-sync itself when you put it in ignition.
Posted : 28/05/2022 6:19 pm
Erm, passenger side for the key - it is on Nissans.
Posted : 28/05/2022 6:22 pm
Keyless entry keys are passive RFID. The energised coil is in the car .... So you can remove battery and it'll still open the car. The blades for when the car battery is flat - hence why I'm asking if he's ever been able to open/start the car after leaving the hire co.
Posted : 28/05/2022 6:35 pm
That's it.
The key wouldn't go in as it was just a slot which hid the bit where the key goes, not the actual key hole, get that cover off and then key goes in
Easy when you know how.
Thanks all
Posted : 28/05/2022 10:23 pm
I suspect that particular skill set has been lost by the current generation of "yoofs"
Posted : 28/05/2022 10:50 pm
That’s it.
The key wouldn’t go in as it was just a slot which hid the bit where the key goes, not the actual key hole, get that cover off and then key goes in
Thanks all
You don’t see the woods for the trees sometimes. 😁
I got a call from the wife saying my T6.1 alarm was going off as she had opened it using the key as she said there wasn’t a button on the fob to unlock it. It has electric boot and doors , and there are symbols of the doors and boot on the buttons. You press the boot button once to unlock (and again for 3 seconds to open boot).
I did laugh, as I had done exactly the same thing the day I bought it (except I knew to put key in ignition to turn the alarm off) 😉
What are those new Astras like to drive ?
Certainly come on a long way since my Mk2 1.6 SR
Posted : 28/05/2022 11:34 pm
Sort of. The keyless entry requires a (charged) battery in the keyfob to operate.
If the battery dies you need to use the mechanical lock to get into the car, but there will be a key reader somewhere (cup holder usually) that will energise the key enough to start the car.
Posted : 29/05/2022 9:49 am
