Before I inadvertently burn my new old house down I thought I’d check if the follow was going to be possible and how to go about doing it. I have no practical skills.
In short, I’m looking to add a timer module to a 3kw immersion heater:
Module – [url= http://www.timeguard.com/products/time/immersion-and-general-purpose-timeswitches/24-hour-fused-spur-timeswitch ]here[/url]
Bathroom socket selection, 'heat' is the one in question:
Inside:
Two questions:
1.The existing setup has two earth connections, one on the power line in and one on the lead out to the heater, each is connected to a separate earth screw. The timer above has a single earth screw – is this a problem? If so, what is the solution?
2.Can you see any other issues with this?
Thanks
1. No problem. That metal bar is linking the two earth connections.
2. Nope.
Flap - thanks, the issue with the new module is that it only appears to have one earth connection, see page 4 [url= http://www.timeguard.com/media/3027/FST24_FST77_Instructs_135x85_issue2.pdf ]here[/url]
Could you just bodge both earth connections into the same hole/screw?
no harm to you, but that wall is a mess. looks like a re wire is due to me .
Provided they fit, yes you can do that, but make sure you've done the screw up really tight afterwards and that they can't pull out.
Its fine to do that. Just give them both a tug once tightened to make sure they have caught properly.Could you just bodge both earth connections into the same hole/screw?
Ok, thanks all, I'll give it a go.
rmacattack - that wall wont exist before long... new wiring, heating/plumbing, floors, kitchen, bathroom, quite a few windows... Saving the money is the biggest issue.
This is a temporary measure to make things a bit easier in the morning.
It's fine to stick them in together.
Although the load cable looks like it's a flex so it might be tricky, but not impossible, to get them tightened up together.
As others have said give it a tug once you have tightened up the earth terminal to make sure they are in properly.
If you have some needle pliers you could twist the wires into one piece to aid them going in and staying in.
I wish I had done just that last night after fitting a new ceiling light and the second one in the run stopped working as one of the live terminals popped out, which meant I had to take the whole thing down again which, given its design, was a faff.
Spoken like a true Sparky, but you forgot to say that he needs a new consumer unit too.
It needs the works.
The boiler is 36 years old...
That wallpaper tho.....wow
Ps. thanks again for the feedback, I've ordered the timer module so should be good to go soon enough.
Post that on an electricians forum and it'll run to 78 pages 😀twist the wires into one piece to aid them going in and staying in.
Do the curtains match exactly? If they do OMG.
Does it really need to say "plug" on the one with a... plug... in it?
How do you know it says PLUG? all I can see is _UG
But we didnt know to put a plug in it until we wrote plug on it. Now that it's got a plug in it makes perfect sense.
If you mean: Are they the same pattern - Yes
If you mean: When fully drawn, do the curtains line up with the wallpaper - also Yes.
