Hmmm. Bluetooth spe...
[Closed] Hmmm. Bluetooth speaker connected to laptop but no sound. Aidez moi!
6 Users
It's connected. The speaker volume is up.
What the flip is the problem.
Any help much appreciated.
I
Posted : 04/10/2017 11:23 am
Volume on the laptop?????
Posted : 04/10/2017 11:24 am
Separate volume controls for Bluetooth audio muted would be my first guess.
Open volume control from the system tray and click the icon at the top.
Make sure bluetooth device is selected for output.
(Ps. I've discovered how to shut the Ba-BOOM noise up when starting the Jam Heavy Metal - just tap the on/off button again. 🙂 )
Posted : 04/10/2017 11:36 am
tthew - can you expand on that please?
Ta.
DezB bluetooth device selected.
It's bugging me now!
Posted : 04/10/2017 11:56 am
Are there some volume controls in whatever application you're using to play music (assuming that's what you're doing?)
Posted : 04/10/2017 11:59 am
Er, it was just a guess, I was expecting you to do the leg work! 😳
OK, try opening the Control Panel, (not sure how you do that on Windows 10, probably use the Cortana search or something) open Sounds then you should have separate controls for different devices, like the built in speakers and your blue tooth speaker.
Posted : 04/10/2017 12:02 pm
Right-click on the speaker icon in the system tray, it should give you a mixed panel.
Can you pair it with something else as a test, make sure it's not broken? Your phone maybe?
Yep. Spotify volume and laptop volumes are mid level.
Posted : 04/10/2017 12:03 pm
Bluetooth on Windows is garbage. It all looks good from your screenshots.
Now get a 3.5mm jack lead and plug the Jam into the laptop's headphone port!
Sorted 😉
Posted : 04/10/2017 12:46 pm
[i]Right-click on the speaker icon in the system tray[/i]
Gives "playback devices" on this here old Win7... might help.
Posted : 04/10/2017 12:49 pm
