How do I refinish b...
How do I refinish bathroom cabinet handles?
7 Users
The handles on bathroom cabinets are peeling. Whatever shit they are finished with is making a run for it.
I can't get replacements so any ideas for cleaning them down to the bare metal? Dremel tool perhaps? If so, which one?
Don't want to go down the chemical route if I can avoid it.
Any ideas appreciated and also recommendations on how to refinish them durably.
TiA.
Posted : 30/01/2023 2:27 pm
What is the distance between the screw centres? In mm. 128, 192? I might be able to find replacements.
Posted : 30/01/2023 3:12 pm
^^^ Yeah I would bet there will be alternatives - I needed to find some and it took some digging (to get exactly what I was looking for) but it worked out.
If you used a Dremel on them, you would end up with loads of surface scratches and imperfections that would undoubtedly show up after repaining.
Posted : 30/01/2023 3:19 pm
Screw centres are 97 mm (two handles) and 117 mm for the other two.
Thanks for looking!
Posted : 30/01/2023 3:23 pm
Hi Derek,
i'm not sure if these handles would do the job. They come close in looks but probably not close enough, i'm afraid.
Posted : 30/01/2023 3:36 pm
Find a rechroming place to do the job for you - they'll strip off the old finish and make em all shiny again.
Posted : 30/01/2023 3:52 pm
The alloy looks pretty badly pitted* I can't see much making them shiny shiny again.
* But sometimes it does looks much worse than it is.
Posted : 30/01/2023 4:01 pm
I don't think they are chromed-chromed. I think they are wrapped if that makes sense? It's almost like a foil that is beginning to lift. Or is that how chrome presents when it has aged?
Posted : 30/01/2023 4:08 pm
If they're metal underneath you can probably still rechrome them properly regardless of what was on there before. There are a few places that will do free quotes based on a couple of photos - might be worth checking with them?
Posted : 30/01/2023 4:16 pm
Panic over. I phoned the manufacturer and explained the situation: 4 replacement handles on the way, gratis.
RRP for non-gratis spares: £84. Result.
Great customer service from R2 Bathrooms and Roper Rhodes.
Posted : 30/01/2023 4:39 pm
That's ok then, although I think they were taking the piss with the replacement cost!
As for re-chroming.... Very expensive.
Posted : 30/01/2023 6:51 pm
