Help my failing Goo...
[Closed] Help my failing Google skills
4 Users
I need a new 92mm square, computer fan. These are easy to find in 25mm depth. However, the one it is replacing is only 20mm and so a 25mm deep one won't fit in the casing...
Any suggestions where I may find a skinny fan?
Ta
Posted : 04/02/2020 7:32 pm
Paris fashion week?
Posted : 04/02/2020 7:38 pm
https://www.overclockers.co.uk/cryorig-qt90-thin-profile-15mm-pwm-600-2500-rpm-fan-92mm-fg-007-cy.html
They have other options. First hit for "92mm low profile fan".
Posted : 04/02/2020 7:40 pm
Googling "92x92x20" throws up a few options - seem to be outside UK though
https://www.google.com/search?q=92x92x20+fan&
That overclockrs fan looks promising, but it's a 4pin connector - I only have a +&- connection available.
Posted : 04/02/2020 7:48 pm
The 4 pin connector is for speed control iirc. Connect the red to red and black to black and it'll run flat out. Pretty sure you can by a conversion jump lead if required.
Posted : 04/02/2020 9:13 pm
