How much weight can...
[Closed] How much weight can I lose in 3 weeks?
59 Users
After going back up to almost pre iDave weight, after next weekend I will have three weeks til my holiday. What do you reckon I will be able to lose in three weeks?
Posted : 22/06/2014 10:52 am
*pulls up chair*
Posted : 22/06/2014 10:55 am
Actual loss of body fat, about 6 pounds sensibly if you're very diligent
Much more possible through dehydration but that's not sensible
Posted : 22/06/2014 10:56 am
3kgs
Posted : 22/06/2014 10:57 am
Are you going as hold luggage or something and paying by the kg?
Posted : 22/06/2014 11:00 am
*pulls up chair*
*pulls up chainsaw*
How much does a leg weigh?
Posted : 22/06/2014 11:07 am
6-8 lbs.
Posted : 22/06/2014 11:12 am
Stone a week by eating green salmon
Posted : 22/06/2014 11:24 am
15kg in 2 weeks.
I did have dysentery and was knocking on the gates at one point.
Not a sensible diet plan.
Posted : 22/06/2014 11:45 am
No we are going to America where I can get jeans I like for really cheap. I just don't want to have to buy fat sizes 🙂
Posted : 22/06/2014 11:51 am
3-4kg last week due to a milder version of what bigblackshed had. I had an intolerance to food...
Posted : 22/06/2014 11:52 am
Gastroenteritis for the last week has helped me shift some weight, not recommended.
Posted : 22/06/2014 11:54 am
 poah
either catch a disease or stop eating
Posted : 22/06/2014 12:02 pm
So that'll be the iDave diet added to the list of fad diets that dont work. Meanwhile my exercise loads and eat a sensible normal diet has seen me got from 15 stone to 11 stone and keep it off. Surprising that.
Posted : 22/06/2014 12:07 pm
How many limbs can you afford to lose?
What jeans?
Posted : 22/06/2014 12:25 pm
You seem kinda awesome.
Posted : 22/06/2014 12:29 pm
For jeans?
Any way multichoice answer:
A You are propellerly committed to long term change and you can start loosing weight at a sensible rate now. Buy the jeans in a suitable size and they should fit s in a month or so
B Start starving yourself now. Arrive America and squeeze into jeans on first day and buy loads. Generally trough out in America as the portions are huge, your on holiday and your body has just left a famine. Return from holiday and place jeans in draw and never have to worry about them wearing out...
Posted : 22/06/2014 12:35 pm
It worked within the parameters that iDave presented it, which was rapid weight loss as a short term aim - such as in preparation for a sporting event. It was a fairly draconian short term eating plan that you could only really sustain for a finite time because it basically condemns you to only eating food you've prepared yourself (it was surprising how many people on the first idave threads couldn't cook but hadn't really realised). It was also a diet which took for granted the fact that you exercise already because his clients are sportspeople. So if Mols is back to his pre-diet weight that may be because he's not dieting, not the diet not working.
Posted : 22/06/2014 12:38 pm
You keep telling yourself that. 😀
Posted : 22/06/2014 12:44 pm
I can if I like. I've never been on a diet though. I found the threads interesting because of the recipes that cropped up and the culinary challenge it creates - it set some interesting parameters to cook within, some of which have become a bit of household staple now.
Posted : 22/06/2014 12:46 pm
6lbs
Posted : 22/06/2014 1:07 pm
I've recently lost 32lbs of pizza & cake in 10weeks. Go me. 😀
Posted : 22/06/2014 1:30 pm
A top tip for this would be to eat less and move more, probably.
Posted : 22/06/2014 1:50 pm
you say that like it's a bad thing!!
Posted : 22/06/2014 1:53 pm
You could lose 3kg, then buy jeans which will be too small for you by the end of August.
It didn't work, long term, for molgrips, but that's because he's a precious flower or something 😉
Posted : 22/06/2014 3:05 pm
It's because it's a diet not a lifestyle change.
Eat (insert fad food item) and nothing else = drop a load of weight. Return to "normal" and put it all back on.
Eat sensibly and exercise moderately and you will drop some weight and become fitter. To drop more weight, either eat less or move more.
There is a whole load of anomollies surrounding eat less / move more, that will give differing results for different people. Some are sustainable, some aren't.
I can offer shed based liposuction with a rust knife and an industrial vacuum if you're desparate. PayPal Gift and no questions. 😉
Posted : 22/06/2014 3:31 pm
I thought he was a unique snowflake?
Posted : 22/06/2014 3:35 pm
What jeans?
Only two think he might need his legs
Posted : 22/06/2014 3:38 pm
I always had him down as a 'delicate sunflower'
Posted : 22/06/2014 3:57 pm
Sunflowers are hard as nails.
Precious Passat?
Posted : 22/06/2014 4:06 pm
 hora
Fasted rides
Re teach your body to eat fat. I.e remove carbs from diet
Posted : 22/06/2014 4:09 pm
 ton
6lb in 3 week is a good figure.
