Help me find my ima...
[Closed] Help me find my imaginary 19mm socket.
8 Users
Reet.
Need a deep reach 19mm socket that can hold a nut captive within it. Doesn't matter if the nut is held in by magnetism/o-ring etc so long as it's a proper off the shelf product (long story but it's for a demo for an important client where a bodge is a no no).
Been through the usual magnetic spark plug sockets/ grip tite sockets but nothing in 19mm.
Posted : 20/06/2016 7:31 pm
Spotted those thanks but wondered what stopped them staying with the nut rather than in the socket?
Posted : 20/06/2016 7:40 pm
I'd imagine slightly oversized so that they're an interference fit in the socket. They were pretty much all Google showed up, apart from a set at Aliexpress for power screwdrivers.
[url= https://www.amazon.co.uk/Shank-Socket-Magnetic-Driver-Power/dp/B009PL6KKE ]Or these[/url]
Posted : 20/06/2016 7:42 pm
I bought [url= http://www.ebay.co.uk/itm/351675335768?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT ]this [/url]one recently. Works well but the seller seems to have sold out. Might be worth dropping [url= http://www.axminster.co.uk/proxxon-1-2-drive-spark-plug-sockets-with-magnetic-insert-ax806383 ]them[/url] a email/call?
Posted : 20/06/2016 7:54 pm
can't you glue inside a rare earth magnet?,if done carefully should look good and not a bodge
Posted : 20/06/2016 8:04 pm
That's a neat idea teethgrinder, I just ordered one.
Snap On made a short 1/4, 3/8 and 1/2 inch drive adaptor which had a magnetic extended centre which went through the socket drive centre and adhered to a bolt head. It didn't work with nuts.
OP would these not work for you?
https://store.snapon.com/MAGNETIC-AND-SURFACE-DRIVE-SOCKETS-C796485.aspx
Posted : 20/06/2016 8:19 pm
So a bit of card folded over just won't cut it. What's the world coming too....
Posted : 20/06/2016 9:10 pm
I think maycontainnuts has what you're after (and with that username!)
but if not maybe [url= https://www.cromwell.co.uk/shop/hand-tools/standard-impact-1-2inch-sd/19mm-wheel-nut-impact-socket-1-2inch-sq-dr-/p/KEN5833082K ]this[/url] or [url= https://www.kincrome.com.au/super-impact-socket-19mm ]this[/url] - but while they say they can be used with retaining rings they don't show how?
Posted : 20/06/2016 9:12 pm
It's a nuclear ting.
That looks ideal shaggy, just found a euro supplier with a 3/4 day delivery so could be an option.
Those inserts don't look too bad actually teethgrinder
Has to be a deep reach socket mcmoonter as it's winding the nut down to the bottom of a stud.
maycontainnuts, spotted some similar but the ones in your link are quite a bit cheaper cheers.
Thanks again everyone.
Posted : 20/06/2016 9:17 pm
Greybeard - Member
but if not maybe this or this - but while they say they can be used with retaining rings they don't show how?
Usually the rings and pins are to retain the socket onto the impact wrench.
Posted : 20/06/2016 9:20 pm
