The doctor told me to put olive oil in my ear to soften a wax build up. She didn't say how much.
Also, seeing how she battered her printer (not a euphemism) I'm glad I wasn't in to have my prostate flicked.
a few drops.
Teacup?
Say again?
Did you ask what kind of olive oil?
Ordinary, Virgin, Extra Virgin? Each will make your ear taste slightly different. Don't go for EV if you're thinking of frying the wax afterwards... it'll catch in the pan.
Just freepour till it feels full. Tricky business earwax.
I prefer my printers breadcrumbed rather than battered, especially if frying in olive oil, or earwax..
Till it comes out your nose.
Don't forget the balsamic
Not very much, or just enough, but definitely stopping before too much
Exactly 1 Efl.
I'd just go for a full head submerge if I were you.
Exactly 1 Efl.
FACT.
Umm being as I do do this (the shame), a couple of drops from a pipette type thingy (ear dropper?) and even then most will drain out anyway.
should you warm the oil before dripping it in.
Not smoking obviously, but a bit? Like stand the syringe in a cup of hot water beforehand.
No, just use the chilli-enfused stuff for pizzas
The Chilli infused oil works well 😉
Just start pouring, we'll say when.
Shouldn't she put it in [b]her[/b] ear, if she's got a wax build up?
GP advised me to to that - give it 10secs in the micro-ping, check temperature then add a [i]few drops[/i] (that was the technical, medical terminology I was given to work with) to the old lug-ole.
I was also advised to keep the treated ear pointing in a vertical direction for 5 mins or so in order the oil could do its stuff, as opposed to just dripping straight back out again...
on the olive oil and vinegar theme;
"Doctor Doctor I've got a lettuce growing out of my bottom"
"bend over I'll have a look, ah yes I can see something green there"
"that's just the tip of the iceberg!"
"I've got a dressing for that"
igmc
You could vary the temperature to check for brain stem death too. Win-win.
http://en.wikipedia.org/wiki/Caloric_reflex_test
You need to use artisan olive oil.
Ah, takes me back to my Youth. After swim sessions I would have bad ear ache, Mum would (feels like) pour some warm olive oil in my ear.
The feeling as it welled up in my ear was so soothing.
Lying across the sofa for a while, with all the noise just a faint distance muffle.
Then the reality when you sit up, and it all drains out.
We've been using that very stuff on my daughter for the past week.
they recommend massaging the front of the ear after application to help loosen things up.
I have used Almond oil ,will I die ?
[i]I have used Almond oil ,will I die ? [/i]
no, you'll just go nuts.
A light drizzle should do it
I hope in wasn't Marc Almond oil....
Just shove a whole olive in each ear for a slow release solution.
Use pitted and you can still hear too!
Classic!! Thank you people!! 😀
they recommend massaging the front after application to help loosen things up
I've heard that works for other applications too 😉
[i]derek_starship - Member
I hope it wasn't Marc Almond oil....[/i]
Wrong. Just wrong.
Until I say when.
[b]
I SAID, "UNTIL I SAY ............"[/b]
Isn't an Almond a unit of volume roughly equating to a horse full?
Pour loads and loads in.
No half measures.
If told to do something by one or more of the opposition undertake do it to the max......