Posted : 22/06/2014 4:13 pm
 poah
hora - Member
TBF your body knows how to metabolise fat, it doesn't need taught lol
Posted : 22/06/2014 5:09 pm
Forget the weight loss, be yourself....
Posted : 22/06/2014 5:25 pm
Have you considered the Class A Drugs Diet? Not only effective, but bloody good fun too!
The only downside is the expense.
Posted : 22/06/2014 5:29 pm
Posted : 22/06/2014 5:51 pm
Posted : 22/06/2014 5:53 pm
It's ok, he means the inevitable hookers. We all know the drugs are cheap.
Posted : 22/06/2014 5:54 pm
It can get better at it though, like most things it can be trained and improved.
Aww, thanks 🙂
It works unless you end up using more carb than you can eat in low-carb form. Which for me was quite easy.
We ain't all the same inside.
Posted : 22/06/2014 6:18 pm
I'm not sure mine can
Well its at a much lower rate than many. We had a few cycle touring holidays when we couldn't quite get the righy. That split the 4 of us into 2 pairs. The fat metabolisers were out of site...
Posted : 22/06/2014 6:31 pm
A work colleague just dropped two stone in eight weeks, which is 12kg and 1.5kg a week. It doesn't look like he did it in a linear fashion though; seeing him a few times a week it looked like he's dropped quite a bit more in the last three weeks than he did in the first five.
A kilo a week seems to be reasonable.
Posted : 22/06/2014 6:38 pm
Seeing as you're a space cadet, build yourself a space ship and lose all your weight. 😉
Posted : 22/06/2014 6:45 pm
So if you stopped exercising loads, and eating a sensible diet (like molgrips stopped doing iDave) would yours continue to work ?
Posted : 22/06/2014 6:54 pm
the iDiet definitely isn't lo-carb though. If anything, it's hi-carb. Which makes sense, because it's for people who are training or doing a lot of exercise. Perhaps that's where you went wrong!
Posted : 22/06/2014 7:26 pm
Not in theory, but in practice it is lower than a traditional diet simply because you can only eat so much, and replacing starchy high carb foods with veg and legumes doesn't give as much carbs in total.
Not only does our ability to burn fat vary, but the way we ride varies too. If you get two people of the same weight riding the same hill they might be using different amounts of fat due to maybe physiology, or maybe why they've eaten that day. Not only that, but there are a few feedback mechanisms that govern how the fat gets replaced from your food, which will be different in different people too.
I know exactly where I go wrong.. Too inconsistent, periods of not much riding, periods of short intense riding and periods of sppradic long rides. Very hard to adjust diet for that..
Posted : 22/06/2014 7:44 pm
Why on earth would I want to do that? I get to eat cakes and pies, drink beer and ride my bike.
Posted : 22/06/2014 7:47 pm
I think you've lost track of the argument there wan 🙂
Posted : 22/06/2014 8:06 pm
What jeans?????
Posted : 22/06/2014 8:14 pm
Nah, I don't think so. The thing with fad diets like the iDave diet and any other that you care to mention (basically any eating advice with a capital letter in it) is that people dont stick to them because they are boring or not all that pleasant long term, or they stop you eating stuff that you like to eat. A healthy balanced diet coupled with enough exercise to create an optimal energy balance is the only way to lose weight and keep it off long term.
Posted : 22/06/2014 8:15 pm
Aaaaaand we're off.
Posted : 22/06/2014 8:26 pm
IDave isn't a fad imo. He just said eat low GI, really. It's not hard. Just a lifestyle change. If you think it's a fad you haven't understood the principles.
Well of course. Given that I like to eat cakes and sweets, I think most diets would do that. 🙂
Posted : 22/06/2014 8:45 pm
 JoeG
If you enter the US on foot from Mexico as is currently in vogue, you could lose quite a bit of weight on your way north! 😉
And you can lose even more at Gitmo! 😆
Posted : 22/06/2014 9:04 pm
I did 10kg in 2 weeks a few years ago. I did ride over 2000 km in that period though...
Posted : 22/06/2014 9:16 pm
Posted : 22/06/2014 9:31 pm
9 lbs in 9 days on aloe Vera detox clean
Posted : 22/06/2014 9:37 pm
I started yesterday morning at 91.4kg.
Today I was 91.2kg. Good start!
Posted : 01/07/2014 10:19 am
Good Start, hopefully tomorrow I will get to leavemy sling in the hospital that i've been in for 8 weeks and get the go ahead to start jogging and easy cycling.
In 8 weeks I have gained 2 and a half stone, I even altered my diet was eating healthy and about half of what I normaly would any less and i'd start on the cakes and snacks. Im now at 86kg which at 5 foot 7 seems alot. Ill be joining you on any diet I can find.
Posted : 01/07/2014 10:38 am
surely <200g is within a normal day to day variation
Posted : 01/07/2014 10:39 am
 loum
molgrips - Member
POSTED 1 WEEK AGO # REPORT-POST
Don't understand the one week warm up?
