Don't understand 😥
dabbled, but it seemed so bloody complicated, I gave up
double click on them is enough on most systems?
What operating system are you using?
windows 7
it's to unlock a phone, but I'll be doing it from the laptop I presume
I read this as 'how do you unzip your flies?'
glenh+1 - I thought this was another shoelace-tying-like enlightenment that would tell me I've been doing it wrong all this years.
Sorry, not to unlock a phone, to get rid of all the bloatware off an EE/Orange phone. Following Scaredypants instructions (from ages ago), failing at the first hurdle.
Should just be a double click. If that doesn't work then install 7zip and use that
Ah, file compression and encryption... part of my day to day job for my sins.
There is a conflict between some files on W7 and using Windows Zip. Not looked into it but suspect its due to the program used to zip the file originally. Easiest workaround I found was as above, use 7Zip.
Unless the file is downloaded and called:
phoneunlocker.zip.exe 😯
The vid above looks straightforward cheers
