How am I going to s...
[Closed] How am I going to saw 30 oak sleepers in half?
51 Users
I’d probably use the silky saw, most dangerous of all handsaws.
Now that I can agree with, it's a vicious beast if it bounces in a cut, makes a right mess of your hand.
That chainsaw video, the man deserves what he nearly got, utterly inappropriate use of a chainsaw, the most dangerous thing there was the operator.
If you really want to get manly you need one of these
Saw I really miss having access to these, 2 blades 2 axis cutting computer controlled and with a digital length stop hands free, just press the button and step back, auto shields, auto clamping.
Posted : 05/04/2021 5:53 pm
a piece of 2400x200x100 oak will weigh at least 70kg
48kg according to the supplier's website.
Posted : 05/04/2021 6:02 pm
and THREE packets of Haribo Tangfastics. Can’t say fairer than that.
Having a a laugh this one, no way can haribo tangfastics be compared to Princess Marshmallows. No way
English oak weighs about 45lbs per cubic foot- 1 Cubic foot is a board 12'x12"x1"
American white is a little bit heavier.
For those enjoying the restoration vids on YT, here's a manly saw for dissecting big timbers.
The scariest of scaries, the Swing Saw.
Posted : 05/04/2021 6:38 pm
You need fingers to grip handlebars, and even the loss of a single digit, let along three means an end to cycling.
While I'm all for safety, were you drunk when you wrote this? You think losing a finger will be the end of cycling? Then this man probably wants a chatMeet The Man Who Mountain Bikes With One Arm | Teton Gravity Research
Posted : 05/04/2021 7:05 pm
She’s pretty good with tools generally
Evidently 😁
Sorry Moly, couldn't resist.
I'm waiting for the 'I took my saw to bits and now have it in 1000 pieces...' thread 👍
Posted : 06/04/2021 8:36 am
48kg according to the supplier’s website.
Pretty small ... I use these for the fireplace and composter but the borders/wall is made of reclaimed sidings ones which are MUCH bigger and heavier.
Either way stick a strap under when lifting off pallets etc. to avoid fingers getting caught... even 48kg will sting if it drops on a finger.
Posted : 06/04/2021 8:50 am
I used to work for a guy, you know the type, “no, it’ll be fine, I’ve got plenty of experience with a chainsaw”
He can’t walk properly now as he was cutting up some felled trees and one of them rolled against the other while he was standing between them.
Totally mangled from the knee down, he had an external metal thing fitted between knee and ankle for a number of months.
He, now, recognises that he didn’t really know what he was doing with a chainsaw.
Common sense isn’t actually all that common.
All this happened when he was about 30, he’ll be in his early 60s now, so half of his life not walking properly.
I take any safety precautions seriously.
Posted : 06/04/2021 10:12 am
That looks like something out of a 2000AD creation, that would be on the arm of some crazed cyborg. Madness. What could possibly go wrong? 😀
My maths might be wildly off, but I'm getting about 34.5kg for a 240x20x10cm piece, @ 720kg per cubic metre?
Posted : 06/04/2021 10:13 am
Common sense isn’t actually all that is all too common. Actual sense, not so much.
ftfy 😎
Posted : 06/04/2021 10:16 am
That bit seems the hardest to work out, was reading about felling in forests on sloping ground and predicting what happens to each half of the tree when you finish your cut is quite tricky - occasionally ends up with someone being crushed to death when one half of the tree flips off in the wrong direction eg moves uphill.
Posted : 06/04/2021 10:48 am
My maths might be wildly off, but I’m getting about 34.5kg for a 240x20x10cm piece, @ 720kg per cubic metre?
No thats about right.
English oak is about an average of 670kg per cubic meter and American white oak is about 750kg per cubic meter.
Japanese oak is comparable to English and Persian is comparable to American. Turkish oak is about 870kg per cubic meter and Evergreen oak is an average of between 800 and 960kg/c/m.
(I've a book from college - Handbook of hardwoods that lists all the properties of all the commercial hardwoods, its actually been invaluable over the years.)
The barberchair.
