As the title suggests really... I've got a standard berlingo forte 03 plate and I'd like a safe and secure way of slinging my hammock up within it.. any ideas on where to look for hooking points!
Sorry Mr Internet
Pop rivet hooks into the structure infront ot the passenger widow, infront of the drivers side door?
Hi Alex,you'll be buying a campervan next:)you probably have everything you need already in your climbing gear!How about using a couple of slings,one hooked over the bike rack then over the top of the rear door,then one or two wrapped round the front doors,with the windows down slightly,you could bring it all together with a couple of quickdraws!!It mite work,seen a guy in el chorro a couple of years bk who had an inflatable bed in his,he had a 12v pump to inflate it and then just let it down during the day:) or there is a company called amdro(I think)who do camper conversions for berlingos,they are cool! Not that I'm obsessed with camper vans you understand;-).rob
Will this actually work?
For a hammock don't you need a fair bit at either end where it gets wider to let you sleep in the middle? With the size of the Berlingo you're going to be sleeping right next to the mounting point.
Not got any helpful advice but good luck!
