Specifically the one pictured?
This light has been up since we moved years back. I assumed it was a conventional low energy bulb that could be swapped over, but now it's failed and removing the cover I've never seen this type before. What is it called and how do you change it?
Alternative punchlines welcome alongside actual advice. Thanks!
Thanks. There was me thinking nobody in their right mind would design something where the whole thing has to be binned when it fails. Seems ridiculously wasteful.
[Alternative answer: Two. They're efficient but not much of a sense of humour]
At least 7.
1 to change the bulb
1 to tell you you don't need a new bulb but need an artisan hand crafted Mongolian yak oil lamp
1 to tell you your ceiling needs painting
1 to tell you you're a planet destroying monster for using electricity
1 to gradually turn the conversation from bulb changing to politics
1 to gradually turn the conversation from bulb changing to Israel/Palestine
1 to gradually turn the conversation from bulb changing to Brexit
And another to point out you have an asbestos artex ceiling, even though in the OP it states it’s been tested…
At least 7.
1 to tell you you don’t need a new bulb but need an artisan hand crafted Mongolian yak oil lamp
1 to tell you you’re a planet destroying monster for using electricity
What about the 100 to complain about all the bulb "standards" and argue the benefits of one "standard" over another ?
Don't forget his evil twin, the one to tell you that lightbulbs are a waste of money for those with more money than sense
And let's not forget the one who, "just doesn't get it, how could anyone be so lacking in intelligence as to ask a question like this? My toddler has been changing LED bulbs since he was 1 hour old. And he's thick. Do people really not know basic life skills like this? (cont'd p.94)"
And let’s not forget the one who, “just doesn’t get it, how could anyone be so lacking in intelligence as to ask a question like this? My toddler has been changing LED bulbs since he was 1 hour old. And he’s thick. Do people really not know basic life skills like this? (cont’d p.94)”
True! 😆
has the entire fitting failed or just one led within it? if the former it might just be the transformer/inverter that's failed, and you could possibly replace just that if you feel handy. Otherwise bin the whole thing
The reason they're like this is because no-one has standardized the thousands of different shaped light fittings that are now possible with LEDs down to a few standard bulb sizes. I doubt they ever will.
it probably is fixable, but not quite as simply as swapping a new bulb over. Most likely the LED driver (bit in the middle) has failed, which can be replaced, e.g.
https://slvlightingdirect.com/products/led-power-supply-15w-24v (not saying it's that exact one, can't see what's written on yours!!)
The reason they’re like this is because no-one has standardized the thousands of different shaped light fittings that are now possible with LEDs down to a few standard bulb sizes. I doubt they ever will.
And now there's the person who'll post the XKCD sketch about standards.
At least 7.
It seems you forgot (at least) 1 to tell you to not replace it, but to repair it instead. Then of course several more are needed to pile in with alternative (or conflicting) methods of how to repair, and anecdotes of past repairs.
We had one of those. They are not meant to be serviceable.
It failed and I replaced it with one that takes a standard E-27 lamp.
This. Mains-fed, sealed enclosure, it's enough to melt Chinesium solder joints.
... they're cheap crap.
8
All the above plus one to kick the chair away
Wow, tough audience. If i were in charge, I'd handing you 'the internet' for that line,
"Nah, no worries about tomorrow; see you IN A WEEK".
And the one who is an electrical engineer who has worked with lighting engineers for most of their life...
It's not a bulb, it's a lamp. Bulbs go in the ground.
It's not a light, it's a luminaire. FFS
Don't worry about it failing. LEDs last 50,000 hours; that's probably 50 years of your usage; I'll get my kid to take your grand kid's details and schedule a call back.
Yeah, sling it in that hole in the ground marked 'low energy' stuff. Don't cha worry, we got another container ship of crap docking in the morning, we'll have you sorted soon enough.
Chair you say- Rubbish you should use a stool when changing a light bulb, gets you higher up and allows more freedom of movement
Not enough talk of access, obviously an electric scissor lift will allow more lighting repairs but still burn the same number of calories. Stepladders? Luddites!