Surely a four week effort would have been better than waiting to start a three week challenge?
Good luck any way.
Posted : 01/07/2014 10:41 am
200g is just a big poo, surely?
Posted : 01/07/2014 10:42 am
http://www.washingtoncitypaper.com/articles/40248/straight-dope-do-you-really-sweat-one-liter-each-night/
"Total water loss by both routes for an average healthy young male averages about 25g per hour, or 200g per eight hours of sleep, and much of that is simply exhaled, not absorbed by the mattress."
Posted : 01/07/2014 10:45 am
as Pigface said "What jeans" ???
and are you ever going to wash them, or just pop them in the freezer from time to time??
http://www.theguardian.com/fashion/2014/jun/30/jeans-in-the-freezer-grant-wahl-us-world-cup
Posted : 01/07/2014 10:49 am
Not even close to a big poo!
Posted : 01/07/2014 10:53 am
@RScott
I feel your pain, I've just got back to light jogging post surgery after some eejit right turned into me in March.
I went from 12st4lbs to 14st in my enforced lay up.
The worst of it is that the insurance is still going through (he's admitted liability though), so I'm currently sans road bike, which is my main exercise as I was commuting on it every day.
Posted : 01/07/2014 10:59 am
So it's not a diet then? Or is it? If it worked before why not do it again.. but if its a lifestyle surely you never stop...
<isconfuzednow>
Posted : 01/07/2014 11:02 am
Of course it is, I'm just being light-hearted. However I am going to crash diet just to see what I can do. I've put on a few kgs in the last few months so I just want to make sure I'm closer to the 88kg ish of the last year or so when I buy jeans.
200g is a poo yes but I poo every day so that's taken into account 🙂
Yes I know, but this was over a 24 hour period. Weigh ins are before breakfast (and before subsequent poo) every morning.
Because, sadly, cakes and bread are tasty.
Posted : 01/07/2014 11:10 am
Posted : 01/07/2014 11:14 am
Ghost Dog 😉
Posted : 01/07/2014 11:22 am
Rather than lose weight, encourage your partner to put weight on so you won't feel as conscious about your own size.
Posted : 01/07/2014 11:28 am
 emsz
[i]Because, sadly, cakes and bread are tasty.[/i]
So in those other threads were you argued until you were blue in face that your body is different to mine and mine is different to everyone else's and how you suffered low energy levels and alllll that crap and how ideit wasnt working for you it does just boil down to the fact that you can't lay off the cake?
Btw you weigh two of me 😉
Posted : 01/07/2014 11:34 am
@paulmgreen my Mrs is just finishing that Aloe Vera thing now and it's crazy how much she's lost but her body shape has changed dramatically too in just 9 days! She'll be gutted if it goes back on in a week.
Posted : 01/07/2014 11:37 am
molgrips - Member
Has anyone actually weighed a poo?
Just to save me going to the freezer TBH.
Posted : 01/07/2014 11:39 am
Why not buy the jeans size you want to be then slowly and safely lose the weight when you get back and you'll have the perfect incentive?
What's the point of buying jeans that are only going to fit you for a few weeks? Either way.
Either you're going to continue to lose weight, in which case they'll be too big, or you're going back on the cakes and they'll be too small.
And why did you leave it a week to begin.
Your commitment level is showing.......
Posted : 01/07/2014 11:46 am
 Solo
If we're posting quotes....
oh and...
[i]Btw you weigh two of me[/i]
I can almost [i]feel[/i] the luv...
Posted : 01/07/2014 12:30 pm
With you being so determined to look good in your bikini on your hollybobs, can I raise another important issue you need to address....
Have you started your sunbed sessions yet? You don't want to be looking Scottish on the beach now, do you? And you'll need to get your bikini line done too. Nowt worse than stray spiders legs
Posted : 01/07/2014 12:36 pm
 Solo
[i]Your commitment level is showing.......[/i]
Really ? I can't see it.
Come on everyone, lets all look for Molly's commitment.
Posted : 01/07/2014 12:40 pm
[img] ?w=652&h=490[/img]
Posted : 01/07/2014 12:45 pm
Question is, why do I like cake so much?
Since you brought it up.. it's quite an interesting subject imo. If I don't do any exercise at all, I can easily stick to the diet. The problems start when I exercise. I've got a lot of fast twitch muscle, so when I exercise I end up consuming muscle glycogen unless I'm really careful. But sprinting is instinctive, so it's really hard to sit and spin and quite boring. And when I deplete glycogen stores, that's when I start to get unbearably hungry and crave carbs (not just cakes - bread and rice mostly, but also coke).
I raced last weekend on both days, so I didn't want to be crash dieting before that.
So just been for a run and weighed myself, 89.7kg! Will see how much goes back on this afternoon when I eat.
Posted : 01/07/2014 12:47 pm
Good going. 1.5 kg lost since this morning.
Posted : 01/07/2014 12:50 pm
Page 1 / 3
