Home electrics teas...
Home electrics teaser for tonight
10 Users
 kilo
No power in the house, nothing appears to have tripped on the fuse board!
What’s wrong, how much is it going to cost? (London prices!)
Place your bets!!!!
Posted : 19/12/2022 8:23 pm
There is a power cut. It won't cost you anything.
Posted : 19/12/2022 8:24 pm
Phone 105 and see if there's a power cut in your area
Someone has hacked your smart meter and switched you off....
Posted : 19/12/2022 8:25 pm
https://www.ukpowernetworks.co.uk/power-cut
Posted : 19/12/2022 8:28 pm
Check the RCD, sometimes they look like they're still powered up but need a reset.
Main fuse might have popped, especially if you were drawing a particularly large current. Can be swapped for free sometimes if it is a low/out of date amperage.
The supply in the street is 3 phase, if one phase has tripped a third of the houses may have a power cut whilst the other two thirds are ok. If this is the case, it's not your fuse.
Posted : 19/12/2022 8:57 pm
 kilo
The street appears illuminated apart from us 🙁
RCDs been reset but no joy, emergency electrician en route. Ayup mtb lights being used.
Stealth edit, the far end of the road was in darkness and it was indeed a power cut!!
Posted : 19/12/2022 9:05 pm
 kilo
Well done Greybeard, spot on. Never new power cuts could be so localised, another learning day!
Posted : 19/12/2022 9:23 pm
I heard he was raisin cain.
Posted : 19/12/2022 9:44 pm
Sounds pretty sketchy
Posted : 20/12/2022 5:24 am
Our neighbour had this recently and the joint in the road had corroded which cut their power. TOOK 3 WEEKS.
Luckily they were supplied with a generator, and I helped the street out with my supply of earplugs.
Posted : 20/12/2022 10:45 am
