Help me STW
[Closed] Help me STW
7 Users
Looking for an app that adds up minutes, does that make sense?
Example would be 10.13 + 47 minutes = It’s for Enduros.
Any ideas?
Posted : 09/01/2019 10:51 am
A calculator?
Posted : 09/01/2019 10:54 am
Got one but doesn’t add up in 60’s
Posted : 09/01/2019 10:56 am
Excel. Put a colon : between the two numbers and it recognises numbers as hours and minutes. Then you can add or subtract etc.
Posted : 09/01/2019 10:58 am
https://play.google.com/store/apps/details?id=com.teaxapp.hourcal
Use it to add up my overtime.
Posted : 09/01/2019 11:00 am
Multiply by 60, work in seconds, then divide by 60 at the end.
Posted : 09/01/2019 11:02 am
Do you mean 10:13 as in 10 hours 13 minutes, or is the .13 decimal hours (which is 7m 48s I think)?
Posted : 09/01/2019 1:39 pm
Yes as in 10 hours 13 minutes. Timings in Enduros goes like this, start at say 10.13 first lap you have 47 minutes to do it, second lap 43 minutes 3 lap 38 minutes.
Looking for a app that will calculate this when sat in a field before the start, Excell is a no no
Posted : 09/01/2019 2:40 pm
A lot of inexpensive calculator have a H/M/S function, it takes a little bit to learn to work it, but it's easy once you do.
Posted : 09/01/2019 2:46 pm
So you're asking what the cut off is if you start a lap at 10:13am and have 47 minutes to finish it in? And then again at say 11:05am plus 43 minutes and so on?
I'd just print off a grid of start times (ie. 1-60 minutes) down the left side, lap times across the top (30mins to 60 or whatever) and the projected finish times in the middle and get it laminated. the have a couple of empty boxes to write the times for the day on in chinagraph pencil at the bottom.
Posted : 09/01/2019 2:56 pm