The tree splits as the backcut is made,as it falls it can send the trunk backwards into the operator, or if its high off to either side. Luck denotes its the operators side
Posted : 06/04/2021 10:50 am
Did just this 2 years ago and again this year, on 125x250 sleepers, about 40 of them.
Chainsaw works best, some good advise above on using one safely - I had a petrol erbauer model from screw fix. I had the chainsaw gloves and that helped. My hardwood sleepers were ridiculously heavy and I had to swap out the chain at some point.
For the other garden project I used 100x200 sleepers and I was able to use my srewfix mitre saw that would just cut through them in a single pass, made the whole job much easier.
I did have to cut a few sleepers with a handsaw and I really wouldn’t recommend it.
Posted : 06/04/2021 11:01 am
I have a Festool Kapex
Genuine tool envy here. Saw one demonstrated a few years ago; feels so solid and precise. I needed a chop saw to do our decking, but couldn't justify even the KS60. Went with a decent Makita which was on silly special offer, but it's been sat in a friend's house since I did the deck. He used it once and put it away in a cupboard. So it's actually been pretty poor value for money. He's badgering me to take it back, as it's taking up space. I might just sell it to be honest; a decent chop/mitre saw is a great tool if you need one, but unless you're doing regular work with it, it's bulky and redundant most of the time.
Posted : 06/04/2021 11:03 am
For the other garden project I used 100×200 sleepers and I was able to use my srewfix mitre saw that would just cut through them in a single pass
@walowiz what model was that?
Posted : 06/04/2021 11:16 am
@molgrips It was this one Erbauer EMIS254S 254mm Electric Double-Bevel Sliding Mitre - still at the same price as I paid - £180, but I figured I had more than enough projects to justify it. I don;t knwo how it compares to Festool etc, but for the money its very nicely made, solid and importantly cuts really well.
I combined it with a mitre saw stand (from Aldi of all places - as the Erbauer one wasn't in stock for ages) and using the mitre saw on a proper stand made cutting the sleepers way easier.
Link https://www.screwfix.com/p/erbauer-emis254s-254mm-electric-double-bevel-sliding-mitre-saw-220-240v/244fv
Posted : 06/04/2021 11:39 am
90% of the functionality for 20% of the price 😉
Posted : 06/04/2021 11:55 am
Such a shame they put the handle on the wrong way... 😉
Posted : 06/04/2021 12:04 pm
@footflaps lol, I really really wanted a festool, but everytime I looked at the full cost, I had to go and have a little sit down.
Posted : 06/04/2021 12:20 pm
It says 90mm cut on that saw, is it typical for the cut to be a little more than advertised? I mean, a 254mm blade is clearly more than 100mm in diameter.
Posted : 06/04/2021 12:39 pm
Such a shame they put the handle on the wrong way… 😉
Tell me about it. I've a dewalt dw700 which also has a vertical handle and its really difficult to use. Not keen on it at all.
Theres a bit more to it than that. The mount, the guard and casing get in the way. Or someties the saw is direct drive and the placing of the motor limits depth of cut.
Opting for the screwfix saw then are we ?
Best check this out, and please take note thats a little saw, not the beast that screwfix are doing.
https://www.leeds-live.co.uk/news/leeds-news/leeds-grandad-chopped-entire-hand-19438924
You;ll notice he didnt use the clamp.
If thats not the best representation of a sheepish face, I don't know what is 😆
Posted : 06/04/2021 12:44 pm
But the spindle, motor, blade guard mechanism etc are all in the way and stop the blade getting exactly half way into the wood.
Posted : 06/04/2021 12:45 pm
Of course, but @walowiz says he cut 100mm timbers with a saw advertised as cutting 90mm so clearly something is open to interpretation.
Posted : 06/04/2021 12:51 pm
Managed to reduce the amount of work we have to do by 33% by only actually ordering 20 instead of 30.
Posted : 06/04/2021 3:00 pm
/blockquote>
Yep, that's quite a small chop saw!
Posted : 06/04/2021 3:16 pm
You could remove all cutting required by digging really deep holes.
Are there any sawmills locally that would do the lot for you in a matter of minutes?
For a price obviously. And transporting 20x sleepers may be the bigger problem there.
