Help me see my way ...
[Closed] Help me see my way - to my garage
6 Users
My garage is on the opposite side of my house to the back door and it's very dark when I pop round for an evening fettle.
I need some lights to avoid slips, trips and falls (and walking into spiders webs). It's 26m around the girth of the wall from back door to garage door.
I was thinking about low level lights as I don't want to illuminate the whole garden. There's one outside light about halfway round which is switched internally - if I can take something off this it would be ideal, or I could possibly drill through to a internal socket near the back door.
Anyone done similar and can recommend something suitable?
Posted : 20/11/2018 12:39 pm
Mpow Solar Lights, 20 LED Solar Powered Security Lights with Motion Sensor Wide Angle Lighting , Upgraded Sensor Head Waterproof for Outdoor, Yard, Garage, Pathway and Garden, Pack of 4
https://www.amazon.co.uk/dp/B079QPFQGL/ref=cm_sw_r_cp_apa_hia9Bb2J5NRBF
Posted : 20/11/2018 12:46 pm
I've tried solar lights but it's too dark down the sideways they never come on!
Posted : 20/11/2018 12:49 pm
Head torch?
Posted : 20/11/2018 12:57 pm
I have a few of these dotted around.
Work fine.
https://www.amazon.co.uk/dp/B003BZSV20/
Posted : 20/11/2018 12:58 pm
I've just put a small run of these  https://www.amazon.co.uk/gp/product/B07CJZ5KQB/ alongside our garage (there is a security light or two, but this just helps).
The difference from the others i've found is that these are on a dimmer switch. You can have them really quite low, so much less power and less annoyance, but enough to make things visible. I have mine on a timer, but obviously you could connect them up to a sensor. Decent amount of waterproof, decent light, etc
The only downside is the length of wire between the dimmer and the plug; i just cut it, joined another 3m wire, and then reconnected everything.
Posted : 20/11/2018 1:14 pm
If you want no fuss put a waterproof battery operated camping light out there. The rechargable ones are less powerful. I had a look in Go outdoors but I preffered the ones on amazon in the end.
Posted : 20/11/2018 1:56 pm
