how to know if your...
[Closed] how to know if your gmail account been hacked?
6 Users
I've been nosy about my account settings and some of the features and I checked recent activities.. it is showing has been logged on last Jan 5 and 18 in Daventry with BT IP address.
Never been to Daventry of Northampton area in 3 years... Im from Cov 🙁
changed password and 2 step verification now 😐
Posted : 20/01/2015 6:50 pm
Where's your isp located?
Posted : 20/01/2015 7:04 pm
 Yak
Roaming ip thingy. Probably not hacked
You should enable 2 step verification if you're not already using it. You'll be notified if a new device tries to log on to your account.
Posted : 20/01/2015 7:18 pm
what is roaming IP thingy? ...might be, I am BT as well.
just enabled the 2 step verification thingy as well
Posted : 20/01/2015 7:21 pm
 Yak
Sorry, the term is dynamic IP. You get a different IP whenever you connect. The IP could be located at some distance from you. You may spot a repeated pattern of distant locations depending on your use/times etc.
Posted : 20/01/2015 8:09 pm
Where does this app say you are?
http://ipcim.com/en/?p=where
Posted : 20/01/2015 8:18 pm
 Yak
Daventry or Northampton I suspect 😉
Posted : 20/01/2015 8:19 pm
If you're accessing via a mobile phone, you can get false locations.
Also, BT are sharing IP V4 addresses, or something like that, leading to location issues.
And, yes, turn on two step verification.
Posted : 20/01/2015 8:26 pm
thanks all, I think I can sleep better tonight now after reading what dynamic IP address is.
Posted : 20/01/2015 8:32 pm