Posted : 06/04/2021 3:37 pm
Lol
#didntthinkitthrough
Posted : 06/04/2021 4:00 pm
Good point, our local builder's merchant has their own timber yard and you can just order timber pre-cut to exact lengths if you're buying a load.
Posted : 06/04/2021 4:08 pm
 Olly
i bought a circular saw to do 5. i did them half way through and flipped them over. it went through them like butter.
i did actually do one of them by hand, just to see how long it would take and i was quite pleased how easy it was with a regular hand saw. they didn't bend and bind like soft wood does.
Have you got them yet. I was staggered by how heavy they are, compared to softwood ones.
https://www.screwfix.com/p/dewalt-dwe560-gb-1350w-184mm-electric-circular-saw-240v/83289
Posted : 06/04/2021 4:53 pm
Yeah they arrived this morning. Just finished my work call so I'm heading out now to have a crack at one of them.
Posted : 06/04/2021 5:02 pm
Uh oh. Standby... 😜
Posted : 06/04/2021 7:19 pm
I’m heading out now to have a crack at one of them.
Posted 3 hours ago
3 hours? #Pray4molgrips
Posted : 06/04/2021 8:20 pm
Posted : 06/04/2021 8:35 pm
Posted : 06/04/2021 8:53 pm
Yes, any updates?
Bruneep; I once saw a man cutting a ply/MDF board by holding it up in mid-air with one hand, and cutting it with a circular saw in the other. Quality work practices. Some people shouldn't ever be allowed to hold spoons, let alone dangerous power tools.
Thinking about that horrific dismemberment above; what's the insurance situation for such injuries? I'm pretty sure that there are strict conditions relating to the use of dangerous equipment, such as having had proper training, using correct safety procedures etc. Such an injury is life changing, and potentially massively debilitating. Putting aside the years needed for surgeries, proper rehabilitation, physiotherapy etc, even if you were to regain use of a limb, it would never function 100% again. So that could have a huge impact on a person's economic situation, possibly requiring them to need the financial support a big payout could provide. But I'm sure insurance companies protect themselves against idiocy. If that happened to someone, and they didn't get a payout, that could have massive consequences for the rest of their life. Terrifying.
Posted : 07/04/2021 10:19 am
I'll put a fiver on
Half the pieces are to long the other half to short after using the first cut sleeper as a guide and getting it wrong.
Posted : 07/04/2021 10:23 am
I noticed in the photos of that chap who chopped his hand off, that the saw was not mounted to the stand just placed on it (likely for the photo). Think I'd just use a nice sharp hand saw. Hmmm, see what I did there.
Posted : 07/04/2021 11:55 am
Sorry to disappoint. The circular saw is still boxed, turns out it is indeed a piece of piss to saw them in half (properly measured of course) with a hand saw (lolol).
I had to take another few inches off the bottom of the trench and then come up with a method for erecting them reasonably accurately. I roughly levelled the trench using a fence post and a spirit level and some more digging - this involved removing some pretty large rocks that were preventing the last few inches from being loosened up. Then I used a ratchet strap to lash the first eight together, I developed techniques for straightening them up using the pry bar and big stones, now the concrete is setting:
I think doing the rest will be easier because this lot are more or less straight and now fixed in position so I can just lash the next eight to these and pour.
Posted : 07/04/2021 3:23 pm
they might be straight by spirit level but they look squint as **** to the eye which is going to piss your wife off no end.
Posted : 07/04/2021 3:42 pm
Straight at the bottom edge and all hand cut to slightly different lengths?
If purposeful to have a staggered top edge then it works well. If not, then you'll have to quickly run a chainsaw along the top to straighten them off 😉
Posted : 07/04/2021 3:47 pm
That's really good, well done Molegrips. Good to see you've listened to common sense, and not bought a chainsaw. As for that circular saw you bought; just take it back. As I said; a plunge saw is a much better tool, although a bit more expensive. Look elsewhere other than BnQ for power tools though, they don't have a great selection, and what they do have tends to be the cheap end of the market, tools for very occasional use rather than things that will serve you well.
What are you going to do with all those rocks?
Posted : 07/04/2021 3:53 pm
Use a length of string to get them all level, as long as the string isnt made to slope you can just hammer each down till the string brushes the top.
