if you want to use solar PV to charge your car your system needs to generate at least 6 amps
To charge from 100% PV, that's correct for my EV too. To be strict, I need 6A (1.4kW) at the car, but it doesn't all have to be from the PV. I have a Zappi charger with 'Eco+' mode that only charges if at least 1.4kW is available from PV, and 'Eco' mode which will use PV when it provides a percentage (that I define) of the charge. I use Eco mode on 50% when the PV isn't adequate to get 1.4kW; last week, for the first time this year, the PV has been producing enough to use Eco+.
Buy an electric kettle with a temperature selection button on it.
I had no idea such a thing existed!
How do you make green tea? Kidding.
They’re quite neat. And I found a reasonable one for much cheaper than the regular boil-until-room-steamy one I’d had my eye on.
They are very confusing for elderly relatives though. ‘Your kettle is too complicated’
We got one from aldi.
It is great for fruit teas, green tea and making coffee so it doesn't taste burnt.
What product are people using to insulate their suspended floors? Beside the obvious don't use foil backed stuff google just seems to suggest using overly fancy/expensive jute based eco hipster warrior stuff.
Standard loft insulation is the best bang for buck and fairly easy too - just shove between the joists and staple sheep/wire netting (or similar) underneath to hold it in place.
You can use celotex type stuff but realistically you need to do it from above and it's a bit of a faff.
