how much space is n...
[Closed] how much space is needed to open a fridge freezer door?
12 Users
Our unpurchased fridge freezer is gonna sit at the end of the worktop next to a wall. We want space to be able to open it properly. Is there a rule of thumb for a minimum gap between the f.f. and the wall? or is each model different?
Posted : 15/12/2012 8:19 pm
Depends on the hinges. To be on the safe side I'd add the depth of the door to the width of the freezer and that should give the max width. But thats a total guess.
Posted : 15/12/2012 8:27 pm
That I would think. Ours can sit next to the wall because of the way the hinges are and the fact that the handle is a recess in the door rather than something stuck on.
As above, it will depend on the hinge design, and also on the Handle design and the front of the door (flat or convex)
Posted : 15/12/2012 8:29 pm
Go to the shop and measure if you are in doubt.
Posted : 15/12/2012 8:40 pm
 Taff
600mm is a minimum (typical width) but all 650mm or safety unless you have some American type fridge freezer type of thing
Posted : 15/12/2012 9:25 pm
Width of fridge plus 100mm generally works for me
Posted : 15/12/2012 9:31 pm
why don't they tell you this kinda stuff on the manufacturers websites?????????
will we be ok with 120mm?
Posted : 15/12/2012 9:40 pm
www.comparethefridge.con
lots of un useful info there
Saw one in Currys today that had a 'double hinge' Like some bridleway gates, you could open it either way.
Posted : 15/12/2012 9:44 pm
100mm should be fine for the Vietnamese (American) Potbellied Pig Fridge.
Posted : 15/12/2012 9:52 pm
[i]swings both ways then[/i]
Posted : 15/12/2012 10:18 pm
Different for each model. But be careful you will need the door thickness including handle as if you can't get the door to 90deg you might not be able to access any slideout trays.
We've just bought one and have a similar setup to you. We have had 2 standard 60cm wide fridges and the gap they fit in is 70cm. Door opens towards wall. Might get it in a tighter spot if it opened the other way but it would be harder to get in.
Posted : 15/12/2012 10:24 pm
there's a website called comparethefridge.com well f*** me rigid i did not know that.This forum is still solid gold.
Posted : 15/12/2012 10:29 pm