I would also look to cap them though with a long board. Problem with endgrain is it soaks up moisture, one of the reasons outside cellar doors rot at the base of the stiles.
All this for a hipster fence 😆
Posted : 07/04/2021 4:48 pm
www.ffx.co.uk is the wiggle of the power tool world....
Posted : 07/04/2021 5:01 pm
Good to see you’re able to cut using a hand saw, it’s easier on the smaller 100x200 sleepers, but the big 250 hardwood sleepers are really hard work to cut through with a hand saw.
I can confirm that the erbauer mitre saw I linked to, will cut through the 100 x 200 sleepers completely in a single pass and makes the job a complete piece of proverbial.
Probably worth mentioning that I was able to justify the purchase, as I had an 18m retaining wall to do and then a 15m run of raised beds to do using sleepers. I’m keen on DIY, but I’m not doing all that by hand.
 Olly
when i did mine i bought a 300 long auger bit and drilled a straight and level hole through each one. Use threaded bar through the whole lot to tie them together, kept them level and from falling out of line with each other.
Posted : 07/04/2021 5:29 pm
Good to see you’ve listened to common sense, and not bought a chainsaw
When I built a 15m long retaining wall out off sleepers, 4 high, the extra large ones, I used common sense and got the most suitable tool for the job = a chainsaw.
Posted : 07/04/2021 5:41 pm
You never have to justify the purchase of a new power tool - this is STW, we understand.
I normally start with the tool I want to buy and the decide what I'm going to use it for 😉
Posted : 07/04/2021 5:50 pm
http://www.ffx.co.uk is the wiggle of the power tool world….
more expensive that they used to be and few decent offers anymore? Yup agree with that 🤣
I’ve got my last few Makita tools from Tools4Trade - sounds a bit dodge but great prices & quick delivery 😃
Posted : 07/04/2021 5:54 pm
Bruneep; I once saw a man cutting a ply/MDF board by holding it up in mid-air with one hand, and cutting it with a circular saw in the other. Quality work practices. Some people shouldn’t ever be allowed to hold spoons, let alone dangerous power tools.
You seem shocked but was a common sight on site 20 years ago.
Not been on a site in 20 years but I can't imagine the tradies have stopped taking short cuts.
*Do you feel lucky punk*
Posted : 07/04/2021 6:44 pm
@Painey agreed, tried every other tool I had on the very large 2.4m 60kg+ 125x250 sleepers for my retaining wall and the one that worked the best was the chainsaw. Would use the chainsaw every time on those.
I do agree that chainsaws are dangerous tools and should be treated with respect and care.
Posted : 07/04/2021 7:08 pm
Absolutely. I had the same size sleepers and they're very heavy. I specifically went for an electric saw due to the fact it stops instantly when you let go of the button. I also learned how to sharpen the blade properly so it cuts well. I was amazed how quickly they can go blunt and you really notice the performance drop off. I'd go as far to say that cutting through sleepers with one of those is highly unlikely to cause any safety issues, providing you know what you're doing. Very little chance of kickback but I wouldn't want to use a petrol one on a tree. A friend is a tree surgeon and has told me all about the dangers involved. Sod that.
Posted : 08/04/2021 9:55 am
If I'd been building such a wall, I'd have used common sense and employed the most suitable tool for the job: the massive industrial saw in the timber merchants who supplied the sleepers. Obviously having them do it for me. So, so much easier. A decent timber suppliers who can cut, mill and plane wood to your specifications, is an absolute boon. I had one recently plane some lovely Ash planks to a specific thickness; was £22.85 inc vat for the work. They do such jobs for free, if you order a sufficient amount.
Posted : 08/04/2021 10:03 am
Buying a chainsaw means buying a lot of protective equipment (if you want to retain all your limbs and blood and eyes), so I can see why it's a lot less hassle to just saw them in half.
With that said... I would have put a horizontal line in to make sure that the sleepers are straight, level and upright.
I'd also be tempted to buy a lod of rebar and drill through the sleepers mid-way so I could use the rebar as a brace to hold them together. You'd need a big hammer for that though, so possibly a trip to the local crossfit gym needed.
Other than that, your garden looks like a cross between a south american strip mine and trench warfare. Good work for an easter weekend.
Posted : 08/04/2021 10:14 am
All the rage now, lawns are so 2010....
Posted : 08/04/2021 10:20 am
If I’d been building such a wall, I’d have used common sense and employed the most suitable tool for the job
A chainsaw.
Posted : 08/04/2021 10:27 am
A chainsaw.
Err, no. Read the rest of my post.
Edit: I'm talking about cutting seasoned timbers, not raw. You're probably thinking of those massive static saws that use a chainsaw to cut big logs, no? My local timber suppliers don't have anything like that, they only get in rough sawn seasoned and treated timber, then mill it down. They won't touch anything like proper old railway sleepers, because of the hazardous chemicals and old nails etc that are often embedded. If I wanted some of those cut down, I'd get an idiot with a chainsaw. Life's too short to risk your own safety. 😉
Posted : 08/04/2021 10:30 am
I did.
But I don't have one of those saws at home.
I'd hate to get all my wood cut then dig my foundations out and find the suitable ground is deeper than expected and have a heap of now too short wood.
Or a garden in a dug up state with large holes for longer than necessary.
Bit like when I did my fence I could have had the mill cut my posts to exact height and found it looked like **** all when I found immovable rock under footings where the posts had to land.
Used the chainsaw to cut angles on top of them too*
*But I do have a couple of chainsaws and training /ground working PPE which is what makes it the right tool for me. If you really want to play with your own life. Forget the circ saw or the chain saw. A 9 inch grinder makes the chain saw look like a electric carving knife by comparison.
Posted : 08/04/2021 10:33 am
Honestly, sawing them by hand is an absolute piece of piss, and it's so quick and easy compared to the rest of the job it's not worth the expense and risk of a power tool, or even the faff of plugging it in. I'd be surprised if it takes 60 seconds to get through.
She's out there with me digging, and assessing the results as we go. You didn't assume that she was leaving me to it just because she's female and landscaping is man's work, did you? 😉
Anyway they might look squint compared to the remains of the old lawn but that's not level, and it's coming out to be properly levelled off anyway. At first I used a line to make sure they were parallel with the patio slabs - I put in the first few and bound them to each other with a ratchet strap. Then I tapped them down to as level as I could get it, whilst adjusting the alignment with a spirit level on all sides. Then I added some soil/rocks to hold them in place whilst I put in the postcrete. Once the first few were in I installed more by lashing them to the first few. However, it turns out that not only do they vary in length a bit but also depth and squareness, so this technique has taken us down the 'rustic' route. Which is fine, really. Now I've set a line horizontally across the garden (not in the picture) because whilst they aren't all even heights I don't want them to trend upwards or downwards, cos that'll look like crap.
Now I'm digging the sub-soil out of the bottom of the garden from where the new patio slabs are going, and really it's not soil at all, it's actual rubble, there are so many stones in it.
Posted : 08/04/2021 11:21 am
Oh, I bought one of those to take up a little square of tarmac that was in the wrong place. It wasn't too bad, once I figured out the easy way to hold it, but yes, pretty terrifying. It also produced epic amounts of dust that coated everyone's car, especially my neighbour's new (to him) Z4 he'd just lovingly waxed. He then waxed it again, now it's covered in dust from the digging 🙂
Posted : 08/04/2021 11:27 am
landscaping is man’s work
Then there's 'manscaping', which is something a bit different...
It also produced epic amounts of dust that coated everyone’s car, especially my neighbour’s new (to him) Z4 he’d just lovingly waxed. He then waxed it again, now it’s covered in dust from the digging 🙂
We once had some work done, and in the process of taking out rubbish, our neighbour's car got a bit of dirt on the front. So I got a bucket of hot soapy water and a hose, and gave it a bit of a clean. Problem was, the car was a quite filthy to begin with, so it now had a nice clean front which contrasted with the rest, so I cleaned the entire car. I went to explain this to the neighbour when she came back, and she took one look and said 'oh my god, it's never been that clean before!' 😀
Posted : 08/04/2021 11:50 am
Page 2 / 2
